Re: [Sujet officiel] Dash Button Amazon
Publié : 13 févr. 2017, 18:27
Fait un screenshot de ta config réseau
Forum sur Jeedom
https://www.jeedom.com/forum/
Début de l'installation
Reading package lists...
Building dependency tree...
Reading state information...
libpcap-dev is already the newest version.
tcpdump is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 179 not upgraded.
Version actuelle : v5.12.0
Ok, version suffisante
/usr/share/nginx/www/jeedom/plugins/dashbutton/node
`-- request@2.79.0
+-- aws-sign2@0.6.0
+-- aws4@1.6.0
+-- caseless@0.11.0
+-- combined-stream@1.0.5
| `-- delayed-stream@1.0.0
+-- extend@3.0.0
+-- forever-agent@0.6.1
+-- form-data@2.1.2
| `-- asynckit@0.4.0
+-- har-validator@2.0.6
| +-- chalk@1.1.3
| | +-- ansi-styles@2.2.1
| | +-- escape-string-regexp@1.0.5
| | +-- has-ansi@2.0.0
| | | `-- ansi-regex@2.1.1
| | +-- strip-ansi@3.0.1
| | `-- supports-color@2.0.0
| +-- commander@2.9.0
| | `-- graceful-readlink@1.0.1
| +-- is-my-json-valid@2.15.0
| | +-- generate-function@2.0.0
| | +-- generate-object-property@1.2.0
| | | `-- is-property@1.0.2
| | +-- jsonpointer@4.0.1
| | `-- xtend@4.0.1
| `-- pinkie-promise@2.0.1
| `-- pinkie@2.0.4
+-- hawk@3.1.3
| +-- boom@2.10.1
| +-- cryptiles@2.0.5
| +-- hoek@2.16.3
| `-- sntp@1.0.9
+-- http-signature@1.1.1
| +-- assert-plus@0.2.0
| +-- jsprim@1.3.1
| | +-- extsprintf@1.0.2
| | +-- json-schema@0.2.3
| | `-- verror@1.3.6
| `-- sshpk@1.10.2
| +-- asn1@0.2.3
| +-- assert-plus@1.0.0
| +-- bcrypt-pbkdf@1.0.1
| +-- dashdash@1.14.1
| | `-- assert-plus@1.0.0
| +-- ecc-jsbn@0.1.1
| +-- getpass@0.1.6
| +-- jodid25519@1.0.2
| +-- jsbn@0.1.1
| `-- tweetnacl@0.14.5
+-- is-typedarray@1.0.0
+-- isstream@0.1.2
+-- json-stringify-safe@5.0.1
+-- mime-types@2.1.14
| `-- mime-db@1.26.0
+-- oauth-sign@0.8.2
+-- qs@6.3.1
+-- stringstream@0.0.5
+-- tough-cookie@2.3.2
| `-- punycode@1.4.1
+-- tunnel-agent@0.4.3
`-- uuid@3.0.1
npm WARN enoent ENOENT: no such file or directory, open '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/package.json'
npm WARN node No description
npm WARN node No repository field.
npm WARN node No README data
npm WARN node No license field.
> socketwatcher@0.3.0 install /usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/5.12.0"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher/.node-gyp"
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher/build'
CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
COPY Release/socketwatcher.node
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher/build'
> pcap@2.0.0 install /usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap
> node-gyp rebuild
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap/.node-gyp"
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap/build'
CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
CXX(target) Release/obj.target/pcap_binding/pcap_session.o
SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
COPY Release/pcap_binding.node
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap/build'
+-- node-dash-button@0.6.1
| +-- pcap@2.0.0 (git+https://github.com/mranney/node_pcap.git#d920204745c8b00ef4b7a3fe27d902b263cdb70f)
| | +-- nan@2.5.1
| | `-- socketwatcher@0.3.0
| `-- underscore@1.8.3
`-- request@2.79.0
Un redémarrage de jeedom a résolu le problème !tchirou a écrit :Bonjour
J'ai moi aussi un problème de démon sur une mini+ en 2.4.6.
Voici ce que j'ai fait :
- j'ai téléchargé le plugin, je l'ai activé, j'ai installé les dépendances
- j'ai ajouté un dash et mis l'adresse mac
- j'ai lancé le démon mais passage en NOK
- j'ai réinstallé les dépendances z-wave
- j'ai réinstallé les dépendances du dash
Mais le démon repasse en NOK à chaque fois
Voici le log de Dashbutton_dep. Il y a manifestement un pb d'installation.
Le log de Dashbutton_node est videCode : Tout sélectionner
Début de l'installation Reading package lists... Building dependency tree... Reading state information... libpcap-dev is already the newest version. tcpdump is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 179 not upgraded. Version actuelle : v5.12.0 Ok, version suffisante /usr/share/nginx/www/jeedom/plugins/dashbutton/node `-- request@2.79.0 +-- aws-sign2@0.6.0 +-- aws4@1.6.0 +-- caseless@0.11.0 +-- combined-stream@1.0.5 | `-- delayed-stream@1.0.0 +-- extend@3.0.0 +-- forever-agent@0.6.1 +-- form-data@2.1.2 | `-- asynckit@0.4.0 +-- har-validator@2.0.6 | +-- chalk@1.1.3 | | +-- ansi-styles@2.2.1 | | +-- escape-string-regexp@1.0.5 | | +-- has-ansi@2.0.0 | | | `-- ansi-regex@2.1.1 | | +-- strip-ansi@3.0.1 | | `-- supports-color@2.0.0 | +-- commander@2.9.0 | | `-- graceful-readlink@1.0.1 | +-- is-my-json-valid@2.15.0 | | +-- generate-function@2.0.0 | | +-- generate-object-property@1.2.0 | | | `-- is-property@1.0.2 | | +-- jsonpointer@4.0.1 | | `-- xtend@4.0.1 | `-- pinkie-promise@2.0.1 | `-- pinkie@2.0.4 +-- hawk@3.1.3 | +-- boom@2.10.1 | +-- cryptiles@2.0.5 | +-- hoek@2.16.3 | `-- sntp@1.0.9 +-- http-signature@1.1.1 | +-- assert-plus@0.2.0 | +-- jsprim@1.3.1 | | +-- extsprintf@1.0.2 | | +-- json-schema@0.2.3 | | `-- verror@1.3.6 | `-- sshpk@1.10.2 | +-- asn1@0.2.3 | +-- assert-plus@1.0.0 | +-- bcrypt-pbkdf@1.0.1 | +-- dashdash@1.14.1 | | `-- assert-plus@1.0.0 | +-- ecc-jsbn@0.1.1 | +-- getpass@0.1.6 | | `-- assert-plus@1.0.0 | +-- jodid25519@1.0.2 | +-- jsbn@0.1.1 | `-- tweetnacl@0.14.5 +-- is-typedarray@1.0.0 +-- isstream@0.1.2 +-- json-stringify-safe@5.0.1 +-- mime-types@2.1.14 | `-- mime-db@1.26.0 +-- oauth-sign@0.8.2 +-- qs@6.3.1 +-- stringstream@0.0.5 +-- tough-cookie@2.3.2 | `-- punycode@1.4.1 +-- tunnel-agent@0.4.3 `-- uuid@3.0.1 npm WARN enoent ENOENT: no such file or directory, open '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/package.json' npm WARN node No description npm WARN node No repository field. npm WARN node No README data npm WARN node No license field. > socketwatcher@0.3.0 install /usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher > node-gyp rebuild gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/5.12.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher/.node-gyp" make: Entering directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher/build' CXX(target) Release/obj.target/socketwatcher/socket_watcher.o SOLINK_MODULE(target) Release/obj.target/socketwatcher.node COPY Release/socketwatcher.node make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/socketwatcher/build' > pcap@2.0.0 install /usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap > node-gyp rebuild gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/5.12.0" gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap/.node-gyp" make: Entering directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap/build' CXX(target) Release/obj.target/pcap_binding/pcap_binding.o CXX(target) Release/obj.target/pcap_binding/pcap_session.o SOLINK_MODULE(target) Release/obj.target/pcap_binding.node COPY Release/pcap_binding.node make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/node_modules/pcap/build' /usr/share/nginx/www/jeedom/plugins/dashbutton/node +-- node-dash-button@0.6.1 | +-- pcap@2.0.0 (git+https://github.com/mranney/node_pcap.git#d920204745c8b00ef4b7a3fe27d902b263cdb70f) | | +-- nan@2.5.1 | | `-- socketwatcher@0.3.0 | `-- underscore@1.8.3 `-- request@2.79.0 npm WARN enoent ENOENT: no such file or directory, open '/usr/share/nginx/www/jeedom/plugins/dashbutton/node/package.json' npm WARN node No description npm WARN node No repository field. npm WARN node No README data npm WARN node No license field.
Quelqu'un aurait-il une idée svp ?
Merci beaucoup
Sinon t'as le droit de le lire le message et chercher un peu, ca revient régulièrement donc c'est accessible en recherche donc cf la chartrevideohone a écrit :Après avoir refait une installation et enlever la liaison avec un produit j ai toujours le même message
Bonjourvideohone a écrit :Bonjour j ai un probleme avec mon dash
Les commandes passent bien sur amazon
Dépendances ok
Démon ok
Calling Jeedom http://:80/plugins/dashbutton/core/api/jeeDash.php?apikey=rbH0OTuyXZh3KuXfDLT9vDwAGK4kqOupeMJdlEMxchWGIKw7&uid=34-**:D2:70:E5:E5:9D
Sun Feb 26 2017 18:31:55 GMT+0100 (CET) - Error : Error: socket hang up
l'éternel soucis de ce forum, lire 42 pages qui répondront surement a ces questions par ci, par là.magicgg91 a écrit :Hello,
Toutes les réponses aux questions existentielles que tu te poses sur ce plugin et les boutons ont été données !
Des retours d'utilisateurs ? Ce sujet en est rempli, donc il te suffit de lire...
J'en ai plusieurs à la maison, mais un seul de configuré pour les Volets Roulants. (5e le premier contre une télécommande Somfy qui coutent un brasAntoinekl1 a écrit :serait il possible d'avoir des retours d'utilisateurs ? le fonctionnement est pleinement opérationnel ?
Aucune idée, mais au pire tu en prend un stock et tu le remplaceAntoinekl1 a écrit :durée de la batterie ?
Imagine que tu regarde ma maison de face, elle fait 14-15mètres de large de mémoire.Antoinekl1 a écrit : porté du wifi ?
Ca sera ma BA de la journéeAntoinekl1 a écrit :
