[Plugin Tiers][Sujet Principal] Rflink : passerelle RF433 multi-protocoles
tijo
Re: [Sujet officiel] Rflink : passerelle RF433 multi-protoco
Message par tijo » 14 nov. 2015, 22:05
dépendances OK
log rflink :
module.js:340
throw err;
Error: Cannot find module 'tough-cookie'
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/request/lib/cookies.js:3:13)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
14-11-2015 16:00:30 | error | Impossible de lancer le démon rflink, vérifiez le port
14-11-2015 16:45:11 | error | Erreur sur la fonction cron15 du plugin : Le port : n'existe pas
log rflink_dep :
Début de l'installtion
Reading package lists...
Building dependency tree...
Reading state information...
avrdude is already the newest version.
build-essential is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
mkdir: cannot create directory '/var/www': File exists
> serialport@2.0.5 install /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport
> node-pre-gyp install --fallback-to-build
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
COPY Release/serialport.node
COPY /usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/rflink/node/node_modules/serialport/build'
serialport@2.0.5 node_modules/serialport
├── bindings@1.2.1
├── sf@0.1.7
├── async@0.9.0
├── nan@2.0.9
├── debug@2.2.0 (ms@0.7.1)
└── optimist@0.6.1 (wordwrap@0.0.3, minimist@0.0.10)
request@2.65.0 node_modules/request
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.5
├── oauth-sign@0.8.0
├── tunnel-agent@0.4.1
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.7
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── qs@5.2.0
├── mime-types@2.1.7 (mime-db@1.19.0)
├── tough-cookie@2.2.1
├── form-data@1.0.0-rc3 (async@1.5.0)
├── http-signature@0.11.0 (assert-plus@0.1.5, asn1@0.1.11, ctype@0.5.3)
├── bl@1.0.0 (readable-stream@2.0.4)
├── hawk@3.1.1 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
└── har-validator@2.0.2 (pinkie-promise@1.0.0, commander@2.9.0, chalk@1.1.1, is-my-json-valid@2.12.3)
Fin de l'installation
quand je relance c'est pareil
tijo
Message par tijo » 14 nov. 2015, 22:06
a priori, c'est devenu bon... tout est OK
breizh22
Message par breizh22 » 15 nov. 2015, 16:31
j'ai acheté des prises DIO 54798 avec une télécommande 54760. J'arrive à voir les commandes dans RFLink mais impossible à les faire fonctionner ensuite. Je précise qu'elles fonctionnent bien avec la télécommande. Lorsque j'appuie sur une commande, les leds de l'arduino mega s'allument bien pourtant. Une personne a t'elle ce modèle de prises, si oui, y a t'il une astuce ?. Mon Rflink fonctionne bien avec d'autres prises Chacon et Dedra plus vieilles. Merci
HP Gen 8 / OMV4 sur SSD / Jeedom 3.3.37 VM Debian 9
RFLink - Sondes Oregon THN 132 N / THGR 122 NX / THGR 810 / THC238 - Prises DIO/Dedra/IDK.
Orvibo AllOne et S20 - Onduleur APC Back-UPS ES 700VA
Écosystème xiaomi - Dash buttons - GHome et mini.
lunarok
Message par lunarok » 15 nov. 2015, 16:34
Tu as quoi dans les logs ?
Mon Blog | Xiaomi Home
breizh22
Message par breizh22 » 15 nov. 2015, 16:51
J'ai ceci dans le log
15-11-2015 16:44:48 | debug | 127.0.0.1
15-11-2015 16:44:48 | info | 10,NewKaku,012b780e,1,ON,
15-11-2015 16:44:48 | debug | Protocole CMD UNKNOWN ID
15-11-2015 16:44:49 | debug | 127.0.0.1
15-11-2015 16:44:49 | info | 10,NewKaku,012b780e,1,OFF,
15-11-2015 16:44:49 | debug | Protocole CMD UNKNOWN ID
un autre qui fonctionne
15-11-2015 16:52:50 | debug | 127.0.0.1
15-11-2015 16:52:50 | info | 10,Kaku,00004c,1,ON,
lunarok
Message par lunarok » 15 nov. 2015, 17:14
Non le log quand tu reçois les commandes de la telco
Envoyé de mon A0001 en utilisant Tapatalk
breizh22
Message par breizh22 » 15 nov. 2015, 17:32
15-11-2015 17:28:23 | debug | Protocole NewKaku ID 012b780e
lunarok
Message par lunarok » 15 nov. 2015, 18:08
Tu as la ligne du dessus ou dessous ?
breizh22
Message par breizh22 » 15 nov. 2015, 18:19
Je suis désolé, je n'ai que cela lorsque j'appuie sur la télécommande, j'ai appuyé sur on et off de la commande 1 et 2. Je devrai avoir quoi comme info , Merci du temps passé.
15-11-2015 18:12:30 | debug | Protocole NewKaku ID 012b780e
15-11-2015 18:12:31 | debug | Protocole NewKaku ID 012b780e
15-11-2015 18:12:32 | debug | Protocole NewKaku ID 012b780e
lunarok
Message par lunarok » 15 nov. 2015, 19:20
Tu devrais avoir la ligne de sortie du port série.
Sinon un screen avec tes commandes infos créées stp
breizh22
Message par breizh22 » 15 nov. 2015, 20:14
J'ai tout effacé et recommencé l'étape, voici
15-11-2015 20:11:39 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:39 | debug | Commande non existante, création SWITCH1:ON sur NewKaku_012b780e
15-11-2015 20:11:40 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:40 | debug | Commande non existante, création SWITCH1:OFF sur NewKaku_012b780e
15-11-2015 20:11:45 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:45 | debug | Commande non existante, création SWITCH2:OFF sur NewKaku_012b780e
15-11-2015 20:11:48 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:48 | debug | Commande non existante, création SWITCH3:ON sur NewKaku_012b780e
15-11-2015 20:11:50 | debug | Protocole NewKaku ID 012b780e
15-11-2015 20:11:50 | debug | Commande non existante, création SWITCH3:OFF sur NewKaku_012b780e
Je n'ai que cela dans le log RFLink
lunarok
Message par lunarok » 15 nov. 2015, 20:33
Tu as le log rflink_daemon ? Et un screen avec les commandes créées
breizh22
Message par breizh22 » 15 nov. 2015, 20:53
je n'ai pas rflink_daemon. J'ai rflink_flash, rflink et rflink_dep en log.
Pièces jointes
breizh22
Message par breizh22 » 15 nov. 2015, 22:15
j'ai cela dans le log rflink avec appuie sur la télécommande. mais cela ne fonctionne pas, je dois louper un truc, mais quoi !!! mdr
15-11-2015 22:27:17 | debug | 20;51;NewKaku;ID=012b780e;SWITCH=1;CMD=ON;
15-11-2015 22:27:17 | info | Send Value : 20;51;NewKaku;ID=012b780e;SWITCH=1;CMD=ON;
15-11-2015 22:27:17 | debug | Protocole NewKaku ID 012b780e
15-11-2015 22:27:17 | debug | Got response Value: 200
15-11-2015 22:27:18 | debug | 20;52;NewKaku;ID=012b780e;SWITCH=1;CMD=OFF;
15-11-2015 22:27:18 | info | Send Value : 20;52;NewKaku;ID=012b780e;SWITCH=1;CMD=OFF;
15-11-2015 22:27:18 | debug | Protocole NewKaku ID 012b780e
15-11-2015 22:27:18 | debug | Got response Value: 200
lunarok
Message par lunarok » 15 nov. 2015, 22:52
Je comprend plus, là t'as bien des logs normaux alors qu'avant t'as juste une des lignes sur 4 ?
Ta capture de l'équipement il y a quelque chose de pas normal dans les infos aussi, il n'y a pas la valeur
Là si tu testes une de tes commandes tu as toujours l'ID de CMD inconnu ?
breizh22
Message par breizh22 » 16 nov. 2015, 05:49
Oui, je ne comprends pas non plus.
16-11-2015 05:47:51 | debug | 127.0.0.1
16-11-2015 05:47:51 | info | 10,NewKaku,012b780e,1,ON,
16-11-2015 05:47:51 | debug | server connected
16-11-2015 05:47:51 | info | Response: 10;NewKaku;012b780e;1;ON;
16-11-2015 05:47:51 | debug | server disconnected
16-11-2015 05:47:51 | debug | 20;8A;CMD UNKNOWN;
16-11-2015 05:47:51 | info | Send Value : 20;8A;CMD UNKNOWN;
16-11-2015 05:47:51 | debug | Protocole CMD UNKNOWN ID
16-11-2015 05:47:51 | debug | Got response Value: 200
rosty
Message par rosty » 16 nov. 2015, 08:17
Excellent, le RFXcom by @Lunarok, belle initiative qui va réjouir tout ceux qui veulent s'équiper du 433Mhz à moindre coût :) succès garantie ;)
Envoyé de mon MI PAD en utilisant Tapatalk
lunarok
Message par lunarok » 16 nov. 2015, 14:41
@breizh22 : donc c'est bien la bonne trame qui est envoyée et recue par la gateway, mais elle en veut pas
Tu peux essayer en mettant un 0 devant le 1 par exemple ? (j'ai vu le cas, où l'info recu faisait l'inverse, on voiyait SWITCH=02;CMD=OFF mais il fallait pas envoyer 02;OFF, mais 2;OFF
kriss35
Message par kriss35 » 16 nov. 2015, 15:24
@breizh22 : il y a la version 34 que la stunteam a sortie il y a quelques jours, est-ce que c'est cette version que tu as ?
lunarok
Message par lunarok » 16 nov. 2015, 15:44
Et la version est visible sur la page santé ca me fait penser (pour ceux qui sauraient pas où la voir)
