[Plugin Tiers][Sujet Principal] Parrot Plants
Re: [Sujet officiel] Plugin Flower Power Bluetooth
- Timide
inclusion OK pour moi avec la MAJ d'aujourd'hui !
merci
merci
la maj de dépendance me revois des erreurs de npm :
Par contre le démon démarre bien mais j'ai "error:timeout" à la place des valeurs !
Début de l'installation
Reading package lists...
Building dependency tree...
Reading state information...
bluez is already the newest version.
bluetooth is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 218 not upgraded.
libbluetooth-dev is already the newest version.
Version actuelle : v5.6.0
Ok, version suffisante
npm ERR! Linux 3.13.0-49-generic
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "cache" "clean"
npm ERR! node v5.6.0
npm ERR! npm v3.6.0
npm ERR! path /var/www/.npm
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall rmdir
npm ERR! Error: EACCES: permission denied, rmdir '/var/www/.npm'
npm ERR! at Error (native)
npm ERR! { [Error: EACCES: permission denied, rmdir '/var/www/.npm']
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'rmdir',
npm ERR! path: '/var/www/.npm' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! Please include the following file with any support request:
npm ERR! /usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/npm-debug.log
> usb@1.1.2 install /usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/node_modules/usb
> node-pre-gyp install --fallback-to-build
make: Entering directory `/usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/node_modules/usb/build'
CC(target) Release/obj.target/libusb/libusb/libusb/core.o
CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
CC(target) Release/obj.target/libusb/libusb/libusb/io.o
CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
AR(target) Release/obj.target/usb.a
COPY Release/usb.a
CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
CXX(target) Release/obj.target/usb_bindings/src/device.o
CXX(target) Release/obj.target/usb_bindings/src/transfer.o
SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
COPY Release/usb_bindings.node
COPY /usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/node_modules/usb/src/binding/usb_bindings.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory `/usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/node_modules/usb/build'
> bluetooth-hci-socket@0.4.3 install /usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/node_modules/bluetooth-hci-socket
> node-gyp rebuild
make: Entering directory `/usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/node_modules/bluetooth-hci-socket/build'
CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
SOLINK_MODULE(target) Release/obj.target/binding.node
COPY Release/binding.node
make: Leaving directory `/usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node/node_modules/bluetooth-hci-socket/build'
node-flower-bridge@1.8.6 /usr/share/nginx/www/jeedom/plugins/flowerpowerbt/node
+-- async@1.5.2
+-- cli-color@1.1.0
| +-- ansi-regex@2.0.0
| +-- d@0.1.1
| +-- es5-ext@0.10.11
| | `-- es6-symbol@3.0.2
| +-- es6-iterator@2.0.0
| +-- memoizee@0.3.9
| | +-- es6-weak-map@0.1.4
| | | +-- es6-iterator@0.1.3
| | | `-- es6-symbol@2.0.1
| | +-- event-emitter@0.3.4
| | +-- lru-queue@0.1.0
| | `-- next-tick@0.2.2
| `-- timers-ext@0.1.0
+-- figures@1.5.0
+-- flower-power-api@1.4.2
| +-- node-schedule@0.6.0
| | +-- cron-parser@0.6.2
| | `-- long-timeout@0.0.2
| `-- request@2.69.0
| +-- aws-sign2@0.6.0
| +-- aws4@1.3.2
| | `-- lru-cache@4.0.1
| | +-- pseudomap@1.0.2
| | `-- yallist@2.0.0
| +-- bl@1.0.3
| | `-- readable-stream@2.0.6
| | +-- core-util-is@1.0.2
| | +-- inherits@2.0.1
| | +-- isarray@1.0.0
| | +-- process-nextick-args@1.0.6
| | +-- string_decoder@0.10.31
| | `-- util-deprecate@1.0.2
| +-- caseless@0.11.0
| +-- combined-stream@1.0.5
| | `-- delayed-stream@1.0.0
| +-- extend@3.0.0
| +-- forever-agent@0.6.1
| +-- form-data@1.0.0-rc4
| +-- har-validator@2.0.6
| | +-- chalk@1.1.3
| | | +-- ansi-styles@2.2.1
| | | +-- escape-string-regexp@1.0.5
| | | +-- has-ansi@2.0.0
| | | +-- strip-ansi@3.0.1
| | | `-- supports-color@2.0.0
| | +-- commander@2.9.0
| | | `-- graceful-readlink@1.0.1
| | +-- is-my-json-valid@2.13.1
| | | +-- generate-function@2.0.0
| | | +-- generate-object-property@1.2.0
| | | | `-- is-property@1.0.2
| | | +-- jsonpointer@2.0.0
| | | `-- xtend@4.0.1
| | `-- pinkie-promise@2.0.0
| | `-- pinkie@2.0.4
| +-- hawk@3.1.3
| | +-- boom@2.10.1
| | +-- cryptiles@2.0.5
| | +-- hoek@2.16.3
| | `-- sntp@1.0.9
| +-- http-signature@1.1.1
| | +-- assert-plus@0.2.0
| | +-- jsprim@1.2.2
| | | +-- extsprintf@1.0.2
| | | +-- json-schema@0.2.2
| | | `-- verror@1.3.6
| | `-- sshpk@1.7.4
| | +-- asn1@0.2.3
| | +-- dashdash@1.13.0
| | | `-- assert-plus@1.0.0
| | +-- ecc-jsbn@0.1.1
| | +-- jodid25519@1.0.2
| | +-- jsbn@0.1.0
| | `-- tweetnacl@0.14.3
| +-- is-typedarray@1.0.0
| +-- isstream@0.1.2
| +-- json-stringify-safe@5.0.1
| +-- mime-types@2.1.10
| | `-- mime-db@1.22.0
| +-- node-uuid@1.4.7
| +-- oauth-sign@0.8.1
| +-- qs@6.0.2
| +-- stringstream@0.0.5
| +-- tough-cookie@2.2.2
| `-- tunnel-agent@0.4.2
+-- flower-power-ble@0.5.0
| +-- buffer-equal@1.0.0
| `-- noble-device@1.3.0
| `-- noble@1.3.0
| +-- bluetooth-hci-socket@0.4.3
| | +-- nan@2.2.1
| | `-- usb@1.1.2
| | `-- node-pre-gyp@0.6.24
| | +-- mkdirp@0.5.1
| | | `-- minimist@0.0.8
| | +-- nopt@3.0.6
| | | `-- abbrev@1.0.7
| | +-- npmlog@2.0.3
| | | +-- ansi@0.3.1
| | | +-- are-we-there-yet@1.1.2
| | | | +-- delegates@1.0.0
| | | | +-- inherits@2.0.1
| | | | +-- isarray@1.0.0
| | | `-- gauge@1.2.7
| | | +-- has-unicode@2.0.0
| | | +-- lodash.pad@4.1.0
| | | | +-- lodash.repeat@4.0.0
| | | | `-- lodash.tostring@4.1.2
| | | +-- lodash.padend@4.2.0
| | | `-- lodash.padstart@4.2.0
| | +-- rc@1.1.6
| | | +-- deep-extend@0.4.1
| | | +-- ini@1.3.4
| | | +-- minimist@1.2.0
| | | `-- strip-json-comments@1.0.4
| | +-- request@2.69.0
| | | +-- aws-sign2@0.6.0
| | | +-- aws4@1.3.2
| | | | `-- lru-cache@4.0.0
| | | | +-- pseudomap@1.0.2
| | | | `-- yallist@2.0.0
| | | +-- bl@1.0.3
| | | | +-- inherits@2.0.1
| | | | +-- isarray@1.0.0
| | | +-- caseless@0.11.0
| | | +-- extend@3.0.0
| | | | `-- async@1.5.2
| | | | +-- chalk@1.1.1
| | | | | +-- ansi-styles@2.2.0
| | | | | | `-- color-convert@1.0.0
| | | | | +-- has-ansi@2.0.0
| | | | | | `-- ansi-regex@2.0.0
| | | | +-- commander@2.9.0
| | | | | `-- xtend@4.0.1
| | | | `-- pinkie@2.0.4
| | | +-- hawk@3.1.3
| | | | +-- boom@2.10.1
| | | | +-- cryptiles@2.0.5
| | | | +-- hoek@2.16.3
| | | | `-- sntp@1.0.9
| | | | +-- jsprim@1.2.2
| | | | | `-- verror@1.3.6
| | | | `-- sshpk@1.7.4
| | | | +-- asn1@0.2.3
| | | | +-- dashdash@1.13.0
| | | | +-- ecc-jsbn@0.1.1
| | | | +-- jsbn@0.1.0
| | | | `-- tweetnacl@0.14.1
| | | +-- isstream@0.1.2
| | | | `-- mime-db@1.22.0
| | | +-- node-uuid@1.4.7
| | | +-- qs@6.0.2
| | +-- rimraf@2.5.2
| | | `-- glob@7.0.3
| | | +-- inflight@1.0.4
| | | | `-- wrappy@1.0.1
| | | +-- inherits@2.0.1
| | | +-- minimatch@3.0.0
| | | | `-- brace-expansion@1.1.3
| | | | +-- balanced-match@0.3.0
| | | | `-- concat-map@0.0.1
| | | +-- once@1.3.3
| | | | `-- wrappy@1.0.1
| | | `-- path-is-absolute@1.0.0
| | +-- semver@5.1.0
| | +-- tar@2.2.1
| | | +-- block-stream@0.0.8
| | | +-- fstream@1.0.8
| | | | `-- graceful-fs@4.1.3
| | | `-- inherits@2.0.1
| | `-- tar-pack@3.1.3
| | +-- debug@2.2.0
| | | `-- ms@0.7.1
| | +-- fstream@1.0.8
| | | +-- graceful-fs@4.1.3
| | | `-- inherits@2.0.1
| | +-- fstream-ignore@1.0.3
| | | +-- inherits@2.0.1
| | | `-- minimatch@3.0.0
| | +-- once@1.3.3
| | | `-- wrappy@1.0.1
| | +-- readable-stream@2.0.6
| | | +-- inherits@2.0.1
| | | +-- isarray@1.0.0
| | `-- uid-number@0.0.6
| +-- bplist-parser@0.0.6
| `-- debug@2.2.0
| `-- ms@0.7.1
`-- nedb@1.8.0
+-- async@0.2.10
+-- binary-search-tree@0.2.5
+-- localforage@1.4.0
| `-- promise@5.0.0
| `-- asap@1.0.0
+-- mkdirp@0.5.1
| `-- minimist@0.0.8
`-- underscore@1.4.4
npm WARN optional Skipping failed optional dependency /noble/xpc-connection:
npm WARN notsup Not compatible with your operating system or architecture: xpc-connection@0.1.4
Fin de l'installation
En ssh :
sudo wget http://gamers-city.eu/jeedom/webapp
sudo chmod +x webapp
sudo ./webapp nginx
sudo reboot et relance dépendance
Envoyé via mon smartphone, si la réponse est trop courte, fonction recherche
sudo ./webapp nginx
Charte du forum
Doc jeedom - Trucs et astuces
Soutiens à Slobberbone membres actif !
Non disponible par MP/Email.
la classe ! ça c'est du rapide ! Merci kouaw
Ou de la réécriture de support
Charte du forum
J'ai l'impression que la commande : sudo ./webapp nginx ne fonctionne pas !
jeedom@Jeedom:~$ sudo chmod +x webapp
jeedom@Jeedom:~$ ls
homebridge install.sh webapp webapp.1
jeedom@Jeedom:~$ sudo ./webapp nginx
Ign http://fr.archive.ubuntu.com trusty InRelease
Atteint http://fr.archive.ubuntu.com trusty-updates InRelease
Atteint http://fr.archive.ubuntu.com trusty-backports InRelease
Réception de : 1 http://security.ubuntu.com trusty-security InRelease [65,9 kB]
Atteint http://fr.archive.ubuntu.com trusty Release.gpg
Atteint http://fr.archive.ubuntu.com trusty-updates/main Sources
Atteint http://fr.archive.ubuntu.com trusty-updates/restricted Sources
Atteint http://fr.archive.ubuntu.com trusty-updates/universe Sources
Atteint http://fr.archive.ubuntu.com trusty-updates/multiverse Sources
Atteint http://fr.archive.ubuntu.com trusty-updates/main amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty-updates/restricted amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty-updates/universe amd64 Packages
Réception de : 2 http://security.ubuntu.com trusty-security/main Sources [110 kB]
Atteint http://fr.archive.ubuntu.com trusty-updates/multiverse amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty-updates/main i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-updates/restricted i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-updates/universe i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-updates/multiverse i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-updates/main Translation-en
Réception de : 3 http://security.ubuntu.com trusty-security/restricted Sources [4 035 B]
Atteint http://fr.archive.ubuntu.com trusty-updates/multiverse Translation-en
Réception de : 4 http://security.ubuntu.com trusty-security/universe Sources [35,2 kB]
Atteint http://fr.archive.ubuntu.com trusty-updates/restricted Translation-en
Atteint http://fr.archive.ubuntu.com trusty-updates/universe Translation-en
Réception de : 5 http://security.ubuntu.com trusty-security/multiverse Sources [2 750 B]
Atteint http://fr.archive.ubuntu.com trusty-backports/main Sources
Atteint http://fr.archive.ubuntu.com trusty-backports/restricted Sources
Réception de : 6 http://security.ubuntu.com trusty-security/main amd64 Packages [449 kB]
Atteint http://fr.archive.ubuntu.com trusty-backports/universe Sources
Atteint http://fr.archive.ubuntu.com trusty-backports/multiverse Sources
Atteint http://fr.archive.ubuntu.com trusty-backports/main amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/restricted amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/universe amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/multiverse amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/main i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/restricted i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/universe i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/multiverse i386 Packages
Atteint http://fr.archive.ubuntu.com trusty-backports/main Translation-en
Atteint http://fr.archive.ubuntu.com trusty-backports/multiverse Translation-en
Réception de : 7 http://security.ubuntu.com trusty-security/restricted amd64 Packages [13,0 kB]
Atteint http://fr.archive.ubuntu.com trusty-backports/restricted Translation-en
Réception de : 8 http://security.ubuntu.com trusty-security/universe amd64 Packages [126 kB]
Atteint http://fr.archive.ubuntu.com trusty-backports/universe Translation-en
Atteint http://fr.archive.ubuntu.com trusty/main Sources
Atteint http://fr.archive.ubuntu.com trusty/restricted Sources
Atteint http://fr.archive.ubuntu.com trusty/universe Sources
Atteint http://fr.archive.ubuntu.com trusty/multiverse Sources
Réception de : 9 http://security.ubuntu.com trusty-security/multiverse amd64 Packages [4 991 B]
Atteint http://fr.archive.ubuntu.com trusty/main amd64 Packages
Atteint https://deb.nodesource.com trusty InRelease
Atteint http://fr.archive.ubuntu.com trusty/restricted amd64 Packages
Réception de : 10 http://security.ubuntu.com trusty-security/main i386 Packages [423 kB]
Atteint http://fr.archive.ubuntu.com trusty/universe amd64 Packages
Atteint https://deb.nodesource.com trusty/main Sources
Atteint http://fr.archive.ubuntu.com trusty/multiverse amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty/main i386 Packages
Atteint http://fr.archive.ubuntu.com trusty/restricted i386 Packages
Atteint http://fr.archive.ubuntu.com trusty/universe i386 Packages
Atteint http://fr.archive.ubuntu.com trusty/multiverse i386 Packages
Atteint https://deb.nodesource.com trusty/main amd64 Packages
Atteint http://fr.archive.ubuntu.com trusty/main Translation-fr
Atteint http://fr.archive.ubuntu.com trusty/main Translation-en
Réception de : 11 http://security.ubuntu.com trusty-security/restricted i386 Packages [12,7 kB]
Atteint https://deb.nodesource.com trusty/main i386 Packages
Atteint http://fr.archive.ubuntu.com trusty/multiverse Translation-fr
Réception de : 12 http://security.ubuntu.com trusty-security/universe i386 Packages [126 kB]
Atteint http://fr.archive.ubuntu.com trusty/multiverse Translation-en
Réception de : 13 https://deb.nodesource.com trusty/main Translation-fr_FR
Atteint http://fr.archive.ubuntu.com trusty/restricted Translation-fr
Réception de : 14 http://security.ubuntu.com trusty-security/multiverse i386 Packages [5 175 B]
Atteint http://fr.archive.ubuntu.com trusty/restricted Translation-en
Atteint http://fr.archive.ubuntu.com trusty/universe Translation-fr
Atteint http://security.ubuntu.com trusty-security/main Translation-en
Atteint http://fr.archive.ubuntu.com trusty/universe Translation-en
Atteint http://security.ubuntu.com trusty-security/multiverse Translation-en
Atteint http://security.ubuntu.com trusty-security/restricted Translation-en
Atteint http://security.ubuntu.com trusty-security/universe Translation-en
Ign http://fr.archive.ubuntu.com trusty/main Translation-fr_FR
Ign http://fr.archive.ubuntu.com trusty/multiverse Translation-fr_FR
Ign http://fr.archive.ubuntu.com trusty/restricted Translation-fr_FR
Ign http://fr.archive.ubuntu.com trusty/universe Translation-fr_FR
Ign https://deb.nodesource.com trusty/main Translation-fr_FR
Ign https://deb.nodesource.com trusty/main Translation-en
1 379 ko réceptionnés en 15s (90,7 ko/s)
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Calcul de la mise à jour... Fait
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Package 'apache2' is not installed, so not removed
Package 'libapache2-mod-php5' is not installed, so not removed
nginx-common est déjà la plus récente version disponible.
nginx-full est déjà la plus récente version disponible.
--2016-04-04 18:35:08-- https://raw.githubusercontent.com/jeedom/core/stable/install/nginx_default
Résolution de raw.githubusercontent.com (raw.githubusercontent.com)... 185.31.17.133
Connexion vers raw.githubusercontent.com (raw.githubusercontent.com)|185.31.17.133|:443... connecté.
requête HTTP transmise, en attente de la réponse... 200 OK
Taille : 2225 (2,2K) [text/plain]
Enregistre : «/etc/nginx/sites-available/default»
100%[======================================>] 2 225 --.-K/s ds 0s
2016-04-04 18:35:08 (133 MB/s) - «/etc/nginx/sites-available/default» enregistré [2225/2225]
./webapp: ligne 41: systemctl : commande introuvable
./webapp: ligne 42: systemctl : commande introuvable
Install done
Ah t sous ubuntu... donc oui sa ira pas
Charte du forum
Oui je sais c'est pas terrible ! Mais j'ai pas trouvé le temps de tout réinstallé !
Mais si mon pb n'est plus en debian jessie je vais me motiver à migrer ! Lol
- Timide
bonjour à tous.
j'ai migré ce matin en 2.2.6, et fait toutes les mises à jours dont FlowerpowerPT, mais depuis, je n'ai plus d'affichage du widget dans ma vue.
Le plugin fonctionne, j'ai le widget sur le dashboard, mais pas dans la vue... vraiment bizarre.
J'ai essayé de l'effacer et de le remettre, sans résultat.
une idée la dessus?
merci!
une idée la dessus?
merci!
Hello j'ai repris mon installation et je suis passé sur une debian jessie "up to date" !kouaw a écrit :Ah t sous ubuntu... donc oui sa ira pas
Et effectivement tout fonctionne beaucoup mieux avec le plugin !
Encore merci
@lunarok
J'utilise le plugin flowerpower en déporté sur 2 rpi depuis plusieurs mois et cela marche plutôt bien.
J'ai cependant une remarque sur les valeurs retournées sur le dashboard Jeedom, que je compare aux valeurs sur le site
http://myflowerpower.parriot.com.
J'ai historisé ces valeurs et je les compare à l'historique sur le site parrot.
Ces valeurs sont bonnes pour l'eau et l'engrais, par contre pour la température et l’ensoleillement , les valeurs du dashboard sont manifestement fausses.
Voila ce que j'ai sur le dashboard pour l’ensoleillement pour une de mes plantes: et voila ce que je devrais avoir On note que les variations ne sont pas bonnes ainsi que le niveau
J’ai aussi une question:
je souhaiterai pouvoir récupérer les données du powerflowser (i.e. ensoleillement par ex.) pour contrôler mes volets de façon
à par ex. baisser le volet si l’ensoleillement de la plante devient trop grand.
Je sais récupérer les données sur le site parrot, par contre je voudrais pouvoir le faire directement sur le power-flower pour avoir la valeur instantanée;
Y a-t-il un bout de script dont je pourrais m'inspirer (j'ai vue que la majorité des scripts utilise nodejs) ?
Encore merci @lunarok pour ce plugin !!
Système DIY 2 PI3 avec SSD (voir mon profil pour le détail)
Je souhaite cacher les instructions qu'un flowerpower retourne au niveau du dashboard (pas assez d'eau, pas assez de soleil,...):
Même en allant dans l'affichage avancé de chaque instruction et en le mettant à invisible, elles sont toujours présentes.
Est-ce possible ?
Merci d'avance
Est-ce possible ?
Merci d'avance
Synology DS415+ (vmm/mariadb) ; Rpi3 avec rfxcom et zwave.
Merci pour le plugin !
Par contre les dépendances ne s'installent pas, j'ai le message :
/usr/bin/env : no such file or directory
or le fichier existe, un problème de droit ?
Est-ce que les dépendances sont nécessaires pour le bluetooth ?
Salut Kouaw,
J'ai exactement le même souci que sbafs dans les logs du plugin :
Du coup j'ai suivi ta précédure :
Le problème est que je n'ai plus accès à jeedom en web :
C'est grave docteur ?
Ca c'est bien passé, et terminé par :kouaw a écrit :En ssh :
sudo ./webapp nginx
Reboot la machine pour voir
Envoyé de mon HUAWEI GRA-L09 en utilisant Tapatalk
Charte du forum
Oui c'est ce qui me manquait à faire.
C'est en cours mais je suis à distance pour il faut ouvrir le port ssh et tout et tout
Snif ... Le reboot n'a rien changé ...
Saurais tu me dire ce que je dois checker?
EDIT :
je viens de rejouer la procédure.
j'ai relancé les services nginx et php.
j'ai ensuite réinstallé le service nginx et reloadé
=> toujours le meme souci.
Re EDIT :
Le souci était au niveau certificat.
Sachant que je n'arrive pas à faire fonctionner le plugin depuis un bail, j'ai décidé de repartir sur une base propre avec une réinstall de jeedom (30 mins et basta).
Donc je te tiens au courant.
EDIT :
Re EDIT :
J'ai une petite question, suite à la création du compte pour l'utilisation de l'API, il faut attendre un certain délais ?
En fait sur le plugin je vois bien la communication via BT, je vois bien les bonne infos dans mon jardin sur le site de parrot. Mais je n'ai aucun Flower qui se créé automatiquement.
Merci par avance
Envoyé de mon A0001 en utilisant Tapatalk
Merci par avance
Jeedom
La rétention de l'information est une forme de constipation du savoir.
Documentation - Trucs & Astuces - Charte
Lorsque je relance le démon du plugin j'ai un message disant PB d'authentification. Concernant la partie login/password de l'appli c'est OK vu que les infos sont bien synchronisée chez parrot. Pour les identifiants API j'ai bien fais un copier coller du mail. J'ai même demander un second accès avec une autre adresse mail et cela me fait toujours pareil.
Quelqu'un aurait il déjà eu ce PB ?
Je pense que le fait que mon FP ne se créé pas tout seul vient de la.
Jeedom
