[Plugin Tiers][Sujet Principal] Portier GrandStream GDS3710
- Timide
Re: [Plugin Tiers][Sujet Principal] Portier GrandStream GDS3710
extrait du log ou a priori RAS, mais la photo n'est pas visible. J'ai néanmoins afficher le flux mjpeg sur le widget, mais c'est aléatoire. Je pense bien un problème de coupure réseau a travers les boitier CPL. je vais tester avec d'autres
[2019-10-14 22:18:57][DEBUG] : Snapshot has been requested
[2019-10-14 22:18:57][DEBUG] : URL array : Array ( [10002] => https://192.168.0.232/goform/login?cmd= ... min&type=1 [64] => [81] => [19913] => 1 )
[2019-10-14 22:18:57][DEBUG] : URL return : <?xml version="1.0" encoding="UTF-8" ?><Configuration><ResCode>0</ResCode><ChallengeCode>b8802db10ba31f134c16ff1065784d6a</ChallengeCode><RetMsg>OK</RetMsg></Configuration>
[2019-10-14 22:18:57][DEBUG] : String to be hashed : b8802db10ba31f134c16ff1065784d6a:GDS3710lDyTlHwN*********
[2019-10-14 22:18:57][DEBUG] : URL array : Array ( [10002] => https://192.168.0.232/goform/login?cmd= ... ***&type=1 [64] => [81] => [19913] => 1 [42] => 1 )
[2019-10-14 22:18:57][DEBUG] : URL return : HTTP/1.0 200 OK Content-Type: text/xml;charset=UTF-8 Set-Cookie: mjpeg_sess=ced4102563f58e5957c2e3173ce98964;path=/; Set-Cookie: mjpeg_uname=admin;path=/; Set-Cookie: mjpeg_level=1;path=/; <?xml version="1.0" encoding="UTF-8" ?><Configuration><ResCode>0</ResCode><RetMsg>OK</RetMsg></Configuration>
[2019-10-14 22:18:57][DEBUG] : Trying to create the capture under : /var/www/html/core/php/../../snap/9/parlophone_2019-10-14_20-18-57-792000.jpg
[2019-10-14 22:18:57][DEBUG] : URL array : Array ( [10002] => https://192.168.0.232/snapshot/view0.jpg [64] => [81] => [19913] => 1 [10022] => mjpeg_sess=ced4102563f58e5957c2e3173ce98964;mjpeg_uname=admin;mjpeg_level=1 [42] => [19914] => 1 [10001] => Resource id #10 )
[2019-10-14 22:18:58][DEBUG] : URL return : 1
[2019-10-14 22:18:58][DEBUG] : Closing the file
[2019-10-14 22:18:58][DEBUG] : Registering path to lastest picture
- Timide
j'ai changé mes boitiers CPL et effectivement le débit est bien meilleur.
j'ai bien le retour du flux vidéo dans le widget et les bouton fonctionne correctement
par contre toujours pas de snap
ci joint log
[2019-10-19 14:57:52][DEBUG] : Snapshot has been requested
[2019-10-19 14:57:52][DEBUG] : URL array : Array ( [10002] => https://192.168.0.232/goform/login?cmd= ... min&type=1 [64] => [81] => [19913] => 1 )
[2019-10-19 14:57:52][DEBUG] : URL return : <?xml version="1.0" encoding="UTF-8" ?><Configuration><ResCode>0</ResCode><ChallengeCode>86f2f61260ca16387c6d0c9e53842728</ChallengeCode><RetMsg>OK</RetMsg></Configuration>
[2019-10-19 14:57:52][DEBUG] : String to be hashed : 86f2f61260ca16387c6d0c9e53842728:GDS3710lDyTlHwNgZ:********
[2019-10-19 14:57:52][DEBUG] : URL array : Array ( [10002] => https://192.168.0.232/goform/login?cmd= ... ***&type=1 [64] => [81] => [19913] => 1 [42] => 1 )
[2019-10-19 14:57:52][DEBUG] : URL return : HTTP/1.0 200 OK Content-Type: text/xml;charset=UTF-8 Set-Cookie: mjpeg_sess=74d18b796d9bcb4a31ca61546cc92906;path=/; Set-Cookie: mjpeg_uname=admin;path=/; Set-Cookie: mjpeg_level=1;path=/; <?xml version="1.0" encoding="UTF-8" ?><Configuration><ResCode>0</ResCode><RetMsg>OK</RetMsg></Configuration>
[2019-10-19 14:57:52][DEBUG] : Trying to create the capture under : /var/www/html/core/php/../../snap/26/cam1_2019-10-19_12-57-52-981000.jpg
[2019-10-19 14:57:52][DEBUG] : URL array : Array ( [10002] => https://192.168.0.232/snapshot/view0.jpg [64] => [81] => [19913] => 1 [10022] => mjpeg_sess=74d18b796d9bcb4a31ca61546cc92906;mjpeg_uname=admin;mjpeg_level=1 [42] => [19914] => 1 [10001] => Resource id #10 )
[2019-10-19 14:57:53][DEBUG] : URL return : 1
[2019-10-19 14:57:53][DEBUG] : Closing the file
[2019-10-19 14:57:53][DEBUG] : Registering path to lastest picture
ci joint log
- Timide
Salut, ca ressemble à un problème de droit, es-tu certain que l'utilisateur www-data à les droits d'écriture dans le dossier où tu veux stocker les captures?889laurent a écrit : ↑19 oct. 2019, 15:06j'ai changé mes boitiers CPL et effectivement le débit est bien meilleur.
ci joint log
Peux tu faire un petit ls -l le dossier parent de ton dossier de capture?
- Timide
-rw-r--r-- 1 www-data www-data 141129 Oct 19 13:51 cam1_2019-10-19_13-51-22-2437
retour dossier
retour dossier
- Timide
On va fait un petit test, fait un "chmod -R 775" sur le répertoire qui contient tes captures. Chez moi ca donne qqch comme :
chmod -R 775 /var/www/html/plugins/gds3710/data/records
Et reessaye de faire une capture.
- Timide
le fichier présent récupère les droits, mais lorsque je fait une nouvelle capture le nx fichier n'a pas les droits du dossier ?
je suis sous une Jeedom smart
- Timide
Quel est le dossier que tu utilises pour placer tes captures?
- Timide
j'avais mis tout simplement snap et il s'est mis sous /var/www/html/snap/26. je viens de mettre ton emplacement plugins/gds3710/data/records et ce marche.
merci pour ton aide
merci pour ton aide
- Timide
je voulais pouvoir m'envoyer des sms avec les snap. Je vais chercher sur le forum comment faire, mais si je peu abuser de ton aide je suis preneur de pistes.
cordialement
cordialement
- Timide
889laurent a écrit : ↑19 oct. 2019, 16:24je voulais pouvoir m'envoyer des sms avec les snap. Je vais chercher sur le forum comment faire, mais si je peu abuser de ton aide je suis preneur de pistes.
cordialement
Je n'ai jamais envoyé de sms mais je m'envoie les captures par telegram. A priori ca devrait marcher avec les sms aussi, c'est une fonction intégré dans le plugin.
Tu as une commande du plugin qui s'appelle "Envoyer un snapshot" qui permet de spécifier un nombre de capture et une commande d'envoi.
- Timide
je vais suivre ta démarche avec télégram.
merci encore
merci encore
- Timide
- Timide
bonsoir, je viens de tester les messages avec telegram et effectivement ca semble très puissant dans les possibilités.
par contre lors de l'envoi du message vers telegram, j'ai noté "appel parlophone" et je reçoit sur le tel /plugin/gds3710/core/php/camera.php?mac=******Appel parlophone
je pense qu'il y a un petit bug.
- Timide
889laurent a écrit : ↑20 oct. 2019, 20:29bonsoir, je viens de tester les messages avec telegram et effectivement ca semble très puissant dans les possibilités.
C'est bizarre, est ce que tu peux me faire une capture d'écran de la façon dont tu configure la commande pour obtenir ce résultat?
- Timide
j'ai refait la config et maintenant ca marche. je ne sais pas ce que j'avais fait comme erreur.
par contre je n'arrive pas a lancer un scenario ?
j'ai seulement des actions possible vers des équipements. je ne sait surement pas faire car je commence sous Jeedom
- Timide
C'est bon j'ai trouvé. il faut écrire scenario et sauvegarder
- Timide
C'est assez simple, tu as juste a écrire "scénario" dans la case "action" puis enregistrer, tu pourra alors sélectionner le scenario que tu veux lancer.889laurent a écrit : ↑20 oct. 2019, 22:35j'ai refait la config et maintenant ca marche. je ne sais pas ce que j'avais fait comme erreur.
Salut ripleyxlr8,
Je viens un peut aux nouvelles de la nouvelle version que tu nous prepares, je suis impatient de la tester.
J’en profite pour te signaler quelques bugs de fonctionnement du plugin sur la V4, c’est peux être pas des bugs mais juste des problèmes liés à ma maquette de test en v4.
J’utilise un reverse proxy sous nginx pour me connecter a Jeedom de l’extérieur, sous la forme de https://mondnsperso.xxx/jeedomv4, cet alias me redirige de façon transparente vers l’url http interne de mon jeddom de test.
Ce fonctionnement me permet de m’affranchir des contraintes de certificat interne tout en ayant un certificat pour les connexions externes.
Dans cette configuration, je n’ai pas le flux vidéo du GDS sur le dashboard, alors que ça ne pose aucun problème aux plugins camera et surveillance station. Y’a aucune urgence, car je n’utilise pas jeedom pour la surveillance des cameras depuis l’extérieur, mais ca sert forcement a d'autres.
Le second problème que je rencontre est encore sur le flux vidéo du dashboard, je le perds après un certain temps, je dois relancer complètement le navigateur pour qu'il apparaisse de nouveau. Il faut que je creuse également, mais il me semble qu’au moment où je n’ai plus de vidéo, la navigation sur jeedom est extrêmement lente avec la roue crantée durant plusieurs secondes lorsque je navigue. Je n’ai pas ce problème lorsque je suis en externe, mais c’est peux être une coïncidence.
On devrait peux être passer sur https://community.jeedom.com pour continuer la conversation sur ton plugin ?
Jeedom 3.3.29 DIY ESXi sur HP Prolian Gen8
- Timide
Salut Alpine_Z,
Pour ton premier problème de redirection je vais jeter un coups d'oeil et voir ce qu'il y a de différent par rapport aux autres plugin. Il y a quand même une différence essentielle dans le mode de fonctionnement. Le plugin camera te présente une succession de snap du flux qu'il actualise régulièrement, il y a donc une action de plugin pour capturer une frame du flux et de l'afficher dans le navigateur. Le flux que tu regardes sur le plugin camera n'est qu'un échantillon du flux d'origine. Mon système est un peu plus léger en ressource pour Jeedom mais un peu plus sensible aux problèmes de réseau (ce qui peut expliquer aussi ton deuxième problème) car mon plugin ne fait que rediriger le flux du portier vers ton navigateur sans le modifier.
Pour essayer de diagnostiquer le problème est ce que tu pourrais vérifier l'url de l'image dans le widget?
PS : Pour le nouveau forum, on va faire la bascule très rapidement... mais j'ai quelques soucis de connexion internet en ce moment qui n'ont rien a voir avec Jeedom et ca me prends un peu de temps. Pour ceux qui veulent voir comment j'ai fais le con avec ma connexion fibre qui marchait bien, ca se passe la : https://lafibre.info/remplacer-livebox/ ... e/new/#new
Salut ripleyxlr8,
j'ai remarqué un truc qui pourrais t'aider, lorsque je suis a extérieur, l'url utilisée pour ouvrir le flux n'ai pas bon, il ne prend pas en compte l'url externe configurée dans les paramètres de jeedom.
Voila ce que j'ai dans une page console de Chrome, il utilise l'url https://monjeedomexterne:4265/plugins/etc... alors qu'il devrait utiliser https://monjeedomexterne:4265/jeedom/plugins/etc...
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 17 invités
