worxLandroidS
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 07:04
Rebonjour, la tondeuse remonte bien sur Jeedom mais je n'ai que les action, les infos ne se créent pas, comment faire ? Quel log et ou screen vous voulez ?
ssc
Re: worxLandroidS
Message par ssc » 22 mars 2019, 07:25
La tondeuse est sous tension et accessible depuis l'appli mobile ?
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 07:41
Yep, tout remonte bien sur l'app
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 07:59
[2019-03-22 07:13:16][INFO] : Connexion result :[{"id":61116,"product_id":19,"user_id":xxx,"serial_number":"xxx","mac_address":"xxx","name":"Pablo","purchase_date":"2018-06-27 00:00:00","warranty_expiration_date":"2020-06-27 00:00:00","setup_location":{"latitude":xxx,"longitude":xxx},"locked":false,"created_at":"2017-08-16 06:39:49","updated_at":"2019-03-22 00:07:04","firmware_version":5.18,"registration_date":"2019-03-21 10:25:05","firmware_auto_upgrade":false,"distance_covered":235471,"mower_work_time":10323,"blade_work_time":9151,"battery_charge_cycles":585,"messages_in":4,"messages_out":77,"push_notifications":true,"city_id":xxx,"push_notifications_level":"warning","lawn_size":800,"raw_messages_in":25,"raw_messages_out":77,"test":0,"iot_registered":true,"warranty_registered":true,"pin_code":"xxx","time_zone_id":52,"activated":true,"dealer_id":null,"activated_at":null,"sim_id":null,"app_settings":null,"city":{"id":xxx,"country_id":xxx,"name":"Le Many","latitude":xxx,"longitude"xxx"created_at":"2018-02-15 22:28:38","updated_at":"2018-02-15 22:28:38"},"time_zone":"Europe\/Brussels","online":true,"mqtt_topics":{"command_in":"DB504\/0023A7A633B6\/commandIn","command_out":"DB504\/0023A7A633B6\/commandOut"}}]
[2019-03-22 07:13:16][INFO] : board_id: 2 / product id:19
[2019-03-22 07:13:16][INFO] : mac_address xxx
[2019-03-22 07:13:16][INFO] : Saving device with mac addressxxx
[2019-03-22 07:13:16][INFO] : nouvelle action par défaut{"rd":"#message#"}
[2019-03-22 07:13:17][INFO] : nouvelle action par défautArray
[2019-03-22 07:13:17][INFO] : nouvelle action par défautoff_today
[2019-03-22 07:13:17][INFO] : nouvelle action par défauton_today
[2019-03-22 07:13:17][INFO] : nouvelle action par défaut0
[2019-03-22 07:13:17][INFO] : nouvelle action par défaut30
[2019-03-22 07:13:17][INFO] : nouvelle action par défaut60
[2019-03-22 07:13:17][INFO] : nouvelle action par défaut120
[2019-03-22 07:13:17][INFO] : nouvelle action par défaut240
[2019-03-22 07:13:17][INFO] : nouvelle action par défauton_0
[2019-03-22 07:13:18][INFO] : nouvelle action par défautoff_0
[2019-03-22 07:13:18][INFO] : nouvelle action par défauton_1
[2019-03-22 07:13:18][INFO] : nouvelle action par défautoff_1
[2019-03-22 07:13:18][INFO] : nouvelle action par défauton_2
[2019-03-22 07:13:18][INFO] : nouvelle action par défautoff_2
[2019-03-22 07:13:18][INFO] : nouvelle action par défauton_3
[2019-03-22 07:13:18][INFO] : nouvelle action par défautoff_3
[2019-03-22 07:13:18][INFO] : nouvelle action par défauton_4
[2019-03-22 07:13:18][INFO] : nouvelle action par défautoff_4
[2019-03-22 07:13:18][INFO] : nouvelle action par défauton_5
[2019-03-22 07:13:18][INFO] : nouvelle action par défautoff_5
[2019-03-22 07:13:19][INFO] : nouvelle action par défautoff_6
[2019-03-22 07:17:33][DEBUG] : Publication du message  stop Array
[2019-03-22 07:17:33][DEBUG] : 8 : Error: Unable to load client certificate "/var/www/html/plugins/worxLandroidS/resources/cert.pem".
[2019-03-22 07:17:33][DEBUG] : 8 : OpenSSL Error: error:0906D06C:PEM routines:PEM_read_bio:no start line
[2019-03-22 07:17:33][DEBUG] : 8 : OpenSSL Error: error:140DC009:SSL routines:SSL_CTX_use_certificate_chain_file:PEM lib
voila le log avec après un essai d'envoi d'une commande, aucune info remonte
EDIT : Après avoir envoyé la commande refresh j'ai toutes les infos qui remontent :)
ssc
Re: worxLandroidS
Message par ssc » 22 mars 2019, 08:15
Ok donc ça signifie qu'il n'a pas récupéré le certificat correctement.
Est-ce que c'est possible de cocher "Initialiser/réactualiser données cloud worx" et sauvegarder?
Ca permettra de récupérer à nouveau le certificat.
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 08:30
C'est ce que je faisais à chaque fois :/
Lors de la tonte, quand la tondeuse est au bout du jardin je perds la connexion wifi avec, quand elle revient, elle se reconnecte, ton plugin refais une tentative de connexion tous les combien de temps quand le statusDescription = Connection timeout ?
ssc
Re: worxLandroidS
Message par ssc » 22 mars 2019, 08:51
est-ce tu as tenté une suppression de l'équipement créé et recommencé l'initialisation?
ssc
Re: worxLandroidS
Message par ssc » 22 mars 2019, 08:56
En horaire de tonte, réactualisation toutes les 2 minutes et 30 en dehors.
Et le timeout arrive au bout de 45 secondes s'il n'y a pas de retour de la tondeuse.
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 09:02
ssc a écrit :
22 mars 2019, 08:51
Oui plusieurs fois,
même désinstallation et installation du plugin, relance des deps. Le seul truc qui à permis de recup toutes les infos à été l'envoi de la commande refresh dans les action disponible
ssc
Re: worxLandroidS
Message par ssc » 22 mars 2019, 09:13
HadesDT a écrit :
22 mars 2019, 09:02
ssc a écrit :
22 mars 2019, 08:51
Oui plusieurs fois,
je ne comprends pas, du coup tu as récupéré quelque chose? (par exemple le planning de tonte)
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 09:16
Toutes les infos sont remontées, les statuts, erreurs, batterie, agenda de tonte, batterie etc. Je comprends pas non plus.
ssc
Re: worxLandroidS
Message par ssc » 22 mars 2019, 10:13
Est ce que tu as bien les fichiers cert et pkey dans /var/www/html/plugins/worxLandroidS/resources?
/var/www/html/plugins/worxLandroidS/resources $ ls -l
total 64
-rwxrwxr-x 1 www-data www-data 1224 Mar 22 08:20 cert.pem
-rwxrwxr-x 1 www-data www-data 3317 Dec 16 07:14 install.sh
-rwxrwxr-x 1 www-data www-data 1704 Mar 22 08:20 pkey.pem
-rwxrwxr-x 1 www-data www-data 1142 Dec 16 07:14 remove.sh
-rwxrwxr-x 1 www-data www-data 1758 Dec 16 07:14 vs-ca.pem
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 10:49
Oui ils sont bien la
HadesDT
Re: worxLandroidS
Message par HadesDT » 22 mars 2019, 16:56
Ça se met à jour qu'une fois de temps en temps par contre, pendant la tonte programmée sur le schuduler de la tondeuse j'ai pas eu de mise a jour du statut. Ensuite a 15h30 j'ai eu une mise a jour, depuis plus rien dans les logs.
ssc
Re: worxLandroidS
Message par ssc » 22 mars 2019, 18:16
Ce qui est sûr c'est que lorsque la tondeuse perd le réseau, le plugin ne peut pas se mettre à jour et dans ce cas là peut être qu'il est en défaut.
Il faudrait que je fasse des essais.
paulnux
Re: worxLandroidS
Message par paulnux » 23 mars 2019, 23:43
Etant intéressé par l'achat d'une tondeuse dans la nouvelle gamme WR141E, WR142E, WR143E.
Ceux qui l'on acheté peuvent il nous faire un retour sur la compatibilité avec le plugin ?
Je vois aussi que vous achetez vos tondeuse sur myrobotcenter, c'est dans la normalité que les délais de livraison soit long ?
Jeedom Mini+, Zigate
Temp Xiaomi
Ouverture Xiaomi
Ampoule Ikea, Xiaomi
Détecteur mouvement Xiaomi
Pi3B+, ZStick GEN5, SENA UD100, Gateway Xiaomi
PSM02
FGMS-001
ZM1602
Ampoule Yeelight
Echo Plus
Nut mini
Balance Xiaomi
MiFlora
WorxLandroidS
Shyriu59
Re: worxLandroidS
Message par Shyriu59 » 25 mars 2019, 21:43
J’ai contacté le site et voici ce que j’ai obtenu ... ça fait maigre...
Merci pour votre courriel.
Il y a un léger retard de la part de notre fournisseur; de ce fait, votre colis n'a pas encore été expédié.
Ne vous en faites pas, nous expédierons votre colis au plus vite. Vous recevrez un lien de suivi par mail au moment de l'expédition.
Cordialement,
Anne-Claire Julie
Ventes
paulnux
Re: worxLandroidS
Message par paulnux » 25 mars 2019, 22:21
Shyriu59 a écrit :
25 mars 2019, 21:43
Tu a commandé quand ?
Temp Xiaomi
Ouverture Xiaomi
PSM02
FGMS-001
ZM1602
Ampoule Yeelight
Echo Plus
Nut mini
Balance Xiaomi
MiFlora
WorxLandroidS
Shyriu59
worxLandroidS
Message par Shyriu59 » 25 mars 2019, 22:35
Le 20/03 - y a 5 jours
Le site annonçait 48-72h...
J’ai tenté... :cry:
paulnux
Re: worxLandroidS
Message par paulnux » 26 mars 2019, 07:13
Mince moi qui voulait commander la WR143E, cela donne pas trop envie.
Je vais attendre vos retours
Sinon quelqu'un a commandé chez https://www.roboexpert.fr/Masterfeed/Wo ... -2019.html ?
Le M1000 est encore moins chers que chez robotcenter
Temp Xiaomi
Ouverture Xiaomi
PSM02
FGMS-001
ZM1602
Ampoule Yeelight
Echo Plus
Nut mini
Balance Xiaomi
MiFlora
WorxLandroidS
