Merci pour ton retour.
Mauvais élève que je suis, je n'ai pas pris le temps de vérifié ma version de Debian.
File "/usr/local/lib/python3.5/dist-packages/aiohttp/connector.py", line 924, in _wrap_create_connection
await self._loop.create_connection(*args, **kwargs))
File "/usr/lib/python3.5/asyncio/base_events.py", line 775, in create_connection
raise exceptions[0]
File "/usr/lib/python3.5/asyncio/base_events.py", line 762, in create_connection
yield from self.sock_connect(sock, address)
File "/usr/lib/python3.5/asyncio/selector_events.py", line 451, in sock_connect
return (yield from fut)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/asyncio/selector_events.py", line 481, in _sock_connect_cb
raise OSError(err, 'Connect call failed %s' % (address,))
OSError: [Errno 113] Connect call failed ('XXX.XXX.XXX.XXX', 8088)
The above exception was the direct cause of the following exception:
File "/var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py", line 641, in <module>
main()
File "/var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py", line 631, in main
sys.exit(args.func(args))
File "/var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py", line 340, in show_config
client = get_client(args.harmony_ip)
File "/var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py", line 56, in get_client
return run_in_loop_now('get_client', func)
File "/var/www/html/plugins/harmonyhub/core/class/../../3rdparty/PyHarmony/harmony/__main__.py", line 34, in run_in_loop_now
loop.run_until_complete(func_task)
File "/usr/lib/python3.5/asyncio/base_events.py", line 466, in run_until_complete
return future.result()
File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
result = coro.throw(exc)
File "/var/www/html/plugins/harmonyhub/3rdparty/PyHarmony/harmony/client.py", line 516, in create_and_connect_client
connected = await client.connect()
File "/var/www/html/plugins/harmonyhub/3rdparty/PyHarmony/harmony/client.py", line 141, in connect
await self._perform_connect()
File "/var/www/html/plugins/harmonyhub/3rdparty/PyHarmony/harmony/client.py", line 125, in _perform_connect
await self.retrieve_hub_info()
File "/var/www/html/plugins/harmonyhub/3rdparty/PyHarmony/harmony/client.py", line 102, in retrieve_hub_info
url, json=json_request, headers=headers) as response:
File "/usr/local/lib/python3.5/dist-packages/aiohttp/client.py", line 1005, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.5/dist-packages/aiohttp/client.py", line 476, in _request
timeout=real_timeout
File "/usr/local/lib/python3.5/dist-packages/aiohttp/connector.py", line 522, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.5/dist-packages/aiohttp/connector.py", line 854, in _create_connection
File "/usr/local/lib/python3.5/dist-packages/aiohttp/connector.py", line 992, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.5/dist-packages/aiohttp/connector.py", line 974, in _create_direct_connection
req=req, client_error=client_error)
File "/usr/local/lib/python3.5/dist-packages/aiohttp/connector.py", line 931, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host XXX.XXX.XXX.XXX:8088 ssl:None [Connect call failed ('XXX.XXX.XXX.XXX', 8088)]
raise exceptions[0]
future.result()
main()
raise last_exc
raise exceptions[0]
future.result()
main()
raise last_exc
J'ai volontairement caché l'IP dans les logs (des fois que certains pensent que j'ai mis XXX.XXX.XXX.XXX dans ma conf'
Après je ne comprends pas les erreurs...
