Le plugin Flower Power BT est installé sur mon Jeedom sur une machine virtuelle (ESXI).
Je suis dans le meme cas que delscate, mes Flower power ne sont pas détecté et j’ai des erreurs semblables dans les logs.
J’ai également essayé cette manip de cyber451, mais ça ne change rien
sudo apt-get remove npm
git clone git://github.com/isaacs/npm.git
cd npm/scripts
chmod +x install.sh
sudo ./install.sh
npm install graceful-fs
Debian Jessie 5.6.12-0+deb8u1
Jeedom v1.205
nodejs 0.127
npm 2.14.2
Module bleutooth Trendnet TBW-106UB.
hciconfig -a
hci0: Type: BR/EDR Bus: USB
BD Address: 00:15:83:E4:19:C3 ACL MTU: 310:10 SCO MTU: 64:8
UP RUNNING PSCAN
RX bytes:2884 acl:0 sco:0 events:151 errors:0
TX bytes:2837 acl:0 sco:0 commands:150 errors:0
Features: 0xff 0xff 0x8f 0xfe 0xdb 0xff 0x5b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF PARK
Link mode: SLAVE ACCEPT
Class: 0x000100
Service Classes: Unspecified
Device Class: Computer, Uncategorized
HCI Version: 4.0 (0x6) Revision: 0x22bb
LMP Version: 4.0 (0x6) Subversion: 0x22bb
Manufacturer: Cambridge Silicon Radio (10)
Devices:
hci0 00:15:83:E4:19:C3
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 004: ID 0658:0200 Sigma Designs, Inc.
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Reading package lists...
Building dependency tree...
Reading state information...
bluetooth is already the newest version.
bluez is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
libbluetooth-dev is already the newest version.
request@2.61.0 ../../node_modules/request
├── aws-sign2@0.5.0
├── forever-agent@0.6.1
├── caseless@0.11.0
├── stringstream@0.0.4
├── tunnel-agent@0.4.1
├── oauth-sign@0.8.0
├── form-data@1.0.0-rc3
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── extend@3.0.0
├── node-uuid@1.4.3
├── qs@4.0.0
├── tough-cookie@2.0.0
├── combined-stream@1.0.5 (delayed-stream@1.0.0)
├── mime-types@2.1.6 (mime-db@1.18.0)
├── hawk@3.1.0 (cryptiles@2.0.4, sntp@1.0.9, boom@2.8.0, hoek@2.14.0)
├── http-signature@0.11.0 (assert-plus@0.1.5, asn1@0.1.11, ctype@0.5.3)
├── bl@1.0.0 (readable-stream@2.0.2)
└── har-validator@1.8.0 (bluebird@2.9.34, commander@2.8.1, chalk@1.1.1, is-my-json-valid@2.12.2)
node-flower-power@1.1.0 ../../node_modules/node-flower-power
└── moment@2.10.6
async@1.4.2 ../../node_modules/async
npm WARN optional dep failed, continuing xpc-connection@0.1.4
> usb@1.0.6 install /usr/share/nginx/www/jeedom/plugins/node_modules/noble-device/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb
> node-pre-gyp install --fallback-to-build
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/node_modules/noble-device/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
CC(target) Release/obj.target/libusb/libusb/libusb/core.o
CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
CC(target) Release/obj.target/libusb/libusb/libusb/io.o
CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
../libusb/libusb/os/threads_posix.c:24:0: warning: "_GNU_SOURCE" redefined
# define _GNU_SOURCE
:0:0: note: this is the location of the previous definition
CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
AR(target) Release/obj.target/usb.a
COPY Release/usb.a
CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
CXX(target) Release/obj.target/usb_bindings/src/device.o
CXX(target) Release/obj.target/usb_bindings/src/transfer.o
SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
COPY Release/usb_bindings.node
COPY /usr/share/nginx/www/jeedom/plugins/node_modules/noble-device/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/src/binding/usb_bindings.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/node_modules/noble-device/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/build'
> bluetooth-hci-socket@0.3.3 install /usr/share/nginx/www/jeedom/plugins/node_modules/noble-device/node_modules/noble/node_modules/bluetooth-hci-socket
> node-gyp rebuild
make: Entering directory '/usr/share/nginx/www/jeedom/plugins/node_modules/noble-device/node_modules/noble/node_modules/bluetooth-hci-socket/build'
CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
SOLINK_MODULE(target) Release/obj.target/binding.node
COPY Release/binding.node
make: Leaving directory '/usr/share/nginx/www/jeedom/plugins/node_modules/noble-device/node_modules/noble/node_modules/bluetooth-hci-socket/build'
noble-device@1.1.0 ../../node_modules/noble-device
└── noble@1.1.0 (bplist-parser@0.0.6, debug@2.2.0, bluetooth-hci-socket@0.3.3)
chown: cannot access 'node_modules': No such file or directory
04-09-2015 15:30:02 | debug | pull cron
04-09-2015 15:30:02 | info | Lancement du service Node-Flower-Power
04-09-2015 16:00:02 | debug | pull cron
04-09-2015 16:00:02 | info | Lancement du service Node-Flower-Power
Merci d'avance pour l'aide.npm WARN optional dep failed, continuing xpc-connection@0.1.4
