Du coup avec la mise à jour tout fonctionne avec le online.
Par contre pas avec le local, même avec la conversion mp3
J'ai suivi ce que tu m'a dis et j'ai cette erreur :
root@jeedom:~/pico_build/svox-1.0+git20110131# sudo dpkg-buildpackage -rfakeroot -us -uc -d
dpkg-buildpackage: warning: using a gain-root-command while being root
dpkg-buildpackage: source package svox
dpkg-buildpackage: source version 1.0+git20110131-2
dpkg-buildpackage: source distribution unstable
dpkg-buildpackage: source changed by Samuel Thibault <sthibault@debian.org>
dpkg-buildpackage: host architecture armhf
dpkg-source --before-build svox-1.0+git20110131
fakeroot debian/rules clean
dh clean --sourcedirectory=pico
dh_testdir -O--sourcedirectory=pico
debian/rules override_dh_auto_clean
make[1]: Entering directory '/root/pico_build/svox-1.0+git20110131'
rm pico/pico2wave.1 ||:
rm: cannot remove ‘pico/pico2wave.1’: No such file or directory
cd pico && test -f Makefile && make clean ||:
chmod +x ./pico/autogen.sh
cd pico && ./autogen.sh clean
make[1]: Leaving directory '/root/pico_build/svox-1.0+git20110131'
dh_clean -O--sourcedirectory=pico
dpkg-source -b svox-1.0+git20110131
dpkg-source: info: using source format `3.0 (quilt)'
dpkg-source: info: building svox using existing ./svox_1.0+git20110131.orig.tar.gz
dpkg-source: info: building svox in svox_1.0+git20110131-2.debian.tar.xz
dpkg-source: info: building svox in svox_1.0+git20110131-2.dsc
debian/rules build
dh build --sourcedirectory=pico
debian/rules override_dh_auto_configure
aclocal: warning: autoconf input should be named 'configure.ac', not 'configure.in'
aclocal: error: couldn't open directory 'm4': No such file or directory
libtoolize: putting auxiliary files in `.'.
libtoolize: linking file `./ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
libtoolize: linking file `m4/libtool.m4'
libtoolize: linking file `m4/ltoptions.m4'
libtoolize: linking file `m4/ltsugar.m4'
libtoolize: linking file `m4/ltversion.m4'
libtoolize: linking file `m4/lt~obsolete.m4'
configure.in:7: error: possibly undefined macro: AM_INIT_AUTOMAKE
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
configure.in:11: error: possibly undefined macro: AC_PROG_LIBTOOL
automake: warning: autoconf input should be named 'configure.ac', not 'configure.in'
configure.in: error: no proper invocation of AM_INIT_AUTOMAKE was found.
configure.in: You should verify that configure.in invokes AM_INIT_AUTOMAKE,
configure.in: that aclocal.m4 is present in the top-level directory,
configure.in: and that aclocal.m4 was recently regenerated (using aclocal)
Makefile.am: installing './INSTALL'
Makefile.am: error: required file './NEWS' not found
Makefile.am: error: required file './README' not found
Makefile.am: error: required file './AUTHORS' not found
Makefile.am: error: required file './ChangeLog' not found
Makefile.am: installing './COPYING' using GNU General Public License v3 file
Makefile.am: Consider adding the COPYING file to the version control system
Makefile.am: for your code, to avoid questions about which license your project uses
Makefile.am:5: error: Libtool library used but 'LIBTOOL' is undefined
Makefile.am:5: The usual way to define 'LIBTOOL' is to add 'LT_INIT'
Makefile.am:5: to 'configure.in' and run 'aclocal' and 'autoconf' again.
Makefile.am:5: If 'LT_INIT' is in 'configure.in', make sure
Makefile.am:5: its definition is in aclocal's search path.
Makefile.am:6: warning: source file 'lib/picoacph.c' is in a subdirectory,
Makefile.am:6: but option 'subdir-objects' is disabled
automake: warning: possible forward-incompatibility.
automake: At least a source file is in a subdirectory, but the 'subdir-objects'
automake: automake option hasn't been enabled. For now, the corresponding output
automake: object file(s) will be placed in the top-level directory. However,
automake: this behaviour will change in future Automake versions: they will
automake: unconditionally cause object files to be placed in the same subdirectory
automake: of the corresponding sources.
automake: You are advised to start using 'subdir-objects' option throughout your
automake: project, to avoid future incompatibilities.
Makefile.am:6: warning: source file 'lib/picoapi.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picobase.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picocep.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picoctrl.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picodata.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picodbg.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picoextapi.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picofftsg.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picokdbg.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picokdt.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picokfst.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picoklex.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picoknow.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picokpdf.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picokpr.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picoktab.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picoos.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picopal.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picopam.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picopr.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picorsrc.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picosa.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picosig.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picosig2.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picospho.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picotok.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picotrns.c' is in a subdirectory,
Makefile.am:6: warning: source file 'lib/picowa.c' is in a subdirectory,
Makefile.am:83: warning: source file 'bin/pico2wave.c' is in a subdirectory,
Makefile.am:83: but option 'subdir-objects' is disabled
Makefile.am: installing './depcomp'
/usr/share/automake-1.14/am/depend2.am: error: am__fastdepCC does not appear in AM_CONDITIONAL
/usr/share/automake-1.14/am/depend2.am: The usual way to define 'am__fastdepCC' is to add 'AC_PROG_CC'
/usr/share/automake-1.14/am/depend2.am: to 'configure.in' and run 'aclocal' and 'autoconf' again
/usr/share/automake-1.14/am/depend2.am: error: AMDEP does not appear in AM_CONDITIONAL
/usr/share/automake-1.14/am/depend2.am: The usual way to define 'AMDEP' is to add one of the compiler tests
/usr/share/automake-1.14/am/depend2.am: AC_PROG_CC, AC_PROG_CXX, AC_PROG_OBJC, AC_PROG_OBJCXX,
/usr/share/automake-1.14/am/depend2.am: AM_PROG_AS, AM_PROG_GCJ, AM_PROG_UPC
Now run ./configure and then make.
cd pico && ./configure --prefix=/usr --libdir=\${prefix}/lib/arm-linux-gnueabihf
./configure: line 1776: syntax error near unexpected token `1.9'
./configure: line 1776: `AM_INIT_AUTOMAKE(1.9 foreign)'
debian/rules:22: recipe for target 'override_dh_auto_configure' failed
make[1]: *** [override_dh_auto_configure] Error 2
debian/rules:19: recipe for target 'build' failed
make: *** [build] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
Petite question ! Est-ce possible de dire une phrase puis de remettre l'entrée source local sur le sonos ou bien de revenir à l'état précédent ?
