ça?lunarok a écrit :non, ca c'est les logs _node
Début de l'installtion
Reading package lists...
Building dependency tree...
Reading state information...
build-essential is already the newest version.
The following extra packages will be installed:
libelf1 libftdi1
Suggested packages:
avrdude-doc
avrdude libelf1 libftdi1
0 upgraded, 3 newly installed, 0 to remove and 103 not upgraded.
Need to get 613 kB of archives.
After this operation, 2083 kB of additional disk space will be used.
Get:1 http://apt.adafruit.com/raspbian/ wheezy/main avrdude armhf 6.1-3 [294 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libftdi1 armhf 0.20-1 [19.0 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libelf1 armhf 0.152-1+wheezy1 [300 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 613 kB in 1s (322 kB/s)
Selecting previously unselected package libftdi1:armhf.
(Reading database ... 89128 files and directories currently installed.)
Unpacking libftdi1:armhf (from .../libftdi1_0.20-1_armhf.deb) ...
Selecting previously unselected package libelf1.
Unpacking libelf1 (from .../libelf1_0.152-1+wheezy1_armhf.deb) ...
Selecting previously unselected package avrdude.
Unpacking avrdude (from .../avrdude_6.1-3_armhf.deb) ...
Processing triggers for man-db ...
Setting up libftdi1:armhf (0.20-1) ...
Setting up libelf1 (0.152-1+wheezy1) ...
Setting up avrdude (6.1-3) ...
mkdir: cannot create directory `/var/www': File exists
> serialport@2.0.6 install /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport
> node-pre-gyp install --fallback-to-build
child_process: customFds option is deprecated, use stdio instead.
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
COPY Release/serialport.node
COPY /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build/Release/node-v14-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
serialport@2.0.6 node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── debug@2.2.0 (ms@0.7.1)
├── nan@2.0.9
└── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
request@2.69.0 node_modules/request
├── is-typedarray@1.0.0
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.5
├── tunnel-agent@0.4.2
├── oauth-sign@0.8.1
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.7
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── qs@6.0.2
├── aws4@1.2.1 (lru-cache@2.7.3)
├── tough-cookie@2.2.1
├── mime-types@2.1.9 (mime-db@1.21.0)
├── form-data@1.0.0-rc3 (async@1.5.2)
├── bl@1.0.1 (readable-stream@2.0.5)
├── har-validator@2.0.6 (pinkie-promise@2.0.0, chalk@1.1.1, commander@2.9.0, is-my-json-valid@2.12.4)
├── hawk@3.1.3 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
└── http-signature@1.1.1 (assert-plus@0.2.0, jsprim@1.2.2, sshpk@1.7.3)
Fin de l'installtion
