nouvelle smart MAJ impossible
Je viens de brancher ma nouvelle Smart, il est en version 3.1.3 et impossible de le mettre à jour même en "forcé"
il m'indique opération échoué
il faut faire autre chose ?
Re: nouvelle smart MAJ impossible
Hello
On peut peut être avoir un log ?
Si pas, comme tu as une Smart tu as accès au support chez Jeedom SAS !
K
Clean old backup...OK
Limit the total size of backups to 500 Mo...
Remove : /var/www/html/core/php/../../backup/backup-Maison-3.1.3-2019-03-13-18h04.tar.gz
OK
Name of backup : /var/www/html/core/php/../../backup/backup-Maison-3.1.3-2019-03-13-19h10.tar.gz
Send end backup event...OK
Backup duration : 26s
***************Fin de la sauvegarde de Jeedom***************
[END BACKUP SUCCESS]
Disable all task
. OK
Disable all scenario OK
Clean temporary file (tmp)...OK
Download url : https://github.com/jeedom/core/archive/stable.zip
Download in progress...converted 'https://github.com/jeedom/core/archive/stable.zip' (ANSI_X3.4-1968) -> 'https://github.com/jeedom/core/archive/stable.zip' (UTF-8)
--2019-03-13 18:10:51-- https://github.com/jeedom/core/archive/stable.zip
Resolving github.com (github.com)... 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443... connected.
HTTP request sent, awaiting response...
302 Found
Location: https://codeload.github.com/jeedom/core/zip/stable [following]
converted 'https://codeload.github.com/jeedom/core/zip/stable' (ANSI_X3.4-1968) -> 'https://codeload.github.com/jeedom/core/zip/stable' (UTF-8)
--2019-03-13 18:10:52-- https://codeload.github.com/jeedom/core/zip/stable
Resolving codeload.github.com (codeload.github.com)... 192.30.253.120, 192.30.253.121
Connecting to codeload.github.com (codeload.github.com)|192.30.253.120|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2019-03-13 18:10:53 ERROR 404: Not Found.
Enable scenario : OK
Enable task : OK
Error during install : Download failed please retry laterDetails : Array
[END UPDATE ERROR]
PHP Fatal error: Uncaught exception 'Exception' with message 'Download failed please retry later' in /var/www/html/install/install.php:160
Stack trace:
#0 {main}
thrown in /var/www/html/install/install.php on line 160
OK
Disable all task
. OK
302 Found
Enable task : OK
[END UPDATE ERROR]
Stack trace:
#0 {main}
Ca ne télécharge meme pas... puisque pas trouvé
Par contre tu sembles etre en version 3.1.3 alors qu'avant la nouvelle version 3.3.x la dernière version était 3.2.16 ...
Attends un peu,, il y a peu être un souci coté dispo si trop de monde ou si une nouvelle version est poussée par Loic et retente vers 20h00
Si toujours cette erreur appelle le support
j'ai essayé de mettre à jour plusieurs fois mais impossible.(hier et aujourd'hui
[2019-03-16 12:06:46][ALERT] : Echec lors du téléchargement du fichier. Veuillez réessayer plus tard (taille inférieure à 100 octets). Cela peut être lié à un manque de place, une version minimale requise non consistente avec votre version de Jeedom, un soucis du plugin sur le market etc...
santé: espace dispo 57% , mémoire dispo 82%
jeedom, openzwave, script et widget impossible
Même problème de la 3.1.3 vers 3.3.x
Jeedom sur Rasp. Pi 2 B + RaZberry
Modules Z-Waves
D.I.Y Modules Wifi (Arduino)
Jeedom APP BETA TESTEUR
Modules Z-Waves
Je viens de mettre à jour ma box, tout s'est bien passé sauf que maintenant je n'ai accès à plus rien "502 Bad Gateway"...
J'aurai mieux fait de rien mettre à jour.
J'ai corrigé le soucis de 3.1.X vers la 3.3.X ce matin vous ne devriez plus le rencontrer.
En ssh il faut faire :
php /var/www/html/install/update.php
Depuis environ le début de l’année la Jeedomsmart, ainsi que son image de recovery mode, sont pré-installés en Stretch avec Jeedom 3.1.x.
Tandis que dans le même intervalle les installations manuelles DIY de Jeedom se faisaient en 3.2.x.
Pour l’instant les mises à jours 3.1.x vers 3.3.x ou 3.2.x vers 3.3.x ont un résultat différent.
akenad
akenad
Présentation akenad
JeedomSmart Debian Stretch
Odroid-C2 eMMC Armbian Buster Kernel 5
RPi3B+ SSD Raspbian Stretch
RPi4B SSD Raspbian Buster
NUC Intel i7Gen7 ProxMox VM Debian Stretch & Buster
Mais fonctionne en local , et la remise upadte.php fonctionne ! merci bien Loïc
Si tu parles des dans jeedom il n'autorise que le HTTPS pas le ssh
Je viens de lancer une backup via la procédure sur la doc.
Sa fait 1h que j'ai lancé la resto avec une clé USB et toujours pas accès via l'IP en local, pareil avec SSH via Putty
Que dois-je faire à ce niveau?
Problème résolu grâce à un peu d'acharnement et putty
AngeloLeb a écrit : ↑
18 mars 2019, 18:58
Par contre toujours pas d’accès en ssh
Réponse faisant suite à Angelo
Y aura t'il une bonne âme pour expliquer la subtilité ?
Débutant Jeedom.
VirtualBox 6.0.10 sur Tablette I Works 12 sous Win 10 - Debian 9.9
Jeedom 3.3.36 - Contrôleur Aeotec ZW 090 C
Modules Fibaro FGR-222
Bonjour @Patdec,
Dans le contexte, ce sont tous deux des protocoles sécurisés mais HTTPS permet l'accès à l'IHM de l'application web Jeedom (via un navigateur) alors que ssh permet l'accès à un terminal distant au système sous-jacent pour y exécuter des commandes (via l'utilitaire putty sous windows par exemple).
Il est toutefois possible d'envoyer des commandes au système via l'IHM Jeedom
roue crantée -> Configuration -> Onglet OS/DB -> Système -> Administration
akenad
Présentation akenad
Merci Akenad pour ton explicatif.akenad a écrit : ↑21 mars 2019, 20:00
akenad
J'entrevois et comprend je pense les différences. J'aurai bien d'autres questions mais ici, c'est pas le sujet. No pollution.
Par contre un p'tit détail que j'avais déjà remarqué dans cet onglet
" Cliquez sur une commande à droite ou tapez une commande personnalisée ci-dessous "
J'aurai plutôt mis à gauche. Mais sur Github je sais pas encore proposer.
Débutant Jeedom.
