J'ai réalisé les manip précédente j'arrive ici maintenant
jeedom@jeedom:~ $ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up motion (3.2.12+git20140228-4+b2) ...
Configuration file '/etc/default/motion'
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** motion (Y/I/N/O/D/Z) [default=N] ? y
Installing new version of config file /etc/default/motion ...
Warning: The home dir /var/lib/motion you specified already exists.
Adding system user `motion' (UID 110) ...
Adding new user `motion' (UID 110) with group `motion' ...
The home directory `/var/lib/motion' already exists. Not copying from `/etc/skel'.
adduser: Warning: The home directory `/var/lib/motion' does not belong to the user you are currently creating.
Adding user `motion' to group `video' ...
Adding user motion to group video
Done.
insserv: warning: script 'resizesd' missing LSB tags and overrides
jeedom@jeedom:~ $
Broadcast message from systemd-journald@jeedom (Sun 2016-10-02 18:38:01 CEST):
motion[25534]: [0] [EMG] [ALL] become_daemon: Exit motion, cannot create process id file (pid file) /var/run/motion/motion.pid:
Message from syslogd@jeedom at Oct 2 18:38:01 ...
motion: [0] [EMG] [ALL] become_daemon: Exit motion, cannot create process id file (pid file) /var/run/motion/motion.pid:
