[Plugin Tiers][Sujet Principal] Plugin Arlo
Re: [Plugin Tiers][Sujet Principal] Plugin Arlo
J'ai viens d'effacer tous les objects dans le plugin et limiter l'accès à seulement 1 caméra dans arlo.com
j'ai réactivé le plugin et syncro.
==> la base est revenue "Arlo(basestaion)" et la caméra "Cuisine(camera)" :: PARFAIT
MAis le démon est toujours NOK (enfin il s'active pendant 4-5 secondes puis repasse en NOK.
Je t'envoi le log en mp
JEEDOM Smart
Dongle Z-Wave
RFXCOM (RFX1000); rts, x2d, oregon,
Dongle Z-Wave
Hi, thank you for your prompt answer!!
After reading it I reinstalled the plugin but the error persists.
Arlo_update:
Arlo_daemon:
Regards.
Logs bellow. I'm running Jeedom on a Raspberry Pi 3.Could you please provide the dependency log as well (arlo_update)? it might be an error with the installed version of some libraries.
Also, on which system are you running jeedom?
Arlo_update:
* Launch install of dependencies *
Tue May 14 10:23:20 WEST 2019
Hit http://archive.raspberrypi.org jessie InRelease
Get:1 http://mirrordirector.raspbian.org jessie InRelease [15.0 kB]
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
Hit https://deb.nodesource.com jessie InRelease
Hit https://deb.nodesource.com jessie/main Sources
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:2 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:3 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:6 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Fetched 15.0 kB in 10s (1402 B/s)
Reading package lists...
Install modules using apt-get...
Building dependency tree...
Reading state information...
python-pip is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
Install the required libraries...
Requirement already satisfied (use --upgrade to upgrade): monotonic in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Uninstalling sseclient:
Successfully uninstalled sseclient
Downloading/unpacking sseclient==0.0.18
Downloading sseclient-0.0.18.tar.gz
Running setup.py (path:/tmp/pip-build-xf8pCc/sseclient/setup.py) egg_info for package sseclient
Requirement already satisfied (use --upgrade to upgrade): requests>=2.0.0 in /usr/lib/python2.7/dist-packages (from sseclient==0.0.18)
Requirement already satisfied (use --upgrade to upgrade): six in /usr/lib/python2.7/dist-packages (from sseclient==0.0.18)
Installing collected packages: sseclient
Running setup.py install for sseclient
Successfully installed sseclient
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): requests in /usr/lib/python2.7/dist-packages
Cleaning up...
Tue May 14 10:24:08 WEST 2019
* Everything successfully installed *
[2019-05-14 10:30:13][ERROR] : [ArloEventHandler] Fatal error: Failed to subscribe to eventstream: __init__() got an unexpected keyword argument 'session'
No, my Arlo account uses another user, not this one that I'm using in the plugin.Another possibility reading this log: are you using your own user (email address) and password to configure the plugin?
Regards.
Hi @jmrfsc
Could you please run following commands between double quotes on ssh (or via jeedom admin tool) and give me the output.
- " python -V "
- " pip freeze "
- " python -c 'import platform; print(platform.uname());' " (same info in health page)
This is to check version of installed libraries, exact version of python and paltform; I see that some librairies were already installed on your system.
FYI, I run on rpi3 (stretch) and a smart (stretch).
- " python -V "
- " pip freeze "
Développeur et auteur des plugins suivants, (entre autre Arlo, Solaredge, Design Image, Gotify...) et aidant sur plein d'autres!
Si vous voulez contribuer, un don fait toujours plaisir : https://paypal.me/mips2648
Hi @Mips2648Mips2648 a écrit : ↑14 mai 2019, 13:47Hi @jmrfsc
- " python -V "
- " pip freeze "
Python 2.7.9
Cython==0.21.1
Flask==0.10.1
Flask-HTTPAuth==3.2.1
Flask-RESTful==0.3.5
Jinja2==2.7.3
Louie==1.1
MarkupSafe==0.23
Pillow==2.6.1
PyJWT==0.2.1
Pygments==2.0.1
RPi.GPIO==0.6.3
RTIMULib==7.2.1
Sphinx==1.2.3
Werkzeug==0.9.6
actdiag==0.5.4
aniso8601==1.2.0
argparse==1.2.1
beautifulsoup4==4.5.1
blinker==1.3
blockdiag==1.5.3
bluepy==1.1.0
certifi==2018.1.18
cffi==0.8.6
chardet==2.3.0
colorama==0.3.2
construct==2.8.20
cryptography==0.6.1
docutils==0.12
duplicity==0.6.24
ecdsa==0.11
enum-compat==0.0.2
enum34==1.1.6
funcparserlib==0.3.6
future==0.16.0
gpiozero==1.4.0
html5lib==0.999
idna==2.6
iotop==0.6
itsdangerous==0.24
libopenzwave==0.3.0
lockfile==0.8
lxkeymap==0.1
lxml==3.4.0
mcpi==0.1.1
mercurial==3.1.2
monotonic==1.3
ndg-httpsclient==0.3.2
nose==1.3.4
numpy==1.8.2
nwdiag==1.0.4
oauthlib==0.6.3
openzwave==0.3.0
paramiko==1.15.1
picamera==1.13
picraft==1.0
pifacecommon==4.2.1
pifacedigitalio==3.1.0
pigpio==1.35
ply==3.4
pyOpenSSL==0.14
pyarlo==0.0.8
pyasn1==0.1.7
pycparser==2.10
pycrypto==2.6.1
pygame==1.9.2a0
pygobject==3.14.0
pyinotify==0.9.4
pyserial==2.6
python-apt==0.9.3.12
python-dateutil==2.6.0
pytz==2016.7
pyudev==0.16.1
requests==2.4.3
roman==2.0.0
sense-emu==1.0
sense-hat==2.2.0
seqdiag==0.9.5
six==1.8.0
smbus==1.1
speedtest-cli==1.0.6
sphinxcontrib-actdiag==0.8.5
sphinxcontrib-blockdiag==1.5.5
sphinxcontrib-nwdiag==0.9.5
sphinxcontrib-seqdiag==0.8.5
spidev==3.0
sseclient==0.0.18
sseclient-py==1.7
twython==3.1.2
urllib3==1.9.1
urwid==1.3.1
webcolors==1.7
wheel==0.24.0
wsgiref==0.1.2
Thanks!
Bonjour, et merci pour ce plugin, tout juste quelques semaines aprés mes achats !! Au TOP !!
Pour ma part le plugin reconnais bien mes 2 arlo sans soucis, j'ai bien les captures !
Juste une chose, le status de 'Detection des mouvements' ne fonctionne pas. Je n'ai rien lorsque j'interroge la commande info (vide), mais dans l'app officielle j'ai bien la detection activée.
Concernant l'info "mouvement detecté", quel est le délai entre la detection du mouvement par la caméra et la reception dans jeedom ?
Merci pour ce super plugin !
Hi jmrfsc,
I got your answer, I suspect the issue is related to the version of monotic or most probably requests module, I've to check.
FYI, I know its working with monotonic==1.5 and requests==2.21.0
and you have requests==2.4.3
if you know how to do it you can give a try (but no guarantee from me), anyway please give me some time to check on my side, I will install same version of libraries to reproduce the issue and get back to you.
regards,
Ma première idée c'est que cela serait du au fait que ce n'est pas correctement initialisé juste après la première détection des caméras.Shinzah a écrit : ↑14 mai 2019, 15:29Bonjour, et merci pour ce plugin, tout juste quelques semaines aprés mes achats !! Au TOP !!
Essaies en passant en mode "activé" puis "désactivé" (ou l'inverse) et ensuite tu peux re-basculer dans le mode que tu veux et la les valeurs devraient être correcte, si ok alors ce n'est un problème que la première fois (que je note à résoudre).
Sinon le délai de notification est quasi nul, l'info est immédiatement disponible dans le plugin, du moins aussi rapidement que dans l'app officielle.
Pareil si tu changes le mode dans l'app officielle, le plugin sera notifié immédiatement.
En effet en désactivant/réactivant cela fonctionne a merveille !!Mips2648 a écrit : ↑14 mai 2019, 15:59Ma première idée c'est que cela serait du au fait que ce n'est pas correctement initialisé juste après la première détection des caméras.
Merci beaucoup
Merci pour ton retour rapide !
Merci aussi pour les autres infos, je peux activer le plugin sans risque de surconsommation de ma (petite) bande passante
J'attends de voir l'évolution pour le lien avec l'app mobile !
Dis moi si jamais tu as besoin de plus d'informations sur la baby arlo.
Bon boulot, encore merci & excellente journée !
C'est ça j'ai modifié le nom dans jeedom.Mips2648 a écrit : ↑13 mai 2019, 21:08je pense que ce ne sont pas 2 bases "station" mais 1 base et un 2eme équipement pour la sirène intégrée à la base, ce sont 2 équipements "logiques" différents même s'ils sont regroupés dans un seul boitier "physique".
Tu peux aussi voir que les commandes sont différentes entre les 2 ainsi que le numéro du modèle se terminant par "-siren" pour le 2eme; correct?
tu peux les renommer dans l'app arlo et ils porteront aussi 2 noms différents dans jeedom après la prochaine synchro.
J'ai tenté de te faire une photo en pièce jointe, à voir si ca marche Sinon je te confirme qu'elle a bien les commandes standard.Mips2648 a écrit : ↑13 mai 2019, 21:08pourtant j'avais déjà intégré la baby arlo, peux-tu me faire une capture de l'écran histoire de voir si je repère d'où viendrait le soucis?
par contre, même s'il y a ce message, les commandes communes aux autres caméras sont présentes (captures, status...) et fonctionnent a priori, peux-tu confirmer? (je devrais clarifier ce message)
Je l’attendais depuis longtemps. Il fonctionne exactement comme je l’espérais voire même mieux. Que du bonheur!!!
Mips2648 a écrit : ↑14 mai 2019, 15:49Hi jmrfsc,
regards,
Hi @Mips2648
I've upgraded monotonic and requests to the versions mentioned by you (1.5 and 2.21.0).
Then I've relaunched again the dependencies.
Tue May 14 17:29:01 WEST 2019
Hit http://mirrordirector.raspbian.org jessie InRelease
Get:1 https://deb.nodesource.com jessie/main Translation-en [162 B]
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
DEPRECATION: Python 3.4 support has been deprecated. pip 19.1 will be the last one supporting it. Please upgrade your Python as Python 3.4 won't be maintained after March 2019 (cf PEP 429).
Collecting monotonic
Downloading https://files.pythonhosted.org/packages/ac/aa/063eca6a416f397bd99552c534c6d11d57f58f2e94c14780f3bbf818c4cf/monotonic-1.5-py2.py3-none-any.whl
Installing collected packages: monotonic
Successfully installed monotonic-1.5
WARNING: Skipping sseclient as it is not installed.
Collecting sseclient==0.0.18
Downloading https://files.pythonhosted.org/packages/cd/ca/f8ff9297c6185d942f0c7d3a8fe7766cfd6a15788463a06a99f89d413abe/sseclient-0.0.18.tar.gz
Requirement already satisfied: requests>=2.0.0 in /usr/local/lib/python3.4/dist-packages (from sseclient==0.0.18) (2.21.0)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from sseclient==0.0.18) (1.8.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.4/dist-packages (from requests>=2.0.0->sseclient==0.0.18) (2019.3.9)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.4/dist-packages (from requests>=2.0.0->sseclient==0.0.18) (3.0.4)
Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.4/dist-packages (from requests>=2.0.0->sseclient==0.0.18) (2.8)
Requirement already satisfied: urllib3<1.25,>=1.21.1 in /usr/local/lib/python3.4/dist-packages (from requests>=2.0.0->sseclient==0.0.18) (1.24.3)
Building wheels for collected packages: sseclient
Building wheel for sseclient (setup.py): started
Building wheel for sseclient (setup.py): finished with status 'done'
Stored in directory: /root/.cache/pip/wheels/cb/da/69/9f802920a1acbd08fefdf24e163cca4cd5e642136e1254de7e
Successfully built sseclient
Successfully installed sseclient-0.0.18
Requirement already satisfied: requests in /usr/local/lib/python3.4/dist-packages (2.21.0)
Requirement already satisfied: urllib3<1.25,>=1.21.1 in /usr/local/lib/python3.4/dist-packages (from requests) (1.24.3)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.4/dist-packages (from requests) (2019.3.9)
Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.4/dist-packages (from requests) (2.8)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.4/dist-packages (from requests) (3.0.4)
[2019-05-14 17:40:11][ERROR] : [ArloEventHandler] Fatal error: Failed to subscribe to eventstream: __init__() got an unexpected keyword argument 'session'
Regards.
@Mips2648, I forgot to tell you that besides the daemon is not OK I've tried the synchronization and my devices (basestation and 2 cams) appeared.
Regards.
Regards.
- Timide
Merci pour la mise à jour.
Je rencontre de nouveau un problème avec le deamon, il démarre puis s'arrête :
[2019-05-14 21:11:07][ERROR] : [ArloEventHandler] Fatal error: u'4N526BST293FC'
[2019-05-14 21:11:07][DEBUG] : Shutdown
Enfin je n'ai que 2 commande sur ma caméra (connecté et statut) qui ne semblent pas fonctionner.
Comment faire pour avoir une capture ?
Merci beaucoup pour ce plugin que j’espérais.
Malheureusement le deamon se lance puis s’arrête malgré le fait d'avoir relancé les dépendances.
[2019-05-15 08:23:18][ERROR] : [ArloEventHandler] Fatal error: u'48E46C7EA4030'
[2019-05-15 08:25:58][ERROR] : Fatal error : 401 Client Error: Unauthorized
(Mini + V 3.2.8) Jeedom smart 3.2.8
Fib fgsd 002 6
Fib FGMS 001 sur thermostat et scenario lumière
Fib FGFS 101 3, 1 en test
fib FGWPE 102 1 porte
Dio 54755 3 chauffage salon et 1 ch 1 Sdb
3 camera ip
Xiaomi detecteur ouveture, temperature enceinte
Fib fgsd 002 6
3 camera ip
Salut,openhomeautomation a écrit : ↑14 mai 2019, 23:17Bonsoir,
Pourrais-tu passer le log en debug et m'envoyer en mp le log au moment du démarrage du démon jusqu'au crash stp? Je voudrai surtout voir la ligne avec la liste des devices récupérés)
si tu pouvais m'envoyer aussi une capture de la config avancée (bouton config avancée, puis bouton "information") de l'équipement arlo q
ou au moins le "type" visible dans l'écran principal, appelé "devicetype" dans la config de l'équipement.
merci
Il semble qu'il y ai un soucis d'autorisation; peux-tu vérifier que le nom d'utilisateur et mot de passe sont correcte et vérifier que tu as bien partagé les caméras ainsi que coché la case "donné les droits d'accès" dans la config arlo (app officielle)?zaz a écrit : ↑15 mai 2019, 10:29Bonjour,
J'ai un souci avec le changement de mode. Au début de l'installation du plugin tout fonctionnait plus sur le changement de mode par scénario ou manuellement. Depuis ce matin, impossible de changer de mode par le plugin (en manuel ou par scénario). J'ai le message d'erreur suivant dans les logs:
[2019-05-15 15:49:26][ERROR] : Send command to demon error : Request (POST https://arlo.netgear.com/hmsweb/users/devices/automation/active) failed: {u'data': {u'message': u"Device doesn't belong to the User", u'reason': u"4R03777PA745D doesn't belong to the User / Is not provisioned", u'error': u'AUTO-5010'}, u'success': False}
[2019-05-15 16:00:51][ERROR] : Send command to demon error : Request (POST https://arlo.netgear.com/hmsweb/users/devices/automation/active) failed: {u'data': {u'message': u"Device doesn't belong to the User", u'reason': u"4R03777PA745D doesn't belong to the User / Is not provisioned", u'error': u'AUTO-5010'}, u'success': False}
[2019-05-15 16:01:01][ERROR] : Send command to demon error : Request (POST https://arlo.netgear.com/hmsweb/users/devices/automation/active) failed: {u'data': {u'message': u"Device doesn't belong to the User", u'reason': u"4R03777PA745D doesn't belong to the User / Is not provisioned", u'error': u'AUTO-5010'}, u'success': False}
Il semble que le user utilisé par le plugin n'a pas ou plus les droits sur tes équipements arlo.
Peux-tu vérifier dans l'app officielle que tout est correctement configuré?
est-ce que tu as "confirmé" l'adresse email du user arlo? (arlo envoit un mail avec un lien à confirmer)
as-tu coché la case "activé les accès" (cf doc)? car sans ça l'utilisateur n'a pas les droits de modifier le mode, seulement des droits en lecture
Petit update, je viens de relancer le daemon et tout est reparti. Très bizarre...
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 17 invités
