qubino RGBW Dimmer
Publié : 28 mars 2017, 20:53
Bonjour, je viens d'inclure mon module reçu la semaine dernière et voici ce que j'ai:
"associations" : [
"command_classes" : {
"0" : {
"hex" : "0x00",
"name" : "COMMAND_CLASS_NO_OPERATION"
"32" : {
"hex" : "0x20",
"name" : "COMMAND_CLASS_BASIC"
"37" : {
"hex" : "0x25",
"name" : "COMMAND_CLASS_SWITCH_BINARY"
"38" : {
"hex" : "0x26",
"name" : "COMMAND_CLASS_SWITCH_MULTILEVEL"
"39" : {
"hex" : "0x27",
"name" : "COMMAND_CLASS_SWITCH_ALL"
"51" : {
"hex" : "0x33",
"name" : "COMMAND_CLASS_COLOR"
"90" : {
"hex" : "0x5a",
"name" : "COMMAND_CLASS_DEVICE_RESET_LOCALLY"
"94" : {
"hex" : "0x5e",
"name" : "COMMAND_CLASS_ZWAVE_PLUS_INFO"
"112" : {
"hex" : "0x70",
"name" : "COMMAND_CLASS_CONFIGURATION"
"114" : {
"hex" : "0x72",
"name" : "COMMAND_CLASS_MANUFACTURER_SPECIFIC"
"115" : {
"hex" : "0x73",
"name" : "COMMAND_CLASS_POWERLEVEL"
"133" : {
"hex" : "0x85",
"name" : "COMMAND_CLASS_ASSOCIATION"
"134" : {
"hex" : "0x86",
"name" : "COMMAND_CLASS_VERSION"
"data" : {
"basicType" : {
"value" : 4
"battery_level" : {
"value" : null
"can_wake_up" : {
"value" : false
"genericType" : {
"value" : 17
"isAwake" : {
"updateTime" : 1490726629,
"value" : true
"isBeaming" : {
"value" : true
"isFailed" : {
"value" : false
"isFrequentListening" : {
"value" : false
"isInfoReceived" : {
"value" : true
"isListening" : {
"value" : true
"isReady" : {
"value" : true
"isRouting" : {
"value" : true
"isSecured" : {
"enabled" : false,
"value" : false
"isSecurity" : {
"value" : false
"isVirtual" : {
"value" : ""
"isZwavePlus" : {
"value" : true
"is_enable" : {
"value" : true
"lastReceived" : {
"location" : {
"value" : "Salle à manger"
"manufacturerId" : {
"hex" : "0x0159",
"value" : 345
"manufacturerProductId" : {
"hex" : "0x0054",
"value" : 84
"manufacturerProductType" : {
"hex" : "0x0001",
"value" : 1
"maxBaudRate" : {
"value" : 40000
"name" : {
"value" : "bandeau led"
"neighbours" : {
"value" : [
1,
2,
6,
9,
10,
11,
19,
21,
26,
27,
29,
30
"pending_changes" : {
"count" : 0
"product_name" : {
"value" : "Unknown: type=0001, id=0054"
"security" : {
"value" : 0
"specificType" : {
"value" : 1
"state" : {
"value" : "Complete"
"type" : {
"value" : "Light Dimmer Switch"
"vendorString" : {
"value" : "Qubino"
"version" : {
"value" : 4
"groups" : {
"1" : {
"associations" : [
1,
0
"label" : "Group 1",
"maximumAssociations" : 1,
"pending" : 1
"instances" : {
"0" : {
"commandClasses" : {
"37" : {
"data" : {
"0" : {
"data_items" : "True or False",
"expected_data" : null,
"genre" : "User",
"help" : "",
"name" : "Switch",
"pendingState" : null,
"poll_intensity" : 0,
"read_only" : false,
"type" : "bool",
"typeZW" : "Bool",
"units" : "",
"updateTime" : 1490726299,
"val" : true,
"value_id" : 72057594646708000,
"write_only" : false
"38" : {
"data" : {
"0" : {
"data_items" : "A byte between 0 and 255",
"genre" : "User",
"help" : "",
"name" : "Level",
"type" : "int",
"typeZW" : "Byte",
"units" : "",
"updateTime" : 1490726422,
"val" : 99,
"value_id" : 72057594646725000,
"1" : {
"genre" : "User",
"help" : "",
"name" : "Bright",
"type" : "bool",
"typeZW" : "Button",
"units" : "",
"updateTime" : 1,
"val" : null,
"write_only" : true
"2" : {
"genre" : "User",
"help" : "",
"name" : "Dim",
"type" : "bool",
"units" : "",
"updateTime" : 1,
"val" : null,
"write_only" : true
"3" : {
"genre" : "System",
"help" : "",
"name" : "Ignore Start Level",
"type" : "bool",
"typeZW" : "Bool",
"units" : "",
"updateTime" : 1,
"val" : true,
"value_id" : 72057594655113000,
"4" : {
"genre" : "System",
"help" : "",
"name" : "Start Level",
"type" : "int",
"typeZW" : "Byte",
"units" : "",
"updateTime" : 1,
"val" : 0,
"39" : {
"data" : {
"0" : {
"data_items" : "Disabled;Off Enabled;On Enabled;On and Off Enabled",
"genre" : "System",
"help" : "",
"name" : "Switch All",
"type" : "List",
"typeZW" : "List",
"units" : "",
"updateTime" : 1,
"val" : "Disabled",
"value_id" : 72057594655130000,
"updateTime" : 1
"51" : {
"data" : {
"0" : {
"data_items" : "A string",
"genre" : "User",
"help" : "",
"name" : "Color",
"type" : "String",
"typeZW" : "String",
"units" : "#RRGGBBWW",
"updateTime" : 1490726612,
"val" : "#FFFF0000",
"value_id" : 72057594646938000,
"1" : {
"data_items" : "Blue;Cool White;Custom;Cyan;Gray;Green;Lime;Magenta;Maroon;Navy;Off;Olive;Purple;Red;Silver;Teal;Warm White;Yellow",
"genre" : "User",
"help" : "",
"name" : "Color Index",
"type" : "List",
"typeZW" : "List",
"units" : "",
"val" : "Yellow",
"2" : {
"data_items" : "An integer between 2147483648 and 2147483647",
"genre" : "System",
"help" : "",
"name" : "Color Channels",
"type" : "int",
"typeZW" : "Int",
"units" : "",
"updateTime" : 1490725203,
"val" : 29,
"value_id" : 72057594655326000,
"3" : {
"genre" : "User",
"help" : "",
"name" : "Duration",
"type" : "int",
"typeZW" : "Byte",
"units" : "Sec",
"updateTime" : 1490726310,
"val" : 0,
"94" : {
"data" : {
"0" : {
"data_items" : "Read only",
"genre" : "System",
"help" : "",
"name" : "ZWave+ Version",
"read_only" : true,
"type" : "int",
"typeZW" : "Byte",
"units" : "",
"val" : 1,
"value_id" : 72057594656031000,
"1" : {
"genre" : "System",
"help" : "",
"name" : "InstallerIcon",
"read_only" : true,
"type" : "int",
"typeZW" : "Short",
"units" : "",
"val" : 1536,
"2" : {
"genre" : "System",
"help" : "",
"name" : "UserIcon",
"read_only" : true,
"type" : "int",
"typeZW" : "Short",
"units" : "",
"val" : 1536,
"115" : {
"data" : {
"0" : {
"data_items" : "-1dB;-2dB;-3dB;-4dB;-5dB;-6dB;-7dB;-8dB;-9dB;Normal",
"genre" : "System",
"help" : "",
"name" : "Powerlevel",
"type" : "List",
"typeZW" : "List",
"units" : "dB",
"updateTime" : 1,
"val" : "Normal",
"value_id" : 72057594656375000,
"1" : {
"genre" : "System",
"help" : "",
"name" : "Timeout",
"type" : "int",
"typeZW" : "Byte",
"units" : "seconds",
"updateTime" : 1,
"val" : 0,
"2" : {
"genre" : "System",
"help" : "",
"name" : "Set Powerlevel",
"type" : "bool",
"units" : "",
"updateTime" : 1,
"val" : null,
"write_only" : true
"3" : {
"genre" : "System",
"help" : "",
"name" : "Test Node",
"type" : "int",
"typeZW" : "Byte",
"units" : "",
"updateTime" : 1,
"val" : 0,
"4" : {
"genre" : "System",
"help" : "",
"name" : "Test Powerlevel",
"type" : "List",
"typeZW" : "List",
"units" : "dB",
"updateTime" : 1,
"val" : "Normal",
"5" : {
"data_items" : "A short between 4294934528 and 32767",
"genre" : "System",
"help" : "",
"name" : "Frame Count",
"type" : "int",
"typeZW" : "Short",
"units" : "",
"updateTime" : 1,
"val" : 0,
"6" : {
"genre" : "System",
"help" : "",
"name" : "Test",
"type" : "bool",
"units" : "",
"updateTime" : 1,
"val" : null,
"write_only" : true
"7" : {
"genre" : "System",
"help" : "",
"name" : "Report",
"type" : "bool",
"units" : "",
"updateTime" : 1,
"val" : null,
"write_only" : true
"8" : {
"genre" : "System",
"help" : "",
"name" : "Test Status",
"read_only" : true,
"type" : "List",
"typeZW" : "List",
"units" : "",
"updateTime" : 1,
"val" : "Failed",
"9" : {
"genre" : "System",
"help" : "",
"name" : "Acked Frames",
"read_only" : true,
"type" : "int",
"typeZW" : "Short",
"units" : "",
"updateTime" : 1,
"val" : 0,
"updateTime" : 1
"134" : {
"data" : {
"0" : {
"genre" : "System",
"help" : "",
"name" : "Library Version",
"read_only" : true,
"type" : "String",
"units" : "",
"updateTime" : 1490725204,
"val" : "3",
"value_id" : 72057594656686000,
"1" : {
"genre" : "System",
"help" : "",
"name" : "Protocol Version",
"read_only" : true,
"type" : "String",
"units" : "",
"val" : "4.24",
"2" : {
"genre" : "System",
"help" : "",
"name" : "Application Version",
"read_only" : true,
"type" : "String",
"units" : "",
"val" : "2.07",
"data" : {
"last_notification" : {
"code" : 2,
"description" : "NoOperation",
"help" : "Report on NoOperation message sent completion",
"next_wakeup" : null,
"receiveTime" : 1490726629
"multi_instance" : {
"instances" : 1,
"support" : false
