Diagral E-ONE - Des retours avec Jeedom ?
Re: Diagral E-ONE - Des retours avec Jeedom ?
Que donne un wget/curl vers l’URL de login depuis Jeedom ?
“La connaissance s'acquiert par l'expérience, tout le reste n'est que de l'information.”
Albert Einstein
Albert Einstein
wget https://appv3.tt-monitor.com/topaze/authenticate/login
--2019-05-24 13:42:06-- https://appv3.tt-monitor.com/topaze/authenticate/login
Resolving appv3.tt-monitor.com (appv3.tt-monitor.com)... 90.83.135.115
Connecting to appv3.tt-monitor.com (appv3.tt-monitor.com)|90.83.135.115|:443... connected.
HTTP request sent, awaiting response... 405 M\351thode Non Autoris\351e
2019-05-24 13:42:06 ERROR 405: M\351thode Non Autoris\351e.
Rpi 3B / Z-wave+ / Rfp1000
Tu es sur de ton mot de passe ? Car là tu as la connectivité au site, mais pour autant Diagral te refuse
Tu peux me partager ton script ?
Albert Einstein
Albert Einstein
?php
* This file is part of the Diagral-eOne-API-PHP distribution (https://github.com/mguyard/Diagral-eOne-API-PHP).
* Copyright (c) 2018 Marc GUYARD (https://github.com/mguyard).
* Version : 1.0
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, version 3.
* This program is distributed in the hope that it will be useful, but
* WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
* General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
// Chargement des classes
require_once 'class/Diagral/Diagral_eOne.class.php';
use \Mguyard\Diagral\Diagral_eOne;
// Instanciation de mon objet Alarm
$MyAlarm = new Diagral_eOne("XXXXX","XXXXX");
// Activation/Désactivation du mode verbose
$MyAlarm->verbose = True;
$MyAlarm->login(); // On peut recuperer des information par le retour de la fonction
$MyAlarm->getSystems(); // Recupere la liste de toutes les alarmes
$MyAlarm->setSystemId(0); // Definit l'ID de son alarme
$MyAlarm->getConfiguration();
$MyAlarm->connect("XXXXX");
// Si nous n'avons pas d'information sur l'état de l'alarme (session existante), on demande les informations
if(empty($MyAlarm->systemState)) {
$MyAlarm->getAlarmStatus();
echo "".$MyAlarm->systemState."\n";
$MyAlarm->logout();
* Version : 1.0
$MyAlarm->logout();
Je vois pas comme ça. Tout semble bon si tu es sûr de ton mot de passe.
Tu penses possible de me donner un accès ssh sur ton Jeedom pour regarder ?
Albert Einstein
Albert Einstein
Je n'ai pas d'accès physique sur mon jeedom actuellement. Je fais des tests à partir d'un PC après avoir constaté des problèmes avec le script.
Je suis donc le seul à avoir ce problème ?
A priori ouitduf a écrit :Je suis donc le seul à avoir ce problème ?
Albert Einstein
Albert Einstein
Je me tate a équiper ma diagral avec la box E-One. Mettre les mains dans Jeedom ne me fait pas peut (ce sera pas la première fois) par contre après lecture de quasiment toutes les pages j'ai un peu de mal a savoir ce qu'il est possible de faire ou non.
Mon besoin :
Remonter les états On/off/alerte de diagral vers Jeedom -> ca semble OK
Faire agir Jeedom en fonction des capteurs diagral -> mon alarme est en OFF, puis-je connaitre l'état du capteur d'ouverture de la porte d'entrée ?
Faire agir diagral en fonction d'un capteur Jeedom -> un capteur domotique EnOcean ou Zwave pourrait déclencher l'alarme (la faire sonner)
merci pour vos retours
Mon besoin :
1/ pas de souci
2/ impossible. Diagral ne permet pas d’avoir le statut des détecteurs
3/ tu peux faire un scénario diagral qui déclenche l’alarme. Et une commande Jeedom qui déclenche le scénario Diagral. Donc à partir d’un détecteur Zwave ou EnOcean tu devrais pouvoir faire sonner l’alarme
1/ pas de souci
Albert Einstein
Albert Einstein
Merci pour ton retour Mguyard,
Je pense que je vais la commander alors, pour le point 2, je peux m'en passer.
Ce qui est le plus important c'est le 1 ensuite le 3 (pas envie de mettre 2 capteurs différents sur chaque porte ça commence à couter cher au bout d'un moment...).
Avec le contrôle d'état de l'alarme depuis Jeedom, celui-ci pourra passer mon Syno surveillance station en Home Mode et donc arrêter de m'envoyer 2000 photos d'intrusion quand la femme de ménage vient ou quand mon père arrose les plantes et nourrit les poissons lorsqu'on est en vacances !
C’est ce que je fais et ça marche très bienAlex37 a écrit : Avec le contrôle d'état de l'alarme depuis Jeedom, celui-ci pourra passer mon Syno surveillance station en Home Mode
Albert Einstein
Albert Einstein
Je me décide enfin à commencer le plugin. J’ai passé une partie de l’après-midi.
Pour l’instant j’ai un début opérationnel qui récupère tous seul les alarmes configuré sur votre compte Diagral ainsi que l’état.
J’ai une question pour ceux qui ont plusieurs alarmes configuré sur leur compte, est-ce que le Master code est différent pour chaque alarme ou globale ?
Et maintenant c’est le bon moment, pour demander les commandes Que vous souhaiteriez avoir.
Albert Einstein
Albert Einstein
Top !
Pour moi, ce qui m'est utile et mis en place au travers des scripts:
- armement total
- armement partiel
- désarmement total
- désarmement partiel
- mode présence
- le statut
- les groupes armés
Et comme le cloud Diagral est parfois capricieux, penses, lors de l'exécution d'une commande, à retourner une erreur à l'utilisateur afin que l'on puisse se l'envoyer dans l'action suivante du scénario ...
Merci ...!
Fais signe lorsque tu veux tester.
- armement total
- armement partiel
- désarmement total
- mode présence
- le statut
- les groupes armés
Merci ...!
Trop bien bientôt un plugin même si mon sript fonctionne
A très vite
A très vite
Jeedom Smart
Passerelle 433 : RFXCOM-RFXtrx433E
Zigbee (xiaomi)
Z-wave
IPX800V4+X4VR
5 Caméras Reolink
Syno DS 416 + DS 214
Zigbee (xiaomi)
Z-wave
IPX800V4+X4VR
5 Caméras Reolink
La je suis en vacance mais je ferais signe pour la bêta.Juju31 a écrit :Top !
- armement total
- armement partiel
- désarmement total
- mode présence
- le statut
- les groupes armés
Merci ...!
Quand tu parles de retourner une erreur pour l’action suivante tu parles d’un code de retour par exemple dans une commande info ?
Car je peux générer un log comme tout les plugins mais tu peux pas exploiter le log je crois.
J’ai dû mal à voir la logique derrière donc si tu peux m’éclairer.
Albert Einstein
Albert Einstein
Bonjour a tous
peux ton utilisé un compte secondaire spécial jeedom via le script car je n'arrive pas a le faire fonctionner je ne voudrais pas donné un acces total a jeedom Merci de votre retour
Jeedom Smart
Zigbee (xiaomi)
Z-wave
IPX800V4+X4VR
5 Caméras Reolink
Zigbee (xiaomi)
Z-wave
IPX800V4+X4VR
5 Caméras Reolink
Bonjour,Matt25p a écrit :Bonjour a tous
Oui un compte secondaire fonctionne bien. Quand je fais mes tests d’évolution API je le fais avec le compte master et un compte secondaire.
Albert Einstein
Albert Einstein
mince alors il faut que je cherche
Jeedom Smart
Zigbee (xiaomi)
Z-wave
IPX800V4+X4VR
5 Caméras Reolink
Zigbee (xiaomi)
Z-wave
IPX800V4+X4VR
5 Caméras Reolink
Ton compte marche avec l’application eOne ?
Qu’est ce qui bloque ? Tu as le log en verbose ?
Albert Einstein
Albert Einstein
