J'ai découvert par hasard qu'il existait deux versions de la multiprise Greenwave, la NP210 et la NP310. Il semblerait qu'il y ait de nouveaux paramètres pour la NP310.
https://community.openhab.org/t/greenwave-np310/6560/2
Pourtant les 2 modèles semblent avoir les mêmes Identifiant du fabricant, Type de produit et Identifiant du produit quand on les inclus dans Jeedom.
Y-a-t-il réellement une différence entre les deux ? Si oui, serait-il possible de l'intégrer ?
Greenwave Power Node NP210 vs NP310
Re: Greenwave Power Node NP210 vs NP310
Voici le retour du fabricant :
The Powernode 6 products were discontinued years ago, and many of the people familiar with the product are no longer with the company, but here’s what we were able to find out for you.
The only difference in the hardware between the NP210-F and the NP310-F is that the NP310-F has a slightly longer power cord and it was certified by GS/TUV.
The firmware between the two would likely vary depending on the date of manufacture, but every version of the firmware had some level of small enhancements and bug fixes which is also the case with the NP310-F because it shipped after the NP210-F.
We also upgraded or introduced a TMOV on the AC side hardware to improve surge protection specifications.
