A très bientôt !
[Plugin Tiers][Sujet Principal] MyHOME Zigbee legrand
Greg0307
Re: [Plugin Tiers][Sujet Principal] MyHOME Zigbee legrand
Message par Greg0307 » 29 oct. 2017, 14:17
J'ai toujours le souci sur mon variateur.
Retour d'état incéssant et valeur de variation toujours à 1.
Un peu d'aide pls.
Greg0307 a écrit :
23 mai 2017, 06:44
Pardon voici
2017-05-23 06:42:31][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *1*1*767031301#9## [format] => BUS_COMMAND [mode] => UNICAST [media] => ZIGBEE [type] => light [value] => ON [dimension] => [param] => [id] => 00750A29 [unit] => 01 [date] => 2017-05-23 06:42:31 )
[2017-05-23 06:42:31][DEBUG] : Jeemyhome_BUS_COMMAND
[2017-05-23 06:42:31][DEBUG] : Update Status Light
[2017-05-23 06:42:31][DEBUG] : statusid : statusnum01 date : 1495514551 family : DIMMER
[2017-05-23 06:42:31][DEBUG] : family type = DIMMER, Check Light Status
[2017-05-23 06:42:31][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#*1## [format] => ACK [mode] => UNKNOWN [media] => ZIGBEE [type] => scene [value] => [dimension] => [param] => [id] => [unit] => [date] => 2017-05-23 06:42:31 )
[2017-05-23 06:42:31][DEBUG] : Jeemyhome_Trame non interprÃtÃe
[2017-05-23 06:42:31][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *1*1*767031301#9## [format] => BUS_COMMAND [mode] => UNICAST [media] => ZIGBEE [type] => light [value] => ON [dimension] => [param] => [id] => 00750A29 [unit] => 01 [date] => 2017-05-23 06:42:31 )
[2017-05-23 06:42:35][DEBUG] : Send trame
[2017-05-23 06:42:35][DEBUG] : mise a jour du status : 1
[2017-05-23 06:42:35][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#1*767031301#9## [format] => STATUS_REQUEST [mode] => UNICAST [media] => ZIGBEE [type] => light [value] => [dimension] => [param] => [id] => 00750A29 [unit] => 01 [date] => 2017-05-23 06:42:35 )
[2017-05-23 06:42:35][DEBUG] : Jeemyhome_STATUS_REQUEST, Aucun action effectuÃe
Envoyé de mon iPad en utilisant Tapatalk
Didier3L
Message par Didier3L » 29 oct. 2017, 14:40
les Logs de mai 2017, c'est une blague ...
Synology DS216+ / DSM 6.2 / Docker / MariaDB 5
Conteneur : jeedom/Jeedom:master en mode réseau Host - Version Jeedom V3.3
Protocole : MyHOME Play Zigbee/ Xiaomi Aqara / HomeBridge / BLEA
Mon matériel | Tuto MyHOME en Vidéo | Documentation
Greg0307
Message par Greg0307 » 29 oct. 2017, 16:25
Didier3L a écrit :les Logs de mai 2017, c'est une blague ...
Non mais parce que j'ai pas eu de réponse et toujours le mm pb
Greg0307
Message par Greg0307 » 29 oct. 2017, 16:27
Les derniers:
[2017-10-29 16:26:29][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *1*1*767031301#9## [format] => BUS_COMMAND [mode] => UNICAST [media] => ZIGBEE [type] => light [value] => ON [dimension] => [param] => [id] => 00750A29 [unit] => 01 [date] => 2017-10-29 16:26:29 )
[2017-10-29 16:26:29][DEBUG] : Jeemyhome_BUS_COMMAND
[2017-10-29 16:26:29][DEBUG] : Update Status Light
[2017-10-29 16:26:29][DEBUG] : statusid : statusnum01 date : 1509290789 family : DIMMER
[2017-10-29 16:26:29][DEBUG] : family type = DIMMER, Check Light Status
[2017-10-29 16:26:33][DEBUG] : Send trame
[2017-10-29 16:26:33][DEBUG] : mise a jour du status : 1
[2017-10-29 16:26:33][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *#1*767031301#9## [format] => STATUS_REQUEST [mode] => UNICAST [media] => ZIGBEE [type] => light [value] => [dimension] => [param] => [id] => 00750A29 [unit] => 01 [date] => 2017-10-29 16:26:33 )
[2017-10-29 16:26:33][DEBUG] : Jeemyhome_STATUS_REQUEST, Aucun action effectuée
[2017-10-29 16:26:33][DEBUG] : Jeemyhome_Equipement : Array ( [trame] => *1*1*767031301#9## [format] => BUS_COMMAND [mode] => UNICAST [media] => ZIGBEE [type] => light [value] => ON [dimension] => [param] => [id] => 00750A29 [unit] => 01 [date] => 2017-10-29 16:26:33 )
[2017-10-29 16:26:33][DEBUG] : Jeemyhome_BUS_COMMAND
[2017-10-29 16:26:33][DEBUG] : Update Status Light
[2017-10-29 16:26:33][DEBUG] : statusid : statusnum01 date : 1509290793 family : DIMMER
[2017-10-29 16:26:33][DEBUG] : family type = DIMMER, Check Light Status
[2017-10-29 16:26:37][DEBUG] : Send trame
[2017-10-29 16:26:37][DEBUG] : mise a jour du status : 1
Didier3L
Message par Didier3L » 29 oct. 2017, 18:27
On dirait le vieux problème de interrogation sans cesse d'un équipement. :?
Pourtant, Apages avait mis à jour le plugin
viewtopic.php?f=133&t=9233&start=580#p469871
On va voir ce que dis le patron du plugin
Greg0307
Message par Greg0307 » 30 oct. 2017, 06:49
Didier3L a écrit :On dirait le vieux problème de interrogation sans cesse d'un équipement. :?
Bonjour oui,
Mon problème n'est pas résolu depuis, par manque de temps j'avais un peu abandonné le sujet.
alx68
Message par alx68 » 30 oct. 2017, 07:34
Tu as essayé de couper le courant sur ton Var et attendre deux minutes et remettre le jus?.
Envoyé de mon TREKKER-X3 en utilisant Tapatalk
raspberry pi 2 V3.1.7 iobl: Inter 67202-scenario 67208-variateur 67214-variateur 67215-volet 67251-67253-67256-scenario 67280-Telecommande 88200-scenario modulaire 03612.MyHomeplay 67227 et 3578
Greg0307
Message par Greg0307 » 30 oct. 2017, 18:25
alx68 a écrit :Salut
Peut être que j'ai pas attendu assez, je test
Greg0307
Message par Greg0307 » 30 oct. 2017, 18:44
Non toujours pareil, malgré suppression de l'équipement' reinitialisation, nouvelle intégration dans le réseau.
alx68
Message par alx68 » 30 oct. 2017, 20:10
Tu penses pas que ton équipement peut avoir un problème est t'il toujours sous garantie
Greg0307
Message par Greg0307 » 30 oct. 2017, 20:37
alx68 a écrit :Tu penses pas que ton équipement peut avoir un problème est t'il toujours sous garantie
Je ne sais pas, ça n'a pas grande importance je peux le gérer juste le retour de la variation qui ne fonctionne pas.
J'ai eu le soucis sur un récepteur éclairage il y a peu, peut être quelques soucis de fiabilité.
Si apages a du temps pour vérifier que cela ne vient pas du plugin, je regarderais avec le logiciel Legrand sur Windows a l'occasion voir si le retour est bon.
alx68
Message par alx68 » 30 oct. 2017, 20:49
C' est quel ref car j'en possède un aussi et chez moi il fonctionne bien.
Greg0307
Message par Greg0307 » 30 oct. 2017, 21:15
Le 67227
alx68
Message par alx68 » 30 oct. 2017, 21:19
C'est le même produit que toi et au début j'avais le même problème sur le retour d'état de la partie dimmer tes templates sont à jour sur le plugin jeehome.
maxpuissant
Message par maxpuissant » 31 oct. 2017, 13:50
Didier3L a écrit :
21 juil. 2017, 17:53
Quand la clé est intégrée dans le réseau elle clignote très légèrement de temps en temps.
je t'invite à ré-initialiser la clé USB
1 - tu appuies sur le bouton de la clé
2 - quand la LED est orange, tu appuies, en permanence, sur le bouton de la clé jusqu' à que la LED clignote rapidement et s’éteigne.
ensuite tu suis cette procédure : viewtopic.php?f=133&t=9233&start=40#p337441
Merci pour votre retour.
J'ai trouvé un peu de temps pour m'en occuper et je n'ai toujours pas réussi à créeer le réseau zigbee avec cette méthode... En revanche, j'y suis parvenu avec le logiciel bticino et la clé bticino connectée au PC. Dans ce programme, il ya des boutons créer réseau, rejoindre etc... Après ça, l'inclusion dans jeedom était un jeu d'enfant :-) Si ça peut aider certains.
Greg0307
Message par Greg0307 » 31 oct. 2017, 17:45
alx68 a écrit :C'est le même produit que toi et au début j'avais le même problème sur le retour d'état de la partie dimmer tes templates sont à jour sur le plugin jeehome.
Oui je l'Ain indiqué plus haut.
Didier3L
Message par Didier3L » 01 nov. 2017, 14:08
Greg0307 a écrit :
31 oct. 2017, 17:45
Quelle est la version de ton template ?
apages
Message par apages » 03 nov. 2017, 21:57
@greg0307,
Effectivement ca ressemble a un vieux bug qui existait sur les Dimmer.
quelle version du plugin as-tu ?
pourrais-tu supprimer ton module, aller dans gestion du plugin/myhome,cliquer sur update template module, puis recreer le module avec le template 67227 (v1.4 normalement)
Si tu as encore le soucis, il faudrait que tu m'envoi en MP les fichiers : /var/www/html/plugins/myhome/core/class/myhome.class.php et /var/www/html/plugins/myhome/core/config/devices/67227.json
EDIT : si tu peux m'envoyer aussi tes logs de myhomecmd.message
Bye
raspberry pi3 et raspberry pi JEEDOM V3.1.3 avec module Legrand USB-CPL et RFXCOM433
Legrand : 10 inter VR avec derogation : 67255, 1 inter VR sans derogation : 67251,1 Selecteur Programmable CPL : 67449, 3 Sortie de cable CPL : 67445
ecc
Message par ecc » 20 nov. 2017, 17:52
Bonjour, une petite question, le statut des volets est complètement erroné, j'ai du closed quand le volet est ouvert, ou encore une valeur.
Ai je loupé quelque chose dans la configuration ?
est'il possible de commander le volet pour une ouverture partielle ?
Pièces jointes
apages
Message par apages » 20 nov. 2017, 18:22
Quelle template utilises-tu?
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 7 invités
