[RFLink] Dépendance NOK [Résolu]
verdi21
Message par verdi21 » 02 févr. 2019, 23:01
Je viens d'installer un RFLink (Fw R48) sur mon Raspberry Pi 3 (update des packages récent) + Jeedom (3.2.15).
J'installe le plugin jeedom et lance les dépendances. Malheureusement, en moins de 1min, KO. Voici les erreurs:
Début de l'installation
--2019-02-02 22:51:26--  https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
Length: 1489 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
     0K .                                                     100% 15.4M=0s
2019-02-02 22:51:26 (15.4 MB/s) - 'dependencies.sh' saved [1489/1489]
dependencies.sh: 3: [: rflink: unexpected operator
Version actuelle : 8
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Get:3 https://deb.nodesource.com/node_6.x stretch InRelease [4635 B]
Fetched 30.0 kB in 1s (19.9 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (9.20161125+rpi1).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Ok, version suffisante
(node:2752) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
npm WARN package.json JeedomRflink@0.0.1 No README data
npm ERR! Error: Method Not Allowed
npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
npm ERR! If you need help, you may report this *entire* log,
npm ERR! including the npm and node versions, at:
npm ERR!     <http://github.com/npm/npm/issues>
npm ERR! System Linux 4.14.79-v7+
npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
npm ERR! cwd /var/www/html/plugins/rflink/resources
npm ERR! node -v v8.11.1
npm ERR! npm -v 1.4.21
npm ERR! code E405
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR!     /var/www/html/plugins/rflink/resources/npm-debug.log
npm ERR! not ok code 0
Fin de l'installation
Je n'ai pas réussi à trouver un problème similaire dans le forum ou sur google.
Avez-vous une idée ?
Merci pour votre aide !
Fabrice
Modérateur
Re: [RFLink] Dépendance NOK
Message par Fabrice » 03 févr. 2019, 11:14
Tentez de mettre à jour npm avant l'installation de vos dépendances, en ssh faites :
sudo apt-get update && sudo apt-get upgrade
sudo npm install -g npm
Chez moi, je vois que j'ai la version 6.4.1 de node.
- Jeedom : 3.3.36
verdi21
Message par verdi21 » 03 févr. 2019, 18:53
C'était bien cela. Merci beaucoup !
tonejay
Message par tonejay » 07 févr. 2019, 18:21
J'ai le meme soucis mais cette commande me renvoie
sudo: npm : commande introuvable
Voici les logs :
--2019-02-07 18:20:06--  https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Résolution de raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.60.133
Connexion à raw.githubusercontent.com (raw.githubusercontent.com)|151.101.60.133|:443… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 1489 (1,5K) [text/plain]
Sauvegarde en : « dependencies.sh »
0K .                                                     100% 17,5M=0s
2019-02-07 18:20:07 (17,5 MB/s) — « dependencies.sh » sauvegardé [1489/1489]
Atteint:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Atteint:2 http://archive.raspberrypi.org/debian stretch InRelease
E: Impossible d'obtenir le verrou /var/lib/dpkg/lock - open (11: Ressource temporairement non disponible)
E: Impossible de verrouiller le répertoire d'administration (/var/lib/dpkg/). Il est possible qu'un autre processus l'utilise.
dependencies.sh: 59: dependencies.sh: npm: not found
chown: impossible d'accéder à 'node_modules': Aucun fichier ou dossier de ce type
MonRFLINK à été testé avec RFLINKLoader, tout est OK
Fabrice
Modérateur
Message par Fabrice » 07 févr. 2019, 18:45
Non ce n'est pas le même soucis.
- vous, il vous manque le mot bonjour dans les dépendances 🤔
- Jeedom : 3.3.36
tonejay
Message par tonejay » 07 févr. 2019, 18:48
Effectivement, désolé...
Fabrice
Modérateur
Message par Fabrice » 07 févr. 2019, 20:41
Testez un redémarrage et l'installation des dépendances ensuite.
- Il semble que cela soit un processus de mise à jour qui créer cela.
Ou alors, elles sont en cours d'installation sur un autre plugin.
- Jeedom : 3.3.36
tonejay
Message par tonejay » 07 févr. 2019, 20:54
J'ai redémarré et tenté de relancer l'istall...et toujours NOK...
--2019-02-07 20:52:44--  https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
0K .                                                     100% 19.5M=0s
2019-02-07 20:52:45 (19.5 MB/s) - 'dependencies.sh' saved [1489/1489]
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
chown: cannot access 'node_modules': No such file or directory
Fabrice
Modérateur
Message par Fabrice » 07 févr. 2019, 21:39
En ssh faire
sudo apt-get install nodejs npm
- Jeedom : 3.3.36
tonejay
Message par tonejay » 08 févr. 2019, 18:24
En ssh faire
Toujours pas...
Mais j'ai une autre erreur cette fois.
--2019-02-08 18:20:03--  https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Résolution de raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.120.133
Connexion à raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443… connecté.
0K .                                                     100% 16,3M=0s
2019-02-08 18:20:03 (16,3 MB/s) — « dependencies.sh » sauvegardé [1489/1489]
0 mis à jour, 0 nouvellement installés, 0 à enlever et 3 non mis à jour.
(node:13616) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
npm ERR! code E405
npm ERR!
Fabrice
Modérateur
Message par Fabrice » 09 févr. 2019, 17:25
Testez cela en ssh :
- Jeedom : 3.3.36
tonejay
Message par tonejay » 10 févr. 2019, 10:36
Super !! dépendance lancée !! Merci !
En revanche je ne vois toujours pas mon RFLINK
Apparemment le firmware est reconnu, Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48 mais que faire ensuite ?
Je tente de lancer le mode inclusion et de tester avec une telecommande, mais rien ne se passe ...
Fabrice
Modérateur
Message par Fabrice » 10 févr. 2019, 10:38
Ca, je ne sais pas vous renseigner là dessus, je n'ai pas cet appareil ni ce plugin.
- Jeedom : 3.3.36
tonejay
Message par tonejay » 10 févr. 2019, 11:23
ok, je vais poster ailleur .. merci! !
Oefut
Message par Oefut » 19 juil. 2019, 20:05
J'ai suivi tout ce que vous avez donné comme solution et ça avance, mais je n'ai pas de Rflink reconnu alors qu'il l'est sur un autre PI.
Voudriez-vous m'aider SVP?
Débutant ++ Jeedom
Box: Zibase - Jeedom sur PPI3 - RFXCOM433
Plugins Utilisés: Email - Network - Phone Market - Pushbullet - Script - Météo - Widget - Zibasedom - Caméra - RTSP
