Jeedom Smart Recovery
Re: Jeedom Smart Recovery
Correction, elle vient d'apparaitre avec la meme IP. Mais ne réponds pas aux ping, ni à une connexion SSH port 21 ou 43, ni via l'interface dashboard ...
Voila le Install.log qui apparait sur la clé usb :
==== PREPARE CARD ====
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 2.92143 s, 11.5 MB/s
/dev/mmcblk0: msdos partitions
Welcome to fdisk (util-linux 2.27.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Device does not contain a recognized partition table.
Created a new DOS disklabel with disk identifier 0x1e8358f4.
Command (m for help): Created a new DOS disklabel with disk identifier 0x105d8d3a.
Command (m for help): The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 5.5239 s, 12.1 MB/s
Command (m for help): Partition type
p primary (0 primary, 0 extended, 4 free)
e extended (container for logical partitions)
Select (default p): Partition number (1-4, default 1): First sector (2048-15269887, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (65536-15269887, default 15269887):
Created a new partition 1 of type 'Linux' and of size 256 MiB.
Command (m for help): Selected partition 1
Partition type (type L to list all types): Changed type of partition 'Linux' to 'W95 FAT32 (LBA)'.
p primary (1 primary, 0 extended, 3 free)
Select (default p): Partition number (2-4, default 2): First sector (2048-15269887, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (589824-15269887, default 15269887):
Created a new partition 2 of type 'Linux' and of size 8 MiB.
p primary (2 primary, 0 extended, 2 free)
Select (default p): Partition number (3,4, default 3): First sector (2048-15269887, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (606208-15269887, default 15269887):
Created a new partition 3 of type 'Linux' and of size 8 MiB.
p primary (3 primary, 0 extended, 1 free)
Select (default e):
Selected partition 4
First sector (2048-15269887, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (622592-15269887, default 15269887):
Created a new partition 4 of type 'Extended' and of size 7 GiB.
Command (m for help): All primary partitions are in use.
Adding logical partition 5
First sector (624640-15269887, default 624640): Last sector, +sectors or +size{K,M,G,T,P} (624640-15269887, default 15269887):
Created a new partition 5 of type 'Linux' and of size 8 MiB.
Adding logical partition 6
First sector (643072-15269887, default 643072): Last sector, +sectors or +size{K,M,G,T,P} (643072-15269887, default 15269887):
Created a new partition 6 of type 'Linux' and of size 256 MiB.
Adding logical partition 7
First sector (1169408-15269887, default 1169408): Last sector, +sectors or +size{K,M,G,T,P} (1169408-15269887, default 15269887):
Created a new partition 7 of type 'Linux' and of size 6.7 GiB.
Syncing disks.
/dev/mmcblk0: msdos partitions 1 2 3 4 <5 6 7>
2048+0 records in
2048+0 records out
1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.095408 s, 11.0 MB/s
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
mkfs.fat 3.0.28 (2015-05-16)
2048+0 records in
2048+0 records out
1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.086034 s, 12.2 MB/s
mke2fs 1.42.13 (17-May-2015)
Discarding device blocks: 4096/1755136 done
Creating filesystem with 1755136 4k blocks and 438912 inodes
Filesystem UUID: eb129bc2-291e-40ea-8fd9-b2349ed9690b
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
Allocating group tables: 0/54 done
Writing inode tables: 0/54 done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: 0/54 done
==== INSTALL BOOT ====
442+0 records in
442+0 records out
442 bytes copied, 0.002335 s, 189 kB/s
96+0 records in
96+0 records out
49152 bytes (49 kB, 48 KiB) copied, 0.004835 s, 10.2 MB/s
1184+0 records in
1184+0 records out
606208 bytes (606 kB, 592 KiB) copied, 0.058697 s, 10.3 MB/s
==== INSTALL JEEDOM ====
mkdir: can't create directory '/mnt1': File exists
mkdir: can't create directory '/mnt2': File exists
umount: can't umount /mnt2: Invalid argument
umount: can't umount /mnt1: Invalid argument
Number of files: 80,612 (reg: 66,759, dir: 9,455, link: 4,392, dev: 6)
Number of created files: 80,610 (reg: 66,759, dir: 9,453, link: 4,392, dev: 6)
Number of deleted files: 0
Number of regular files transferred: 66,746
Total file size: 2,659,320,396 bytes
Total transferred file size: 2,652,751,836 bytes
Literal data: 2,652,751,836 bytes
Matched data: 0 bytes
File list size: 2,096,920
File list generation time: 0.001 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 2,658,187,960
Total bytes received: 1,337,321
sent 2,658,187,960 bytes received 1,337,321 bytes 24,068,102.09 bytes/sec
total size is 2,659,320,396 speedup is 1.00
==== PREPARE JEEDOM BOOT ====
mkdir: can't create directory '/mnt2/media/boot': File exists
==== INSTALL MULTIBOOT SUPPORT ====
mkdir: can't create directory '/mnt2/multiboot': File exists
65536+0 records in
65536+0 records out
Syncing disks.
131072+0 records in
Select (default e):
Syncing disks.
2048+0 records in
2048+0 records out
2048+0 records in
2048+0 records out
442+0 records in
442+0 records out
96+0 records in
96+0 records out
1184+0 records in
1184+0 records out
- Pièces jointes
- install.log
- (5.21 Kio) Téléchargé 40 fois
J'ai exactement le même problème. 2 fois, on m'a répondu de renvoyer la smart à Domadoo, qui m'a renvoyé la smart en ayant "nous avons remplacé l'EMMC"
Il y a une semaine suites à des dépendances qui ne s'installait pas et au refus de jeedom de m'aider j'ai voulu reinstaller la smart et là même problème exactement... elle est repartie chez domadoo.
Je suis dans l'attente
Bon bah j'ai l'impression de me sentir moins seul avec ma Smart en carafe => Pas d’accès Smart jeedom
Surtout quand je vois les dernières ligne de ma tentative se Recovery :
J'ai ouvert un ticket ce matin chez Domadoo, j'attends la réponse. En passant, si je met mon écran de PC sur l'HDMI de la Jeedom, je vois le processus de démarrage de la box et les éventuelles erreurs ?
Jeedom Smart + 6 FGR-223 + 7 capteurs ouvertures Xiaomi + 1 capteur Sensor Xiaomi + Clé Zigate
Bon bah faux départ avec la Jeedom Smart, retour en SAV après 1 mois à tout essayer pour avoir ou reprendre la main sur une box capricieuse. Comme beaucoup c’est certainement un problème du disque interne…
Je n’ai plus qu’a attendre le retour du SAV pour enfin monter tout mes capteurs et actionneurs toujours dans les cartons…
Suite a un recovery de ma Jeedom Smart, j'ai exactement le même probleme que vous :
* Install suivie sur le port hdmi, a priori on passe bien par la copie du .img, des scripts d'install, un écran noir et cela termine au bout de 10mn environ sur le prompt.
* Jeedom est visible sur ma Freebox avec l'adresse habituelle (baux DHCP fixe)
* Aucun réponse de la box depuis le reste du réseau local, ni ping, ni sur le port 80 (pourtant un netstat -a semble dire que le port est bien en écoute sur *)
* Comme vous, le log present sur la clef usb a ses dernières lignes en erreur sur le umount de /mnt1 et/mnt2 (mais je doute que cela soit un reel probleme). A quoi correspondent ces montages, je ne les ai pas dans /
Heureusement, j'ai un ESxi qui a pris le relais...
Vous mentionnez un probleme avec la eMMC, était-ce vraiment cela ?
Le code de Jeedom est bien present dans /var/www/html, mais je ne sais pas si je peux en conclure que le script est allé jusqu'au bout (si il est d'office dans l'img, alors ce serait normal meme en cas d'erreur pendant le shell d'install).
J'ai regardé du coté des iptables et firewall, mais sans succes.
Un peu d'aide serait la bienvenue.
Edit : je précise que j'ai fait ce recovery afin de passer en Debian 9, car j'avais de nombreux problèmes de stabilité (crash de la Smart quasiment toutes les nuits, avec les mêmes symptômes qu’actuellement : plus de ping, ni de serveur httpd, ni ssh, hard reboot obligatoire)
Manu.
Manu.
Jeedom Smart + VM de Dev sur ESXi
RFXCOM / ZWave/ 3 IPX800 / MySensor / IO HomeControl (Connexoon)
Présentation akenad
JeedomSmart Debian Stretch
Odroid-C2 eMMC Armbian Buster Kernel 5
RPi3B+ SSD Raspbian Stretch
RPi4B SSD Raspbian Buster
NUC Intel i7Gen7 ProxMox VM Debian Stretch & Buster
Merci akenad pour cette réponse. J'avais déjà vu ton post fort complet.
En fait, je pense que l'on ne s'est pas bien compris. Le recovery se passe bien, l'image Jeedom est correctement installée, puisqu'au boot suivant j'ai bien juste avant le prompt : Debian GNU/Linux 9 jeedom tty1
Sauf que le réseau n'est pas du tout fonctionnel, du moins en tcp, ou ICMP (le ping).
Les trames UDP semblent passer puisque la Smart se declare sur le routeur.
Mais du coup, pas de ssh ni de http.
Apache et PHP7 démarrent correctement. (wget http://localhost me renvoie bien le index.html de jeedom)
Le install.log sur la clef USB est identique à celui de Woualy posté plus haut.
J'ai essayé plusieurs cables, conf réseau. Mettre l'IP a static dans le fichier interface, etc...
A chaque fois l'IP est correctement postionné si je fais un ifconfig mais aucun ping ne passe (dans aucun des 2 sens)
Comme j'avais déjà des soucis de perte de connectivité avant le recovery, je commence a penser à un probleme hardware. Mais ayant acheté ma Smart dès qu'elle est sortie (chez Domadoo), je ne suis pas sur qu'elle soit toujours sous garantie.
Manu.
Manu.
- fredlamour
- Timide
Bonjour même problème pour moi sur une smart.
J'avais un problème de eMMC avec des erreurs disques. La smart est reparti chez Domadoo qui a fait un remplacement de l'eMMC et a reinstallé Jeedom. J'ai pu faire une restauration de mon backup et la smart a bien marché (à part le Zwave, impossible d'inclure/exclure) jusqu'à aujourd'hui où l'interface ne repondait plus aléatoirement. j'ai rebooté, idem, restauration via mode recovery et là pareil que @neyrou, je reste sur le tty en HDMI.
La box prend une IP mais ne répond pas au ping. Testé un autre routeur et idem.
Le log de restore est presque identique sauf qu'il n'installe pas Jeedom.
J'ai forcé le script d'install mais cela plante puisqu'il n'arrive pas à se connecter au net pour télécharger.
Je fais rappeler Domadoo demain mais si quelqu'un a une idée ...
PS : pour le ticket, faut etre patient. Celui pour mes erreurs disques a été répondu après 17 jours ... la box avait eu le temps de partir et revenir de chez domadoo et la réponse dans le ticket était complétement à côté de la plaque .(vider le cache et faire un reboot , après reboot de toute facon le compteur d'erreur disque est remis à zero)..
J'ai exactement le même problème depuis que je suis passé sur debian 9 (car le plugin bluetooth ne fonctionnait plus) une solution a t'elle été trouvée?neyrou a écrit : ↑31 janv. 2019, 12:23Merci akenad pour cette réponse. J'avais déjà vu ton post fort complet.
Manu.
