depuis mon passage en ubunto 16.4 (et donc php7) , j'ai le message suivant
Erreur sur domogeek::pull() : Exception Object
[message:protected] => [MySQL] Error code : 01000 (1265). Data truncated for column 'value' at row 1
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /var/www/html/core/class/DB.class.php
[line:protected] => 101
[trace:Exception:private] => Array
[0] => Array
[file] => /var/www/html/core/class/history.class.php
[line] => 717
[function] => Prepare
[class] => DB
[type] => ::
[args] => Array
[0] => REPLACE INTO history
SET cmd_id=:cmd_id,
`datetime`=:datetime,
value=:value
[1] => Array
[cmd_id] => 1461
[datetime] => 2016-05-11 06:00:00
[value] => 15:08
[2] => 0
[1] => Array
[file] => /var/www/html/core/class/cmd.class.php
[line] => 1140
[function] => save
[class] => history
[type] => ->
[args] => Array
[0] => domogeekCmd Object
[id:protected] => 1461
[logicalId:protected] =>
[eqType:protected] => domogeek
[name:protected] => Durée jour
[order:protected] => 9
[type:protected] => info
[subType:protected] => string
[eqLogic_id:protected] => 254
[isHistorized:protected] => 1
[unite:protected] =>
[configuration:protected] => {"data":"duree_jour"}
[template:protected] =>
[display:protected] => {"showOncategory":1,"showStatsOncategory":0,"showNameOncategory":1,"showOnstyle":1,"showStatsOnstyle":0,"showNameOnstyle":1}
[html:protected] =>
[_collectDate:protected] => 2016-05-11 06:00:03
[_valueDate:protected] => 2016-05-11 06:00:03
[value:protected] =>
[isVisible:protected] => 1
[_eqLogic:protected] => domogeek Object
[id:protected] => 254
[name:protected] => Domogeek
[object_id:protected] => 5
[eqType_name:protected] => domogeek
[eqReal_id:protected] =>
[isEnable:protected] => 1
[configuration:protected] => {"createtime":"2015-09-17 20:13:15","departement":"94","ville":"L'Hay les roses","zone_scolaire":"C","url":"http:\/\/domogeek.entropialux.com","updatetime":"2016-04-04 08:22:14","zone_ejp":""}
[specificCapatibilities:protected] =>
[timeout:protected] =>
[category:protected] =>
[display:protected] => {"showOncategory":1,"showObjectNameOncategory":0,"showNameOncategory":1,"showOnstyle":1,"showObjectNameOnstyle":0,"showNameOnstyle":1,"showObjectNameOnview":1,"showObjectNameOndview":1,"showObjectNameOnmview":1}
[order:protected] => 0
[_debug:protected] =>
[_object:protected] => object Object
[id:object:private] => 5
[name:object:private] => Divers
[father_id:object:private] =>
[isVisible:object:private] => 1
[position:object:private] => 10
[configuration:object:private] =>
[display:object:private] => {"icon":""}
[_needRefreshWidget:protected] =>
[_templateArray] => Array
[2] => Array
[line] => 1033
[function] => addHistoryValue
[class] => cmd
[type] => ->
[args] => Array
[0] => 15:08
[1] => 2016-05-11 06:00:03
[3] => Array
[file] => /var/www/html/plugins/domogeek/core/class/domogeek.class.php
[line] => 450
[function] => event
[class] => cmd
[type] => ->
[args] => Array
[0] => 15:08
[4] => Array
[line] => 31
[function] => getInformations
[class] => domogeek
[type] => ->
[args] => Array
[5] => Array
[file] => /var/www/html/core/php/jeeCron.php
[line] => 67
[function] => pull
[class] => domogeek
[type] => ::
[args] => Array
[previous:Exception:private] =>
