Voici la log d'installation des dépendances de la version du 2018-03-28 04:53:53
Je suis sur un RPI3 avec Jessie
Début de l'installation
Reading package lists...
Building dependency tree...
Reading state information...
libpcap-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
--2018-03-28 20:30:07-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
Length: 1617 (1.6K) [text/plain]
Saving to: ‘dependencies.sh’
0K . 100% 13.8M=0s
2018-03-28 20:30:07 (13.8 MB/s) - ‘dependencies.sh’ saved [1617/1617]
Version actuelle : 8
Get:1 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
Get:2 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
Get:3 https://deb.nodesource.com jessie InRelease [4,646 B]
Get:4 http://mirrordirector.raspbian.org jessie/main armhf Packages [9,536 kB]
Hit https://deb.nodesource.com jessie/main Sources
Get:5 https://deb.nodesource.com jessie/main armhf Packages [1,001 B]
Get:6 https://deb.nodesource.com jessie/main Translation-en_GB [162 B]
Get:7 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:8 http://archive.raspberrypi.org jessie/main armhf Packages [172 kB]
Get:9 https://deb.nodesource.com jessie/main Translation-en_GB [162 B]
Get:10 https://deb.nodesource.com jessie/main Translation-en [162 B]
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Get:11 https://deb.nodesource.com jessie/main Translation-en_GB [162 B]
Get:12 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:13 https://deb.nodesource.com jessie/main Translation-en_GB [162 B]
Get:14 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:15 https://deb.nodesource.com jessie/main Translation-en_GB [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en_GB
Get:16 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Get:17 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [43.3 kB]
Get:18 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [84.2 kB]
Get:19 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 9,880 kB in 15s (634 kB/s)
W: Failed to fetch https://deb.nodesource.com/node_8.x/dists/jessie/main/binary-armhf/Packages Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
lsb-release is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
dependencies.sh: 21: [: jessie: unexpected operator
Ok, version suffisante
> socketwatcher@0.3.0 install /var/www/html/plugins/dashbutton/resources/node_modules/socketwatcher
> node-gyp rebuild
make: Entering directory '/var/www/html/plugins/dashbutton/resources/node_modules/socketwatcher/build'
CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
../socket_watcher.cpp: In static member function ‘static void SocketWatcher::New(const Nan::FunctionCallbackInfo<v8::Value>&)’:
../socket_watcher.cpp:104:49: warning: ‘v8::Local<v8::Object> v8::Function::NewInstance() const’ is deprecated (declared at /var/www/.node-gyp/8.10.0/include/node/v8.h:3851): Use maybe version [-Wdeprecated-declarations]
info.GetReturnValue().Set(cons->NewInstance());
SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
COPY Release/socketwatcher.node
make: Leaving directory '/var/www/html/plugins/dashbutton/resources/node_modules/socketwatcher/build'
> pcap@2.0.0 install /var/www/html/plugins/dashbutton/resources/node_modules/pcap
> node-gyp rebuild
make: Entering directory '/var/www/html/plugins/dashbutton/resources/node_modules/pcap/build'
CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
CXX(target) Release/obj.target/pcap_binding/pcap_session.o
../pcap_session.cc: In static member function ‘static void PcapSession::New(const Nan::FunctionCallbackInfo<v8::Value>&)’:
../pcap_session.cc:46:49: warning: ‘v8::Local<v8::Object> v8::Function::NewInstance() const’ is deprecated (declared at /var/www/.node-gyp/8.10.0/include/node/v8.h:3851): Use maybe version [-Wdeprecated-declarations]
SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
COPY Release/pcap_binding.node
make: Leaving directory '/var/www/html/plugins/dashbutton/resources/node_modules/pcap/build'
added 57 packages in 31.915s
Fin de l'installation
Le démon ne démarre pas seul , mais une fois démarré il tient le OK
W: Failed to fetch
https://deb.nodesource.com/node_8.x/dis ... f/Packages Hash Sum mismatch
Vue que la log indique : 9 not upgraded
J'ai fais :
apt-get update
apt-get upgrade
J'ai relancé les dépendances ensuite
converted 'https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh' (UTF-8)
--2018-03-28 20:40:36-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Saving to: 'dependencies.sh'
0K . 100% 12.5M=0s
2018-03-28 20:40:36 (12.5 MB/s) - 'dependencies.sh' saved [1617/1617]
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit https://deb.nodesource.com jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:1 https://deb.nodesource.com jessie/main Translation-en [162 B]
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Get:2 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:3 https://deb.nodesource.com jessie/main Translation-en [162 B]
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
> node-gyp rebuild
../socket_watcher.cpp: In static member function 'static void SocketWatcher::New(const Nan::FunctionCallbackInfo<v8::Value>&)':
../socket_watcher.cpp:104:49: warning: 'v8::Local<v8::Object> v8::Function::NewInstance() const' is deprecated (declared at /var/www/.node-gyp/8.11.0/include/node/v8.h:3851): Use maybe version [-Wdeprecated-declarations]
> pcap@2.0.0 install /var/www/html/plugins/dashbutton/resources/node_modules/node-dash-button/node_modules/pcap
> node-gyp rebuild
make: Entering directory '/var/www/html/plugins/dashbutton/resources/node_modules/node-dash-button/node_modules/pcap/build'
../pcap_session.cc: In static member function 'static void PcapSession::New(const Nan::FunctionCallbackInfo<v8::Value>&)':
../pcap_session.cc:46:49: warning: 'v8::Local<v8::Object> v8::Function::NewInstance() const' is deprecated (declared at /var/www/.node-gyp/8.11.0/include/node/v8.h:3851): Use maybe version [-Wdeprecated-declarations]
make: Leaving directory '/var/www/html/plugins/dashbutton/resources/node_modules/node-dash-button/node_modules/pcap/build'
added 57 packages in 35.4s
Je ne sais pas si ;
Signifie pas une erreur dans le script d'installation.
Deux lignes mis plus haut, ont disparues.
Sinon, j'ai cru comprendre que Jessie n'est plus supporté, c'est bien cela ?
