Publié : 22 déc. 2018, 21:41
par karad0
Tout est ouvert.
J'arrive à récupérer deux trois truc avec l'api, via le terminal sur os x
Mais pour le reste, je laisse faire les pro
result[0].data[0].category = alarm
result[0].data[0].ep_id = 11
result[0].data[0].label = État de l'alarme
result[0].data[0].name = state
result[0].data[0].refresh = 2000
result[0].data[0].signal_id = 11
result[0].data[0].ui.access = r
result[0].data[0].ui.display = text
result[0].data[0].ui.icon_url = /resources/images/home/pictos/sirene.png
result[0].data[0].ui = {"access":r,"display":text,"icon_url":/resources/images/home/pictos/sirene.png}
result[0].data[0].value = idle
result[0].data[0].value_type = string
result[0].data[0] = {"category":alarm,"ep_id":11,"label":État de l'alarme,"name":state,"refresh":2000,"signal_id":11,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/sirene.png},"value":idle,"value_type":string}
result[0].data[1].category = alarm
result[0].data[1].ep_id = 1
result[0].data[1].label = Alarme principale
result[0].data[1].name = alarm1
result[0].data[1].slot_id = 1
result[0].data[1].ui.access = w
result[0].data[1].ui.display = button
result[0].data[1].ui.icon_url = /resources/images/home/pictos/alarm_1.png
result[0].data[1].ui = {"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_1.png}
result[0].data[1].value = null
result[0].data[1].value_type = void
result[0].data[1] = {"category":alarm,"ep_id":1,"label":Alarme principale,"name":alarm1,"slot_id":1,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_1.png},"value":null,"value_type":void}
result[0].data[2].category = alarm
result[0].data[2].ep_id = 2
result[0].data[2].label = Alarme secondaire
result[0].data[2].name = alarm2
result[0].data[2].slot_id = 2
result[0].data[2].ui.access = w
result[0].data[2].ui.display = button
result[0].data[2].ui.icon_url = /resources/images/home/pictos/alarm_2.png
result[0].data[2].ui = {"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_2.png}
result[0].data[2].value = null
result[0].data[2].value_type = void
result[0].data[2] = {"category":alarm,"ep_id":2,"label":Alarme secondaire,"name":alarm2,"slot_id":2,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_2.png},"value":null,"value_type":void}
result[0].data[3].category = alarm
result[0].data[3].ep_id = 4
result[0].data[3].label = Désactiver l'alarme
result[0].data[3].name = off
result[0].data[3].slot_id = 4
result[0].data[3].ui.access = w
result[0].data[3].ui.display = button
result[0].data[3].ui.icon_url = /resources/images/home/pictos/alarm_off.png
result[0].data[3].ui = {"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_off.png}
result[0].data[3].value = null
result[0].data[3].value_type = void
result[0].data[3] = {"category":alarm,"ep_id":4,"label":Désactiver l'alarme,"name":off,"slot_id":4,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_off.png},"value":null,"value_type":void}
result[0].data[4].category = alarm
result[0].data[4].ep_id = 3
result[0].data[4].label = Passer le délai
result[0].data[4].name = skip
result[0].data[4].slot_id = 3
result[0].data[4].ui.access = w
result[0].data[4].ui.display = button
result[0].data[4].ui.icon_url = /resources/images/home/pictos/zone_temporisee.png
result[0].data[4].ui = {"access":w,"display":button,"icon_url":/resources/images/home/pictos/zone_temporisee.png}
result[0].data[4].value = null
result[0].data[4].value_type = void
result[0].data[4] = {"category":alarm,"ep_id":3,"label":Passer le délai,"name":skip,"slot_id":3,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/zone_temporisee.png},"value":null,"value_type":void}
result[0].data[5].ep_id = 5
result[0].data[5].label = Code PIN
result[0].data[5].name = pin
result[0].data[5].refresh = 2000
result[0].data[5].signal_id = 12
result[0].data[5].slot_id = 5
result[0].data[5].ui.access = rw
result[0].data[5].ui.display = text
result[0].data[5].ui = {"access":rw,"display":text}
result[0].data[5].value = 3698
result[0].data[5].value_type = string
result[0].data[5] = {"ep_id":5,"label":Code PIN,"name":pin,"refresh":2000,"signal_id":12,"slot_id":5,"ui":{"access":rw,"display":text},"value":3698,"value_type":string}
result[0].data[6].category = alarm
result[0].data[6].ep_id = 13
result[0].data[6].label = Erreur
result[0].data[6].name = error
result[0].data[6].refresh = 2000
result[0].data[6].signal_id = 13
result[0].data[6].ui.access = r
result[0].data[6].ui.display = text
result[0].data[6].ui.icon_url = /resources/images/home/pictos/warning.png
result[0].data[6].ui = {"access":r,"display":text,"icon_url":/resources/images/home/pictos/warning.png}
result[0].data[6].value =
result[0].data[6].value_type = string
result[0].data[6] = {"category":alarm,"ep_id":13,"label":Erreur,"name":error,"refresh":2000,"signal_id":13,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/warning.png},"value":,"value_type":string}
result[0].data = [{"category":alarm,"ep_id":11,"label":État de l'alarme,"name":state,"refresh":2000,"signal_id":11,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/sirene.png},"value":idle,"value_type":string},{"category":alarm,"ep_id":1,"label":Alarme principale,"name":alarm1,"slot_id":1,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_1.png},"value":null,"value_type":void},{"category":alarm,"ep_id":2,"label":Alarme secondaire,"name":alarm2,"slot_id":2,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_2.png},"value":null,"value_type":void},{"category":alarm,"ep_id":4,"label":Désactiver l'alarme,"name":off,"slot_id":4,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_off.png},"value":null,"value_type":void},{"category":alarm,"ep_id":3,"label":Passer le délai,"name":skip,"slot_id":3,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/zone_temporisee.png},"value":null,"value_type":void},{"ep_id":5,"label":Code PIN,"name":pin,"refresh":2000,"signal_id":12,"slot_id":5,"ui":{"access":rw,"display":text},"value":3698,"value_type":string},{"category":alarm,"ep_id":13,"label":Erreur,"name":error,"refresh":2000,"signal_id":13,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/warning.png},"value":,"value_type":string}]
result[0].ep_type = slot
result[0].group.icon_url =
result[0].group.label = Bureau
result[0].group = {"icon_url":,"label":Bureau}
result[0].node_id = 6
result[0].type = alarm_control
result[0] = {"data":[{"category":alarm,"ep_id":11,"label":État de l'alarme,"name":state,"refresh":2000,"signal_id":11,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/sirene.png},"value":idle,"value_type":string},{"category":alarm,"ep_id":1,"label":Alarme principale,"name":alarm1,"slot_id":1,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_1.png},"value":null,"value_type":void},{"category":alarm,"ep_id":2,"label":Alarme secondaire,"name":alarm2,"slot_id":2,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_2.png},"value":null,"value_type":void},{"category":alarm,"ep_id":4,"label":Désactiver l'alarme,"name":off,"slot_id":4,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_off.png},"value":null,"value_type":void},{"category":alarm,"ep_id":3,"label":Passer le délai,"name":skip,"slot_id":3,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/zone_temporisee.png},"value":null,"value_type":void},{"ep_id":5,"label":Code PIN,"name":pin,"refresh":2000,"signal_id":12,"slot_id":5,"ui":{"access":rw,"display":text},"value":3698,"value_type":string},{"category":alarm,"ep_id":13,"label":Erreur,"name":error,"refresh":2000,"signal_id":13,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/warning.png},"value":,"value_type":string}],"ep_type":slot,"group":{"icon_url":,"label":Bureau},"node_id":6,"type":alarm_control}
result = [{"data":[{"category":alarm,"ep_id":11,"label":État de l'alarme,"name":state,"refresh":2000,"signal_id":11,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/sirene.png},"value":idle,"value_type":string},{"category":alarm,"ep_id":1,"label":Alarme principale,"name":alarm1,"slot_id":1,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_1.png},"value":null,"value_type":void},{"category":alarm,"ep_id":2,"label":Alarme secondaire,"name":alarm2,"slot_id":2,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_2.png},"value":null,"value_type":void},{"category":alarm,"ep_id":4,"label":Désactiver l'alarme,"name":off,"slot_id":4,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/alarm_off.png},"value":null,"value_type":void},{"category":alarm,"ep_id":3,"label":Passer le délai,"name":skip,"slot_id":3,"ui":{"access":w,"display":button,"icon_url":/resources/images/home/pictos/zone_temporisee.png},"value":null,"value_type":void},{"ep_id":5,"label":Code PIN,"name":pin,"refresh":2000,"signal_id":12,"slot_id":5,"ui":{"access":rw,"display":text},"value":3698,"value_type":string},{"category":alarm,"ep_id":13,"label":Erreur,"name":error,"refresh":2000,"signal_id":13,"ui":{"access":r,"display":text,"icon_url":/resources/images/home/pictos/warning.png},"value":,"value_type":string}],"ep_type":slot,"group":{"icon_url":,"label":Bureau},"node_id":6,"type":alarm_control}]
success = true
