Merci beaucoup !
Ca à fonctionné pour moi
Merci beaucoup !
[2019-10-31 17:47:28][ERROR] : ACTION------Error while playing action pause on default media controler : Namespace urn:x-cast:com.google.cast.media is not supported by runningapplication.
[2019-10-31 17:47:28][ERROR] : ACTION------Error while playing action play_media on app plex : Socket client's thread is stopped.
Unhandled exception in thread started by <function action_handler at 0x7fd5fcc03048>
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 978, in action_handler
player.play_media(command['resume_plexitem'], command['resume_plexserver'], {'offset':offset, 'type':type, 'shuffle':shuffle, 'repeat':repeat} )
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/customcontrollers/plex2.py", line 48, in play_media
callback_function=app_launched_callback)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/socket_client.py", line 815, in launch_app
self.update_status(lambda response:
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/socket_client.py", line 806, in update_status
callback_function=callback_function_param)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/controllers/__init__.py", line 84, in send_message
self.namespace, data, inc_session_id, callback_function)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/socket_client.py", line 611, in send_platform_message
inc_session_id, callback_function_param)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/socket_client.py", line 590, in send_message
raise PyChromecastStopped("Socket client's thread is stopped.")
pychromecast.pychromecast.error.PyChromecastStopped: Socket client's thread is stopped.
During handling of the above exception, another exception occurred:
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 989, in action_handler
jcast.manage_exceptions(str(e))
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 175, in manage_exceptions
self.disconnect()
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 378, in disconnect
self.free_memory()
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 386, in free_memory
del self.gcast
AttributeError: gcast
[2019-10-31 17:49:59][ERROR] : http://88.80.190.127:8443: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
[2019-10-31 17:50:15][ERROR] : http://176.58.109.167:8443: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
[2019-10-31 17:50:29][ERROR] : http://MONIPPUBLIQUECACHE:19574: HTTPConnectionPool(host='MONIPPUBLIQUECACHE', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x7fd5f31adb38>, 'Connection to MONIPPUBLIQUECACHE timed out. (connect timeout=30)'))
[2019-10-31 17:50:29][ERROR] : https://109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct:19574: HTTPSConnectionPool(host='109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fd5f3199b38>, 'Connection to 109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct timed out. (connect timeout=30)'))
[2019-10-31 17:50:45][ERROR] : https://109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct:19574: HTTPSConnectionPool(host='109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fd5f31c7e48>, 'Connection to 109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct timed out. (connect timeout=30)'))
[2019-10-31 17:50:45][ERROR] : http://MONIPPUBLIQUECACHE:19574: HTTPConnectionPool(host='MONIPPUBLIQUECACHE', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x7fd5f31c64a8>, 'Connection to MONIPPUBLIQUECACHE timed out. (connect timeout=30)'))
[2019-10-31 17:54:51][ERROR] : http://139.162.215.184:8443: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
[2019-10-31 17:54:54][ERROR] : http://88.80.186.253:8443: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
[2019-10-31 17:55:21][ERROR] : https://109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct:19574: HTTPSConnectionPool(host='109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fd5f316f4e0>, 'Connection to 109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct timed out. (connect timeout=30)'))
[2019-10-31 17:55:21][ERROR] : http://MONIPPUBLIQUECACHE:19574: HTTPConnectionPool(host='MONIPPUBLIQUECACHE', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x7fd5f3167908>, 'Connection to MONIPPUBLIQUECACHE timed out. (connect timeout=30)'))
[2019-10-31 17:55:24][ERROR] : https://109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct:19574: HTTPSConnectionPool(host='109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fd5f3040da0>, 'Connection to 109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct timed out. (connect timeout=30)'))
[2019-10-31 17:55:24][ERROR] : http://MONIPPUBLIQUECACHE:19574: HTTPConnectionPool(host='MONIPPUBLIQUECACHE', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x7fd5f304bda0>, 'Connection to MONIPPUBLIQUECACHE timed out. (connect timeout=30)'))
[2019-10-31 17:55:48][ERROR] : http://88.80.186.253:8443: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
[2019-10-31 17:56:18][ERROR] : http://MONIPPUBLIQUECACHE:19574: HTTPConnectionPool(host='MONIPPUBLIQUECACHE', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.HTTPConnection object at 0x7fd5f07d4518>, 'Connection to MONIPPUBLIQUECACHE timed out. (connect timeout=30)'))
[2019-10-31 17:56:18][ERROR] : https://109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct:19574: HTTPSConnectionPool(host='109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct', port=19574): Max retries exceeded with url: / (Caused by ConnectTimeoutError(<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7fd5f07cf470>, 'Connection to 109-29-228-235.119a5288f30a45b4a665dcdcefee4304.plex.direct timed out. (connect timeout=30)'))
[2019-10-31 17:59:08][ERROR] : ACTION------Error while playing action stop on default media controler : Namespace urn:x-cast:com.google.cast.media is not supported by runningapplication.
Un probleme de droit sur les dossiers surement.Hatalar a écrit : ↑06 nov. 2019, 14:33Hello, je me permets une question sans fouille au préalable, désolé.
Je viens de migrer mon Jeedom d'un raspeberry vers une Vm sous Promox (donc avec un backup). Depuis impossible d'envoyer une commande "parle".
J'ai aussi changé mon routeur/firewall (Tplink vers un Pfsense hardware) lors de cette migration.
Mais quand je regarde les logs on dirait plutôt un problème de répertoire ?
[2019-11-06 14:25:01][ERROR] : CMD-TTS------Google Translate API : Cannot connect to API - failover to picotts ([Errno 20] Not a directory: '/var/www/html/plugins/googlecast/tmp/4ad671d0c7ceaf45e74412a27787f7a7.mp3')
[2019-11-06 14:25:01][ERROR] : CMD-TTS------Exception while generating tts file : [Errno 20] Not a directory: '/var/www/html/plugins/googlecast/tmp/4ad671d0c7ceaf45e74412a27787f7a7_failover.wav'
[2019-11-06 14:27:40][ERROR] : WARMUPNOTIF------Exception while generating warmupn
Merci,
Hatalar
vincecoco a écrit :@Mguyard
Tu fais comment pour mettre la musique au moment du réveil avec la routine ?
InterressantMguyard a écrit :vincecoco a écrit :@Mguyard
wget -q https://ftp-master.debian.org/keys/release-10.asc -O- | sudo apt-key add -
echo "deb http://deb.debian.org/debian buster non-free" | sudo tee -a /etc/apt/sources.list
sudo apt-get update
sudo apt-get install libttspico-utils
Je parle sous buster..Rvitch a écrit :Pas moyen de faire marcher le TTS google?
Pico c'est pas WAF.
Merci ! ça fonctionne !cocapic a écrit : ↑30 nov. 2019, 11:33si jamais pas encore partagé, pour faire fonctionner tts sous pi4 buster :
wget -q https://ftp-master.debian.org/keys/release-10.asc -O- | sudo apt-key add - echo "deb http://deb.debian.org/debian buster non-free" | sudo tee -a /etc/apt/sources.list sudo apt-get update sudo apt-get install libttspico-utils
