[Plugin Officiel][Sujet Principal] Harmony Hub
- Timide
Re: [Sujet officiel] - Harmony Hub
Voici les logs apres un reboot du hub harmony:
28-09-2015 13:18:12 | debug | L'activité id est : HARMONY COMMUNICATION LOGIN : FAILUREERROR : swapAuthorizationToken : Communication failure et son nom est N/A
28-09-2015 13:19:11 | debug | L'activité id est : HARMONY COMMUNICATION LOGIN : FAILUREERROR : swapAuthorizationToken : Communication failure et son nom est N/A
28-09-2015 13:20:05 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:20:07 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:20:21 | debug | Sortie console : {"device" : [{"name" :"Ampli Onkyo","id" :"29269695","commands":["Power Off@$@PowerOff","Power On@$@PowerOn","Power Toggle@$@StandBy/ON","0@$@0","1@$@1","2@$@2","3@$@3","4@$@4","5@$@5","6@$@6","7@$@7","8@$@8","9@$@9","Mute@$@Mute","Volume Down@$@VolumeDown","Volume Up@$@VolumeUp","Direction Down@$@DirectionDown","Direction Left@$@DirectionLeft","Direction Right@$@DirectionRight","Direction Up@$@DirectionUp","Select@$@Enter","Return@$@Return","Prev Preset@$@PresetPrev","Next Preset@$@PresetNext","Direct Tune@$@DirectTune","Setup@$@Setup","Sleep@$@Sleep","Display@$@Display","ChannelSelect@$@ChannelSelect","Dimmer@$@Dimmer","InputAux@$@InputAux","InputCbl/Sat@$@InputCbl/Sat","InputCd@$@InputCd","InputDvd@$@InputDvd","InputGame/Tv@$@InputGame/Tv","InputMultiChannel@$@InputMultiChannel","InputTape@$@InputTape","InputTuner@$@InputTuner","InputVcr/Dvr@$@InputVcr/Dvr","LevelDown@$@LevelDown","LevelUp@$@LevelUp","ListeningModeAllStereo@$@ListeningModeAllStereo","ListeningModeCinemaFilter@$@ListeningModeCinemaFilter","ListeningModeDown@$@ListeningModeDown","ListeningModeLateNight@$@ListeningModeLateNight","ListeningModeStereo@$@ListeningModeStereo","ListeningModeSurround@$@ListeningModeSurround","ListeningModeUp@$@ListeningModeUp","TestTone@$@TestTone"]},{"name" :"TV Panasonic","id" :"29269677","commands":["Power Off@$@PowerOff","Power On@$@PowerOn","Power Toggle@$@PowerToggle","0@$@0","1@$@1","2@$@2","3@$@3","4@$@4","5@$@5","6@$@6","7@$@7","8@$@8","9@$@9","Mute@$@Mute","Volume Down@$@VolumeDown","Volume Up@$@VolumeUp","Channel Down@$@ChannelDown","Channel Up@$@ChannelUp","Direction Down@$@DirectionDown","Direction Left@$@DirectionLeft","Direction Right@$@DirectionRight","Direction Up@$@DirectionUp","Select@$@OK","Return@$@Return","Menu@$@Menu","Subtitle@$@Subtitles","Teletext@$@Teletext","Green@$@Green","Red@$@Red","Blue@$@Blue","Yellow@$@Yellow","Guide@$@Guide","Info@$@Info","Exit@$@Exit","Aspect@$@Aspect","AV@$@AV","Hold@$@Hold","I/II@$@I/II","Index@$@Index","InputHdmi1@$@InputHdmi1","InputHdmi2@$@InputHdmi2","InputHDMI3@$@InputHDMI3","InputPc@$@InputPc","InputVideo1@$@InputVideo1","InputVideo2@$@InputVideo2","InputVideo3@$@InputVideo3","InputVideo4@$@InputVideo4","MultiPiP@$@MultiPiP","Option@$@Option","SdCard@$@SdCard","SoundSelect@$@SoundSelect","Surround@$@Surround","TV@$@TV","VieraLink@$@VieraLink"]},{"name" :"Wii","id" :"29269718","commands":["Power Toggle@$@PowerToggle","Direction Down@$@DirectionDown","Direction Left@$@DirectionLeft","Direction Right@$@DirectionRight","Direction Up@$@DirectionUp","A@$@A","B@$@B","+@$@+","-@$@-","1@$@1","2@$@2","Disconnect Wii@$@Disconnect Wii","Home@$@Home","Trackpad@$@Trackpad"]},{"name" :"SCIMO 1.1","id" :"29605566","commands":["Power Off@$@PowerOff","Power On@$@PowerOn","Power Toggle@$@PowerToggle","*@$@-","0@$@0","1@$@1","2@$@2","3@$@3","4@$@4","5@$@5","6@$@6","7@$@7","8@$@8","9@$@9","Mute@$@Mute","Volume Down@$@VolumeDown","Volume Up@$@VolumeUp","Prev Channel@$@ChannelPrev","Channel Down@$@ChannelDown","Channel Up@$@ChannelUp","Direction Down@$@DirectionDown","Direction Left@$@DirectionLeft","Direction Right@$@DirectionRight","Direction Up@$@DirectionUp","Select@$@Select","Stop@$@Stop","Play@$@Play","Rewind@$@Rewind","Pause@$@Pause","Fast Forward@$@FastForward","Return@$@Return","Menu@$@Menu","Favorite@$@Favorite","List@$@List","Green@$@Green","Red@$@Red","Blue@$@Blue","Yellow@$@Yellow","Info@$@Info","Page Down@$@PageDown","Page Up@$@PageUp","Exit@$@Exit","Aspect@$@Aspect","AvMode@$@AvMode","EnergySaving@$@EnergySaving","Freeze@$@Freeze","InputAv1@$@InputAv1","InputAv2@$@InputAv2","InputComponent1@$@InputComponent1","InputComponent2@$@InputComponent2","InputHdmi1@$@InputHdmi1","InputHdmi2@$@InputHdmi2","InputHdmi3@$@InputHdmi3","InputNext@$@InputNext","InputRgb-Pc@$@InputRgb-Pc","InputTv@$@InputTv","Q.Menu@$@Q.Menu","Ratio16:9@$@Ratio16:9","Ratio4:3@$@Ratio4:3","RatioZoom@$@RatioZoom","SimpLink@$@SimpLink","TvVideo@$@TvVideo"]},{"name" :"Bbox Miami","id" :"29269703","commands":["Power Toggle@$@PowerToggle","0@$@0","1@$@1","2@$@2","3@$@3","4@$@4","5@$@5","6@$@6","7@$@7","8@$@8","9@$@9","Mute@$@Mute","Volume Down@$@VolumeDown","Volume Up@$@VolumeUp","Prev Channel@$@ChannelPrev","Channel Down@$@ChannelDown","Channel Up@$@ChannelUp","Direction Down@$@DirectionDown","Direction Left@$@DirectionLeft","Direction Right@$@DirectionRight","Direction Up@$@DirectionUp","Select@$@OK","Play@$@Play","Pause@$@Pause","Record@$@Record","Return@$@Return","Guide@$@Guide","GoogleTV@$@GoogleTV","Home@$@Home","Keyboard@$@Keyboard"]},{"name" :"Switch HDMI","id" :"29272559","commands":["AV1@$@AV1","AV2@$@AV2","AV3@$@AV3","AV4@$@AV4","AV5@$@AV5"]},{"name" :"Sony PS3","id" :"29269722","commands":["Power Off@$@PowerOff","Power On@$@PowerOn","+@$@-/--",".@$@.","0@$@0","1@$@1","2@$@2","3@$@3","4@$@4","5@$@5","6@$@6","7@$@7","8@$@8","9@$@9","Channel Down@$@ChannelDown","Channel Up@$@ChannelUp","Direction Down@$@DirectionDown","Direction Left@$@DirectionLeft","Direction Right@$@DirectionRight","Direction Up@$@DirectionUp","Select@$@Enter","Stop@$@Stop","Play@$@Play","Rewind@$@ScanPrev","Eject@$@Eject","Pause@$@Pause","Fast Forward@$@ScanNext","Skip Backward@$@Prev","Skip Forward@$@Next","Return@$@Return","Top Menu@$@TopMenu","Menu@$@Popup/Menu","Subtitle@$@Subtitle","Audio@$@Audio","Angle@$@Angle","Cross@$@Cross","Circle@$@Circle","Square@$@Square","Triangle@$@Triangle","Green@$@Green","Red@$@Red","Blue@$@Blue","Yellow@$@Yellow","Display@$@Display","InstantLeft@$@InstantLeft","InstantRight@$@InstantRight","L1@$@L1","L2@$@L2","L3@$@L3","PS@$@PS","PSHold@$@PSHold","R1@$@R1","R2@$@R2","R3@$@R3","Select0@$@Select","SlowNext@$@SlowNext","SlowPrev@$@SlowPrev","Start@$@Start","Time@$@Time"]},{"name" :"Apple TV","id" :"29271993","commands":["Mute@$@Mute","Volume Down@$@VolumeDown","Volume Up@$@VolumeUp","Channel Down@$@ChannelDown","Channel Up@$@ChannelUp","Direction Down@$@DirectionDown","Direction Left@$@DirectionLeft","Direction Right@$@DirectionRight","Direction Up@$@DirectionUp","Select@$@Select","Stop@$@Stop","Play@$@Play","Rewind@$@Rewind","Pause@$@Pause","Fast Forward@$@FastForward","Skip Backward@$@SkipBack","Skip Forward@$@SkipForward","Menu@$@Menu","Back@$@Back","Page Down@$@PageDown","Page Up@$@PageUp","Backspace@$@Delete","Home@$@Home","NextChapter@$@NextChapter","Pair@$@Pair","PrevChapter@$@PrevChapter","Reset@$@Reset","UnPair@$@UnPair","VideoMode@$@VideoMode"]}],"activity":[{"name" :"Écouter de la musique","id" :"15563379"},{"name" :"Regarder Apple TV","id" :"15563363"},{"name" :"PowerOff","id" :"-1"},{"name" :"Regarder la TV","id" :"15563282"},{"name" :"Regarder Kodi","id" :"15588643"},{"name" :"Jouer à Wii","id" :"15563311"},{"name" :"Jouer à PS3","id" :"15563341"}]}
28-09-2015 13:20:47 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:21:04 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:21:06 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:22:04 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:22:05 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:23:05 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:23:06 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:24:04 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:24:05 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:26:08 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:26:10 | debug | L'activité id est : -1 et son nom est PowerOff
28-09-2015 13:31:25 | debug | L'activité id est : HARMONY COMMUNICATION LOGIN : FAILUREERROR : swapAuthorizationToken : Communication failure et son nom est N/A
Petit souci pour moi je n'arrive pas a récupérer les appareils ni même les activité.
Je viens de faire une clean install sous debian8 sur un ancien pc tout roule sauf cela.
J'ai rien dans les log harmony mai j'ai sa dans le log cron execution
Stéphane
merci d'avance pour vos lumièrePHP Notice: Undefined variable: _last_declencheur in /usr/share/nginx/www/jeedom/plugins/presence/core/class/presence.class.php on line 2112
PHP Warning: Invalid argument supplied for foreach() in /usr/share/nginx/www/jeedom/plugins/harmonyhub/core/class/harmonyhub.class.php on line 111
Stéphane
Odroid C2 en prod
- Actif
Suis en stable... Tout allé bien jusqu'à d'un coup avoir N/A dans activité courante (ca doit faire 2/3 jours)... alors que les commandes fonctionnes toujours bien ?
J'ai redémarré le hub, sychronisé, quand je vais sur un autre module genre tablet ou telephone avec l'application d'installé j'ai bien le retour de l'activité en cours...
Que dois je faire ???
Odroid C2
Razberry / RFXCOM / Teleinfo / MyFox HC2 / ESP8266
Just Have Fun
Just Have Fun
- Timide
le problème semble résolut chez moi.
J'ai réinitialisé la télécommande et le hub.
Cordialement
Cordialement
je me posais la question quand je lance l'installation des dépendances j'ai ca:
Apres quand je lance la création de la config j'ai une fenêtre qui s'ouvre mais rien d'autre aucun message meme après 10min d'attente.
Normale ou pas?########### Compilation en cours ##########
make: 'HarmonyHubControl' is up to date.
Ign cdrom://[Debian GNU/Linux 8.2.0 _Jessie_ - Official Multi-architecture i386/amd64/source DVD #1 20150906-15:30] jessie InRelease
Ign cdrom://[Debian GNU/Linux 8.2.0 _Jessie_ - Official Multi-architecture i386/amd64/source DVD #1 20150906-15:30] jessie Release.gpg
Ign cdrom://[Debian GNU/Linux 8.2.0 _Jessie_ - Official Multi-architecture i386/amd64/source DVD #1 20150906-15:30] jessie/main Sources/DiffIndex
Ign cdrom://[Debian GNU/Linux 8.2.0 _Jessie_ - Official Multi-architecture i386/amd64/source DVD #1 20150906-15:30] jessie/main amd64 Packages/DiffIndex
Ign http://ftp.fr.debian.org jessie InRelease
Hit http://security.debian.org jessie/updates InRelease
Get:1 http://ftp.fr.debian.org jessie-updates InRelease [128 kB]
Hit http://security.debian.org jessie/updates/main Sources
Hit http://security.debian.org jessie/updates/main amd64 Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://ftp.fr.debian.org jessie Release.gpg
Get:2 http://ftp.fr.debian.org jessie-updates/main Sources [2296 B]
Get:3 http://ftp.fr.debian.org jessie-updates/main amd64 Packages [3452 B]
Get:4 http://ftp.fr.debian.org jessie-updates/main Translation-en [2506 B]
Hit http://ftp.fr.debian.org jessie/main Sources
Hit http://ftp.fr.debian.org jessie/main amd64 Packages
Hit http://ftp.fr.debian.org jessie/main Translation-en
Hit https://deb.nodesource.com jessie InRelease
Hit http://ftp.fr.debian.org jessie/main Translation-fr
Hit https://deb.nodesource.com jessie/main Sources
Hit https://deb.nodesource.com jessie/main amd64 Packages
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:6 https://deb.nodesource.com jessie/main Translation-fr [162 B]
Get:7 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:8 https://deb.nodesource.com jessie/main Translation-fr [162 B]
Get:9 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:10 https://deb.nodesource.com jessie/main Translation-fr [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:12 https://deb.nodesource.com jessie/main Translation-fr [162 B]
Get:13 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Get:14 https://deb.nodesource.com jessie/main Translation-fr [162 B]
Ign https://deb.nodesource.com jessie/main Translation-fr
Fetched 136 kB in 4s (31.8 kB/s)
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
sudo: pip: command not found
########### Fin ##########
Odroid C2 en prod
Coucou, j'ai du mal a trouver réponse a 2 question :
Si j'ai une ultimate avec un hub relié a jeedom avec le plugin, si je lance un scénario "regarder bluray" depuis jeedom, la télécommande sait qu'un scénario a été lancé ?
Et si après le film, avec la télécommande je change de scénario pour passer sur "écouter la radio", Jeedom est il au courant du changement de scenario ?
- Timide
oui et oui
rapidement pour la question 1 et nettement moins rapidement pour la question 2
(de l'ordre de la minute pour la 2 en fait)
Salut,sarakha63 a écrit :J'ai deja repondu dessus pourtant. Ils ne sont pas donné par l'api. Donc en attendant la nouvelle Api logitech (qui normalement arrive) je ne peux pas
Pas de news sur la nouvelle API Logitech ?
Intéressant ! J'avais peur que les fonctions "intelligentes" qui arrêtent les bons appareils et changent les sources pour le nouveau scénario ne marchent plus, mais si tout communique, c'est tout bon du coup ?stravinsky a écrit :oui et oui
rapidement pour la question 1 et nettement moins rapidement pour la question 2![]()
Merci !
Au début j’envisageai de prendre que le HUB, mais avoir tablette/smartphone sur jeedom pour gérer le son par exemple me parait un peu pas WAF du tout ... (et pas pratique), du coup l'ultimate + hub étant en promo je me tâte sévère !
http://www.amazon.fr/gp/product/B00C80J ... FK5RDHNB96 @ 149ۍa ce refuse pas, si ?
Pour l'historique, j'ai une des Harmony One (1ere version), et franchement, c'est génial leur système ! Bon, la batterie commence a plus trop tenir (elle tient 2 jours grand max).
un petit up pour mon PB car je n'arrive pas a refaire fonctionner le pluginsilverman a écrit :Petit souci pour moi je n'arrive pas a récupérer les appareils ni même les activité.
Stéphane
Odroid C2 en prod
j'ai vu que le plugin permettait d'envoyer les infos à la telecommande/hub harmony (ça je vais acheter et tester). Par contre, vu que la telecommande harmony est connecté en wifi (/compatible IFTTT) est-ce qu'il est possible de piloter jeedom via des requêtes http?
Je ne trouve pas sur la télécommande ou le logiciel de moyen d'envoyer une requête alors qu'elle semble être capable d'en recevoir??
Jeedom Mini & Rfxcom
Zwave/X10/Mysensor/Chacon DI-O/CurrentCost Envir/Netatmo
J'ai une question plus concrète sur le plugin. Je l'ai installé sur une mini. Pas de souci à l'installation ni au déploiement des dépendances.
Par contre, la recherche d'équipement reste sur un écran vide mais ne créé rien.
Dans les logs, la seule erreur que j'ai trouvé est dans l'execution du cron :
je suis dans le meme cas que toi
mais j'ai aussi se message d'erreur dans Nginx error
Attendons de voir se que nous dit sarakha63PHP message: PHP Warning: Invalid argument supplied for foreach() in /usr/share/nginx/www/jeedom/plugins/harmonyhub/core/class/harmonyhub.class.php on line 89" while reading response header from upstream, client: 192.168.0.14, server: , request: "POST /jeedom/plugins/harmonyhub/core/ajax/harmonyhub.ajax.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "192.168.0.40", referrer: "http://192.168.0.40/jeedom/index.php?v=d&p=plugin"
Odroid C2 en prod
Je suis dégouté, je l'ai même pas déballé qu'elle a baissé a 134€
lol...
Et moi je l'ai payé 180€ il y a quelques mois.
Elle est passée à 188€ là ...
Amazon m'a filé un coupon de la différence entre ce que j'avais payé et le prix d'hier (je l'avais reçu avant hier ma commande à 149€...).
Me tarde d'essayer tout ça, mais j'ai peu de temps
Je viens d'installer le plugin en version beta mais ça fait pareil que la dernière stable (les dates sont les mêmes mais dans le doute ...). J'ai le texte Recherche qui apparait, disparait et plus rien dans la fenêtre. Je l'ai déjà laissé tourner plusieurs heures donc pas un souci d'attente.
Il faut que tu active les log pour voir les messages (cf mes messages precedents).jbval a écrit :Je viens d'installer le plugin en version beta mais ça fait pareil que la dernière stable (les dates sont les mêmes mais dans le doute ...). J'ai le texte Recherche qui apparait, disparait et plus rien dans la fenêtre. Je l'ai déjà laissé tourner plusieurs heures donc pas un souci d'attente.
Par contre ca ne marche toujours pas chez moi, je ne suis pas contre un peu de support car on semble pas mal dans le même cas....
J'ai activé les logs debug, il va jusqu'au bout en effet et sans erreur :
09-10-2015 20:09:52 | debug | ######### Dispositifs trouvés |
09-10-2015 20:09:52 | debug | ######### Activités trouvées |
#### Fin de l'opération####
Mais je n'ai rien dans la liste des activités.
- aragornier
- Actif
Il m'est déjà arrivé la même chose et j'ai du réinstaller les dépendances, tu as essayé ?jbval a écrit :J'ai activé les logs debug, il va jusqu'au bout en effet et sans erreur :
JEEDOM POWER
3 jeedom sur RPI3 + 1 GEN8 pour VM et stockage
26 modules Zwave + 12 modules Rfxcom + 9 modules Xiaomi Home + téléinfo + 2 kodi + 4 cam IP + 1 hub harmony + 1 orvibo + 4 prises S20 , ect...
