[Plugin Tiers][Sujet Principal] Plugin iCalendar
Antoinekl1
Re: [Sujet officiel] Plugin iCalendar
Message par Antoinekl1 » 03 janv. 2017, 11:49
Bonjour à tous
j'utilise ce plugin depuis un moment sans soucis, mais ce matin, il me remonte un événement qui n'existe pas :
j'ai le même soucis sur 2 calendriers différents
Logs d'une resynchro
[2017-01-03 11:47:21][DEBUG] : [SAVE|365] SAVE START // eqLogic.preSave(): "iAgenda JEEDOM"
[2017-01-03 11:47:21][DEBUG] : [SAVE|365] SAVE END // eqLogic.postSave()
[2017-01-03 11:47:21][DEBUG] : [SAVE|365|3401] SAVE START // cmd.preSave(): "Event_EnCours"
[2017-01-03 11:47:21][DEBUG] : [SAVE|365|3401] getICSFile() starting ...
[2017-01-03 11:47:21][DEBUG] : [SAVE|365|3401] getICSFileDonwload() send request (file_get_contents) at : https://calendar.google.com/calendar/ical/xxxxxxxxxxxxxxxxxx/private-xxxxxxxxxxxxxxxxxxxxx/basic.ics
[2017-01-03 11:47:21][DEBUG] : [SAVE|365|3401] getICSFileDonwload() request back, analyse it
[2017-01-03 11:47:22][DEBUG] : [SAVE|365|3401] setHealthNetwork()._healthNetwork=o o o o o o o o o o o o o o o
[2017-01-03 11:47:22][DEBUG] : [SAVE|365|3401] getICSFileDonwload() return contents; time=0.439sec.
[2017-01-03 11:47:22][DEBUG] : [SAVE|365|3401] manageICSFile() force update cache file
[2017-01-03 11:47:22][INFO] : [SAVE|365|3401] saveICSFile(): Mise à jour du fichier en cache: /tmp/iCalendar/iCal3401-20170103114721.tmp.ics
[2017-01-03 11:47:22][DEBUG] : [SAVE|365|3401] manageICSFile() delete previous ics file (/tmp/iCalendar/iCal3401-20170103114134.tmp.ics)
[2017-01-03 11:47:22][DEBUG] : [SAVE|365|3401] formatRangeEvents() start initialise ICal class
[2017-01-03 11:47:22][DEBUG] : [SAVE|365|3401] formatRangeEvents() ICal Class is initialised (time=0.8sec)
[2017-01-03 11:47:23][DEBUG] : [SAVE|365|3401] formatRangeEvents().periodeWorking=0 | _dStart=1483398000 (2017-01-03 00:00:00) | _dEnd=1483570799 (2017-01-04 23:59:59)
[2017-01-03 11:47:23][DEBUG] : [ICalReaderExt::getEventsFromRange()] _dStartRange=1483398000 (2017-01-03 00:00:00) | _dEndRange=1483570799 (2017-01-04 23:59:59)
[2017-01-03 11:47:23][DEBUG] : [SAVE|365|3401] formatRangeEvents() return Period Events (2)
[2017-01-03 11:47:23][DEBUG] : [SAVE|365|3401] postSave(): create/update cmd:"Event_EnCours (ExecuteFunction-3401)" - eqLogicId=iCal-3401-ExecFunction
[2017-01-03 11:47:23][DEBUG] : [SAVE|365|3401] SAVE END // cmd.postSave()
[2017-01-03 11:47:24][DEBUG] : [DASH|365] toHtml(dashboard) start ...
[2017-01-03 11:47:24][INFO] : [DASH|365] toHtml(dashboard) Refresh Widget (1 cal.): OK (0.053)
est-ce normal que le dEnd soit à la fin de la journée de demain ?
rafdulaf
Message par rafdulaf » 04 janv. 2017, 17:07
j'ai créé un événement dans Google.
Cet événement est récurrent avec arrêt après N répétitions (mercredi, jeudi et vendredi avec 6 répétitions)
Dans google, l'événement apparaît N fois, mais dans le plugin iCalendar il apparaît trop de fois.
As-tu besoin de plus de détails pour reproduire le bug?
-seb-
Message par -seb- » 04 janv. 2017, 19:06
J'utilise iCalendar depuis hier et j'avoue ne pas être déçu de mon choix, super plugin vraiment, récupération sans problème des événements de mon Google Agenda. J'ai pas encore testé toutes les fonctionnalités mais on entrevoit vite les possibilités.
J'ai juste un problème d'affichage du plugin de temps en temps, je sais pas si quelqu'un a déja eu ce problème (pas très gênant pour moi à l'heure actuelle car ce qui m’intéresse c'est récupérer les événements et pas vraiment de les afficher sur le dashboard) :
Jeedom sur RPI3
Z-Wave + Gateway Xiaomi + JPI
Présentation | Dashboard | Design | Matériel
Antoinekl1
Message par Antoinekl1 » 08 janv. 2017, 18:29
Bonjour à tous
Il y a t'il un moyen lors du déclenchement d'un événement de récupérer la date de fin afin de programmer un scénario qui se lancerait 2 heures avant le retour (ex remise en route du chauffage) ?
DuplO
Message par DuplO » 09 janv. 2017, 09:11
Salut Seb,
J'ai le même souci, j'en ai parlé sur le post il y a plusieurs mois.
Je n'ai pas trouvé de solution directe via le plugin.
Du coup, j'ai créé et j'affiche un virtuel qui prend les infos du plugin iCalendar.
kiwihc16
Message par kiwihc16 » 19 janv. 2017, 17:05
En septembre dernier, j avais posté un message avec un problème de non execution de certains événements: viewtopic.php?f=28&t=12653&p=373751#p373751
Je viens de trouver la solution a ce problème. Le plugin Networks est la raison !! Voir le commentaire et explication à: viewtopic.php?f=60&t=11693&start=280
kiwihc16
Message par kiwihc16 » 21 janv. 2017, 14:07
Je viens de trouver un bug. Avis au développer du plugin pour incorporer la correction.
J'utilise Owncloud en serveur de claendrier et récupère les infos en CalDav.
Tout fonctionne très bien sauf la synthese santé qui est toujours en erreur.
Je viens de trouver dans le fichier class: iCalendar.class.php que l'état représente uniquement le succès ou non de la connection au serveur dans la fonction getICSFileCaldav(). Si erreur de connection $this->setHealthNetwork('X'); Si success aucune action.
Donc j ai ajouté les deux lignes suivantes:
$this->setHealthNetwork('o');
$this->_errorNetwork = false;
juste après le:
catch (Exception $e) {}
Et voilà ca fonctionne nickel maintenant.
jeedom:/var/www/html/plugins/iCalendar/core/class# diff iCalendar.class.php.org iCalendar.class.php
1524a1525,1528
Apres correction tout repasse au vert:
Sante
Capture d’écran 2017-01-21 à 14.14.09.png (23.8 Kio) Consulté 1886 fois
michelw
Message par michelw » 23 janv. 2017, 09:49
DuplO a écrit :Salut Seb,
J'ai le même problème, est ce facile de faire un virtuel avec les infos de icalendar ?
si tu as une copie d'ecran je suis preneur :-)
Pour l'instant pour l'afficher je passe de position horizontal a vertical et inversement :-(
DuplO
Message par DuplO » 23 janv. 2017, 14:21
Ce n'est vraiment pas compliqué :
Configuration du virtuel :
Il s'appel "Evenements" j'y ai mis une info pour avoir la date et une autre pour l'évenement Calandar. Ici ça point sur mon calendrier de série.
Rendu sur Dashboard ou Design :
Il est indiqué Aucun car il n'y a pas d'évenement actuellement.
michelw
Message par michelw » 23 janv. 2017, 16:25
Merci pour ta réponse rapide, je test ça ce soir.
Darkeyes
Message par Darkeyes » 23 janv. 2017, 20:07
kiwihc16 a écrit :Bonjour à tous,
juste après le:
1524a1525,1528
Je confirme, je n'ai que les X qui remonte jamais de O, caldav baikal.
Tu la mets où exactement la modif?
Tu peux mettre la ligne d'avant et après pour que je test et confirme pour mois aussi
Développement script:
- ssh_commande.php
- ip_public.sh
- BackupSamba.sh
Claude69
Message par Claude69 » 24 janv. 2017, 00:51
abarrau a écrit :
Claude69 a écrit :
Claude69 a écrit :Hello @abarrau.
Il me semble que le plugin ne réagi pas à la transparence avec les versions 2.3.X
Pour info, je suis avec le thème Dark_sobre
Hello @abarrau
Je reviens vers toi pour ce petit manque. Je viens de vérifier et toujours d’actualité.
Pas d'urgence ;)
Je suis en train de mettre à niveau le plugin pour qu'il corresponde aux nouvelles fonctionnalités jeedom.
Il va bientot être livrée au beta testeur pour validation ...
Helllo
Je ne sais pas si c'est chez moi, mais toujours pas de gestion de la transparence.
Quelqu'un peut confirmer ?
Gestion filtration piscine
Divers éclairages
JEEDOM NUC 3.3.33 ULTIMATE
Mon matériel ici
abarrau
Message par abarrau » 24 janv. 2017, 08:48
@claude69, non effet pas dans la version en stable ; l'évolution a été apportée dans la version en beta par contre.
@ tous, J'ai bien lu tous vos messages, je vais essayé d'y répondre et d'apporter les corrections. Toutefois, j'ai actuellement très peu de temps (merci de votre compréhension). Par contre, j'essai de livrer une version avec plusieurs corrections/évolutions et non pas des livraisons trop rapprochées.
Je vous tiens au courant.
A++
Aurélien
Claude69
Message par Claude69 » 24 janv. 2017, 09:05
abarrau a écrit :Bonjour,
A++
Aurélien
Pas de soucis. ;) Merci
Divers éclairages
Mon matériel ici
airhic
Message par airhic » 29 janv. 2017, 19:32
J'ai de nombreux warnings de ce type dans la log cron_execution:
Warning: Declaration of iCalendar::widgetPossibility() should be compatible with eqLogic::widgetPossibility($_key = '', $_default = true) in /var/www/html/plugins/iCalendar/core/class/iCalendar.class.php on line 766
Dans http.error, j'ai ces erreurs en relation aussi avec le plugin iCalendar:
[Sun Jan 29 17:57:32.218890 2017] [:error] [pid 23230] [client 172.17.0.1:60167] PHP Warning:  Declaration of iCalendar::widgetPossibility() should be compatible with eqLogic::widgetPossibility($_key = '', $_default = true) in /var/www/html/plugins/iCalendar/core/class/iCalendar.class.php on line 0, referer: http://192.168.0.2:9080/index.php?v=d&p=dashboard
[Sun Jan 29 18:16:12.545816 2017] [:error] [pid 19231] [client 172.17.0.1:32992] PHP Warning:  Declaration of iCalendar::widgetPossibility() should be compatible with eqLogic::widgetPossibility($_key = '', $_default = true) in /var/www/html/plugins/iCalendar/core/class/iCalendar.class.php on line 0, referer: http://192.168.0.2:9080/index.php?v=d&p=dashboard
Comment corriger ces erreurs/warnings ? Merci
Synology DS415+ (vmm/mariadb) ; Rpi3 avec rfxcom et zwave.
chric
Message par chric » 30 janv. 2017, 15:33
Je ne sais pas si je suis le seul a avoir le problème mais lorsque je modifie une valeur dans mon agenda google j'ai beaucoup de mal a récupérer la ou les modifications dans icalendar. Je fais bien "Forcer la synchronisation" pour re-synchroniser tous mes équipements lors de la sauvegarde mais lorsque je test ou que je regarde le fichier ics rien n'est mise a jour.
Le rapport de santé du plugin est OK et le plugin est a jour.
Merci d'avance,
Eric
airhic
Message par airhic » 30 janv. 2017, 17:31
Moi, je le fais 2 fois. Forcer sync + sauvegarde + forcer sync + sauvegarde. Dans ce cas, j'ai bien les maj immédiates.
mapama
Message par mapama » 02 févr. 2017, 15:31
Est-il possible avec ce plugin de faire "lire" son agenda à une squeezebox ?
Merci beaucoup.
Philippe777
Message par Philippe777 » 04 févr. 2017, 13:55
bonjour,
j'ai un petit problème de compréhension avec iCalendar:
j'arrive à m'envoyer un SMS en "manuel", mais quand je veux utiliser iCalendar pour le faire, celà ne fonctionne pas !
Pb de date/heure ??
je l'ai bien dans le calendrier:
et voici l'evènement dans mon calendrier Google:
Merci de votre aide ;)
Xpenology, DSM 5.2, Jeedom DIY, clé AEON Labs Z-stick S2, FGRM-222, FGR-222, FGS-222, FGMS-001, FGFS-101, FGBS-001, DSC19103, FGSD-002, FGFS-101, FGK-101
Xiaomi Gateway V2, détecteur de porte, bouton switch
Philippe777
Message par Philippe777 » 06 févr. 2017, 19:46
Pas de piste ?...
