Quelqu'un ici peux m'aider ou il faut que j'ouvre un ticket sur Github ?
Pour info c'est sur une jeedom mini+
Voici le log debug après un redémarrage complet:
[2019-03-08 18:14:53][DEBUG] : result callZiGate Array ( [result] => 0.28.4 [success] => 1 )
[2019-03-08 17:18:52][DEBUG][zigate](Thread-3) : Auto saving /var/www/html/plugins/zigate/core/class/../../resources/zigated/zigate.json
[2019-03-08 17:18:52][DEBUG][zigate](Thread-3) : Saving persistent file
[2019-03-08 17:18:52][DEBUG][zigate](Thread-3) : File already existing, make a backup before
[2019-03-08 17:23:53][DEBUG][zigate](Thread-6) : Auto saving /var/www/html/plugins/zigate/core/class/../../resources/zigated/zigate.json
[2019-03-08 17:23:53][DEBUG][zigate](Thread-6) : Saving persistent file
[2019-03-08 17:23:53][DEBUG][zigate](Thread-6) : File already existing, make a backup before
[2019-03-08 18:27:29][DEBUG] : callZiGate get_version_text
[2019-03-08 17:27:29][DEBUG][root](Thread-5) : Message received in socket
[2019-03-08 17:27:29][DEBUG][root](Thread-5) : {'args': '', 'action': 'get_version_text'}
[2019-03-08 17:27:29][DEBUG][root](Thread-5) : {'result': '3.0f', 'success': True}
[2019-03-08 18:27:29][DEBUG] : result callZiGate Array ( [result] => 3.0f [success] => 1 )
[2019-03-08 18:27:29][DEBUG] : callZiGate get_libversion
[2019-03-08 17:27:29][DEBUG][root](Thread-5) : {'args': '', 'action': 'get_libversion'}
[2019-03-08 17:27:29][DEBUG][root](Thread-5) : {'result': '0.28.4', 'success': True}
[2019-03-08 18:27:29][DEBUG] : result callZiGate Array ( [result] => 0.28.4 [success] => 1 )
[2019-03-08 17:28:53][DEBUG][zigate](Thread-7) : Auto saving /var/www/html/plugins/zigate/core/class/../../resources/zigated/zigate.json
[2019-03-08 17:28:53][DEBUG][zigate](Thread-7) : Saving persistent file
[2019-03-08 17:28:53][DEBUG][zigate](Thread-7) : File already existing, make a backup before
Bonsoir,paulnux a écrit : ↑08 mars 2019, 18:26Bon et bien moi qui me réjouissais que tout fonctionnait bien, après la mise a jours du plugin plus aucun équipement ne fonctionne![]()
LOG-ZIGATE.txt
Installation des dépendances
Ign http://repo.jeedom.com ./ InRelease
Ign http://repo.jeedom.com ./ Release.gpg
Ign http://http.us.debian.org jessie InRelease
Get:1 http://security.debian.org jessie/updates InRelease [44.9 kB]
Hit http://http.us.debian.org jessie Release.gpg
Ign http://httpredir.debian.org jessie InRelease
Ign http://repo.jeedom.com ./ Sources/DiffIndex
Hit https://deb.nodesource.com jessie InRelease
Get:2 http://httpredir.debian.org jessie-updates InRelease [145 kB]
Ign http://repo.jeedom.com ./ Packages/DiffIndex
Hit http://httpredir.debian.org jessie Release.gpg
Ign http://repo.jeedom.com ./ Translation-en_US
Err http://repo.jeedom.com ./ Sources
404 Not Found
Err http://repo.jeedom.com ./ Packages
404 Not Found
Get:3 http://security.debian.org jessie/updates/main Sources [294 kB]
Hit http://http.us.debian.org jessie/non-free armhf Packages
Get:4 http://security.debian.org jessie/updates/main armhf Packages [632 kB]
Get:5 https://deb.nodesource.com jessie/main Sources [687 B]
Get:6 http://security.debian.org jessie/updates/main Translation-en [332 kB]
Hit http://http.us.debian.org jessie/non-free Translation-en
Get:7 https://deb.nodesource.com jessie/main armhf Packages [930 B]
Get:8 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:9 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:10 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:12 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:13 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:14 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:15 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:16 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en_US
Get:17 http://httpredir.debian.org jessie-updates/main Sources [17.2 kB]
Get:18 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:19 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:20 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3,688 B]
Get:21 http://httpredir.debian.org jessie/main Sources [7,063 kB]
Get:22 http://httpredir.debian.org jessie/main armhf Packages [6,675 kB]
Get:23 http://httpredir.debian.org jessie/main Translation-en [4,581 kB]
Fetched 1,466 kB in 48s (30.3 kB/s)
W: Failed to fetch http://repo.jeedom.com/depot/repo.jm0.eu/BSP:/IMX6/Debian_Jessie/./Sources 404 Not Found
W: Failed to fetch http://repo.jeedom.com/depot/repo.jm0.eu/BSP:/IMX6/Debian_Jessie/./Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Reading package lists...
Building dependency tree...
Reading state information...
python3 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 205 not upgraded.
python3-pip is already the newest version.
python3-requests is already the newest version.
python3-setuptools is already the newest version.
Collecting zigate==0.28.4
Downloading https://files.pythonhosted.org/packages/4e/12/4ab9496a766e09f579da858e37899983d0f009efcc2246ff18b0ad2e94c6/zigate-0.28.4-py3-none-any.whl (59kB)
Requirement already satisfied: pydispatcher in /usr/local/lib/python3.4/dist-packages (from zigate==0.28.4) (2.0.5)
Collecting graphviz (from zigate==0.28.4)
Downloading https://files.pythonhosted.org/packages/1f/e2/ef2581b5b86625657afd32030f90cf2717456c1d2b711ba074bf007c0f1a/graphviz-0.10.1-py2.py3-none-any.whl
Requirement already satisfied: pyserial in /usr/local/lib/python3.4/dist-packages (from zigate==0.28.4) (3.4)
Requirement already satisfied: bottle in /usr/local/lib/python3.4/dist-packages (from zigate==0.28.4) (0.12.16)
Installing collected packages: graphviz, zigate
Found existing installation: zigate 0.27.9
Uninstalling zigate-0.27.9:
Successfully uninstalled zigate-0.27.9
Successfully installed graphviz-0.10.1 zigate-0.28.4
Installation des dépendances terminé !
Tu peux le réinstaller (sans tout supprimer) dans le centre de mises à jour.paulnux a écrit : ↑08 mars 2019, 21:32Si je supprime et réinstalle entièrement le plugin je pense qu'il va falloir tout réassocier et si je peux éviter pour l'instant je préfère.
J'ai tenté de réinstaller les dépendances et toujours pareil
J'ai tenté de débranché et rebranché la clé et toujours pareil
Voici le log zigate-updateCode : Tout sélectionner
Installation des dépendances Ign http://repo.jeedom.com ./ InRelease Ign http://repo.jeedom.com ./ Release.gpg Ign http://http.us.debian.org jessie InRelease Ign http://repo.jeedom.com ./ Release Get:1 http://security.debian.org jessie/updates InRelease [44.9 kB] Hit http://http.us.debian.org jessie Release.gpg Ign http://httpredir.debian.org jessie InRelease Hit http://http.us.debian.org jessie Release Ign http://repo.jeedom.com ./ Sources/DiffIndex Hit https://deb.nodesource.com jessie InRelease Get:2 http://httpredir.debian.org jessie-updates InRelease [145 kB] Ign http://repo.jeedom.com ./ Packages/DiffIndex Hit http://httpredir.debian.org jessie Release.gpg Hit http://httpredir.debian.org jessie Release Ign http://repo.jeedom.com ./ Translation-en_US Ign http://repo.jeedom.com ./ Translation-en Err http://repo.jeedom.com ./ Sources 404 Not Found Err http://repo.jeedom.com ./ Packages 404 Not Found Get:3 http://security.debian.org jessie/updates/main Sources [294 kB] Hit http://http.us.debian.org jessie/non-free armhf Packages Get:4 http://security.debian.org jessie/updates/main armhf Packages [632 kB] Get:5 https://deb.nodesource.com jessie/main Sources [687 B] Get:6 http://security.debian.org jessie/updates/main Translation-en [332 kB] Hit http://http.us.debian.org jessie/non-free Translation-en Get:7 https://deb.nodesource.com jessie/main armhf Packages [930 B] Get:8 https://deb.nodesource.com jessie/main Translation-en_US [162 B] Get:9 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:10 https://deb.nodesource.com jessie/main Translation-en_US [162 B] Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:12 https://deb.nodesource.com jessie/main Translation-en_US [162 B] Get:13 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:14 https://deb.nodesource.com jessie/main Translation-en_US [162 B] Get:15 https://deb.nodesource.com jessie/main Translation-en [162 B] Get:16 https://deb.nodesource.com jessie/main Translation-en_US [162 B] Ign https://deb.nodesource.com jessie/main Translation-en_US Get:17 http://httpredir.debian.org jessie-updates/main Sources [17.2 kB] Get:18 https://deb.nodesource.com jessie/main Translation-en [162 B] Ign https://deb.nodesource.com jessie/main Translation-en Get:19 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB] Get:20 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3,688 B] Get:21 http://httpredir.debian.org jessie/main Sources [7,063 kB] Get:22 http://httpredir.debian.org jessie/main armhf Packages [6,675 kB] Get:23 http://httpredir.debian.org jessie/main Translation-en [4,581 kB] Fetched 1,466 kB in 48s (30.3 kB/s) W: Failed to fetch http://repo.jeedom.com/depot/repo.jm0.eu/BSP:/IMX6/Debian_Jessie/./Sources 404 Not Found W: Failed to fetch http://repo.jeedom.com/depot/repo.jm0.eu/BSP:/IMX6/Debian_Jessie/./Packages 404 Not Found E: Some index files failed to download. They have been ignored, or old ones used instead. Reading package lists... Building dependency tree... Reading state information... python3 is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 205 not upgraded. Reading package lists... Building dependency tree... Reading state information... python3-pip is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 205 not upgraded. Reading package lists... Building dependency tree... Reading state information... python3-requests is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 205 not upgraded. Reading package lists... Building dependency tree... Reading state information... python3-setuptools is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 205 not upgraded. Collecting zigate==0.28.4 Downloading https://files.pythonhosted.org/packages/4e/12/4ab9496a766e09f579da858e37899983d0f009efcc2246ff18b0ad2e94c6/zigate-0.28.4-py3-none-any.whl (59kB) Requirement already satisfied: pydispatcher in /usr/local/lib/python3.4/dist-packages (from zigate==0.28.4) (2.0.5) Collecting graphviz (from zigate==0.28.4) Downloading https://files.pythonhosted.org/packages/1f/e2/ef2581b5b86625657afd32030f90cf2717456c1d2b711ba074bf007c0f1a/graphviz-0.10.1-py2.py3-none-any.whl Requirement already satisfied: pyserial in /usr/local/lib/python3.4/dist-packages (from zigate==0.28.4) (3.4) Requirement already satisfied: bottle in /usr/local/lib/python3.4/dist-packages (from zigate==0.28.4) (0.12.16) Installing collected packages: graphviz, zigate Found existing installation: zigate 0.27.9 Uninstalling zigate-0.27.9: Successfully uninstalled zigate-0.27.9 Successfully installed graphviz-0.10.1 zigate-0.28.4 Installation des dépendances terminé !
Non, ça réinstalle par dessus sans toucher à la config existante.
A part tenter une synchronisation dans le plugin Zigate, je vois pas quoi essayer d'autre.
J'ai aussi des problème à chaque mise à jour, je retrouve bien mes équipements sauf qu il perde leurs noms et du coup associtation scénario etc... Je restaure une sauvegarde et tout refonctionne comme avant sauf que biensur la mise à jour n est plus appliquer. En insistant 2 ou 3 fois comme ça cela fini par fonctionner après mise à jour. Juste une question pour la configuration du port usb de la zigate tu es sur auto ?paulnux a écrit : ↑09 mars 2019, 08:38Enlevé le hub alimenté et branché la clé directement sur la mini+ , ouvert la mini+ et enlevé la carte zwave à l’intérieur qui ne servait plus, et toujours pas de remonté d'info sur le dashboard.
Mais pourquoi j'ai fait la mise à jours du plugin alors que tout fonctionnait parfaitement avant![]()
HELP ME![]()
[2019-03-10 12:04:32][DEBUG] : callZiGate permit_join
[2019-03-10 12:04:32][DEBUG][root](Thread-4) : Message received in socket
[2019-03-10 12:04:32][DEBUG][root](Thread-4) : {'action': 'permit_join', 'args': ''}
[2019-03-10 12:04:32][DEBUG][zigate](Thread-4) : REQUEST : 0x0049 FFFC1E00
[2019-03-10 12:04:32][DEBUG][zigate](Thread-4) : Msg to send b'0049000450fffc1e00'
[2019-03-10 12:04:32][DEBUG][zigate](Thread-4) : Encoded Msg to send b'010210490210021450fffc1e021003'
[2019-03-10 12:04:32][DEBUG][zigate](Thread-4) : Waiting for status message for command 0x0049
[2019-03-10 12:04:32][DEBUG][zigate](ZiGate-Listen) : Raw packet received, b'\x01\x80\x02\x10\x02\x10\x02\x15\xdb\x02\x10\x17\x02\x10I\x02\x10\x03'
[2019-03-10 12:04:32][DEBUG][zigate](ZiGate-Event Loop) : Dispatch ZIGATE_PACKET_RECEIVED
[2019-03-10 12:04:32][DEBUG][zigate](ZiGate-Decode data) : Received response 0x8000: b'00170049'
[2019-03-10 12:04:32][DEBUG][zigate](ZiGate-Decode data) : RESPONSE 0x8000 - Status response : status:0, sequence:23, packet_type:73, error:b'', lqi:0
[2019-03-10 12:04:32][DEBUG][zigate](ZiGate-Decode data) : Dispatch ZIGATE_RESPONSE_RECEIVED
[2019-03-10 12:04:32][DEBUG][zigate](Thread-4) : STATUS code to command 0x0049:RESPONSE 0x8000 - Status response : status:0, sequence:23, packet_type:73, error:b'', lqi:0
[2019-03-10 12:04:32][DEBUG][root](Thread-4) : {'success': True, 'result': OrderedDict([('status', 0), ('sequence', 23), ('packet_type', 73), ('error', b''), ('lqi', 0)])}
[2019-03-10 12:04:32][DEBUG] : result callZiGate Array ( [success] => 1 [result] => Array ( [status] => 0 [sequence] => 23 [packet_type] => 73 [error] => [lqi] => 0 ) )
[2019-03-10 12:04:57][DEBUG] : callZiGate get_version_text
[2019-03-10 12:04:57][DEBUG][root](Thread-4) : Message received in socket
[2019-03-10 12:04:57][DEBUG][root](Thread-4) : {'action': 'get_version_text', 'args': ''}
[2019-03-10 12:04:57][DEBUG][root](Thread-4) : {'success': True, 'result': '3.0e'}
[2019-03-10 12:04:57][DEBUG] : result callZiGate Array ( [success] => 1 [result] => 3.0e )
[2019-03-10 12:04:57][DEBUG] : callZiGate get_libversion
[2019-03-10 12:04:57][DEBUG][root](Thread-4) : {'action': 'get_libversion', 'args': ''}
[2019-03-10 12:04:57][DEBUG][root](Thread-4) : {'success': True, 'result': '0.28.4'}
[2019-03-10 12:04:57][DEBUG] : result callZiGate Array ( [success] => 1 [result] => 0.28.4 )
J'ai eu le même problème que toi, pour le résoudre j'ai activé le mode inclusion puis fait l'inclusion de chaque équipements et depuis la communication re-fonctionne. Je précise que je n'ai rien eu à reconfigurer dans mes scénarios ou alarme car rien n'a été modifié après l'inclusion.
N'ayant pas eu de réponse je me permet de relancer la question,paulnux a écrit : ↑02 mars 2019, 10:28Quelqu'un a essayé des ampoules Xiaomi Aqara ZNLDP12LM avec la Zigate ?
Le prix est vraiment bien avec changement de température de couleur et de luminosité.
https://www.gearbest.com/smart-bulb/pp_ ... d=10568018
Je voulais savoir si il faut faire un reset comme sur les Ikea ? et si oui si c’était la même méthode ?
Hello,arno.aka.vdb a écrit : ↑14 févr. 2019, 18:05J'ai mis a jour en bêta 1.2.2 mais toujours le même problème pour moi impossible de lancer l'installation bdes dépendances
Envoyé de mon Mi MIX 3 en utilisant Tapatalk
