j'ai je plugin dakin depuis le debut et 5 untitée dessus tout fonctionne bien mais en regardant mes logs je contate regulierment des erreurs php
voici les erreurs
PHP Strict Standards: Non-static method DaikinOnlineCtrlTools::requestToArray() should not be called statically in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 226
PHP Deprecated: Non-static method olindoteToolsDOC::setHealthNetwork() should not be called statically, assuming $this from incompatible context in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 1140
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::requestToArray() should not be called statically, assuming $this from incompatible context in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 990
PHP Deprecated: Non-static method DaikinOnlineCtrlTools::requestToArray() should not be called statically, assuming $this from incompatible context in /var/www/html/plugins/DaikinOnlineCtrl/core/class/DaikinOnlineCtrl.class.php on line 1103
PHP Warning: Division by zero in /var/www/html/plugins/roomba/core/class/roomba.class.php on line 266
merci d'avance
fred
