[Plugin Tiers][Sujet Principal] arrosageAuto
mika-nt28
Re: [Plugin Tiers][Sujet Principal] arrosageAuto
Message par mika-nt28 » 20 avr. 2019, 18:40
OU?
Tu as un log dans le http.error?
ihexley
Message par ihexley » 20 avr. 2019, 19:10
Dans le panel desktop. oui comme la dernière fois quand tu as vu le probleme de variable.
[Sat Apr 20 08:41:27.273923 2019] [:error] [pid 5002] [client 10.11.0.1:60598] PHP Notice:  Undefined index: Arrosage in /var/www/html/plugins/arrosageAuto/core/class/arrosageAuto.class.php on line 503, referer: https://7e855899.dns4.jeedom.com/index.php?v=d&m=arrosageAuto&p=panel&object_id=45
[Sat Apr 20 08:41:27.273950 2019] [:error] [pid 5002] [client 10.11.0.1:60598] PHP Warning:  Invalid argument supplied for foreach() in /var/www/html/plugins/arrosageAuto/core/class/arrosageAuto.class.php on line 503, referer: https://7e855899.dns4.jeedom.com/index.php?v=d&m=arrosageAuto&p=panel&object_id=45
[Sat Apr 20 08:41:27.273983 2019] [:error] [pid 5002] [client 10.11.0.1:60598] PHP Fatal error:  Uncaught Error: Unsupported operand types in /var/www/html/plugins/arrosageAuto/core/class/arrosageAuto.class.php:504
Stack trace:
#0 /var/www/html/plugins/arrosageAuto/core/ajax/arrosageAuto.ajax.php(61): arrosageAuto::getGraph(1553067687, 1555742487, '45')
#1 {main}
thrown in /var/www/html/plugins/arrosageAuto/core/class/arrosageAuto.class.php on line 504, referer: https://7e855899.dns4.jeedom.com/index.php?v=d&m=arrosageAuto&p=panel&object_id=45
[Sat Apr 20 08:50:01.282599 2019] [:error] [pid 4501] [client 10.11.0.1:46596] PHP Notice:  Undefined index: Arrosage in /var/www/html/plugins/arrosageAuto/core/class/arrosageAuto.class.php on line 503, referer: https://7e855899.dns4.jeedom.com/index.php?v=d&m=arrosageAuto&p=panel&object_id=45
[Sat Apr 20 08:50:01.282626 2019] [:error] [pid 4501] [client 10.11.0.1:46596] PHP Warning:  Invalid argument supplied for foreach() in /var/www/html/plugins/arrosageAuto/core/class/arrosageAuto.class.php on line 503, referer: https://7e855899.dns4.jeedom.com/index.php?v=d&m=arrosageAuto&p=panel&object_id=45
[Sat Apr 20 08:50:01.282661 2019] [:error] [pid 4501] [client 10.11.0.1:46596] PHP Fatal error:  Uncaught Error: Unsupported operand types in /var/www/html/plugins/arrosageAuto/core/class/arrosageAuto.class.php:504
Stack trace:
#0 /var/www/html/plugins/arrosageAuto/core/ajax/arrosageAuto.ajax.php(61): arrosageAuto::getGraph(1553068201, 1555743001, '45')
#1 {main}
mika-nt28
Message par mika-nt28 » 21 avr. 2019, 07:20
Je reprodui chez moi je regarderai ca plus en detail
fredmons31
Message par fredmons31 » 29 juin 2019, 19:22
Je viens d'essayer de paramétrer le plugin, avec peu de succès. J'ai donc certainement loupé des trucs dans le paramétrage mais je ne comprend pas où.
Rien ne se passe, pas d'arrosage ni même de calcul de la durée.
Voici les logs :
[2019-06-29 19:11:03][DEBUG] : [Jardin][Potager] : Temps d'arrosage de NANs avec un coefficient de %
[2019-06-29 19:11:03][INFO] : [Jardin][Potager] : Nous devons arroser INF mm/m² avec un pluviometrie de NANmm/s
[2019-06-29 19:11:26][DEBUG] : [Jardin][Potager] : Aucune programmation
Pourtant il y a bien une programmation, et des paramètres d'arrosage complets
Merci de ton aide !
mika-nt28
Message par mika-nt28 » 01 juil. 2019, 09:22
a tu mis un coefficient différent de 0 (sur le dashbord)?
jacqorlean
Message par jacqorlean » 18 juil. 2019, 20:42
Bonjour, et bravo pour ce développement, c’est très différent des modules avec un fonctionnement purement « horaire ».
Le fait d’éviter encore plus le gaspillage de l’eau m’a séduit, mais je souhaiterai avoir quelques précisions que je n’ai pas trouvé dans le fil de conversations.
A / La pression de l’eau n’est pas mesurée, hors à 1 bar ou 1,8 bar, la quantité d’eau distribuée n’est pas la même, je ne vois pas comment on peut alors parler de pluviomètrie précise. Il ne s’agit donc pour moi que d’une moyenne entre les mini et maxi renseignées et les effets induits des supposées pertes de charges liées au débit. Est-ce bien le principe retenu.???
B / J’ai paramétré le plugin, testé les fonctions météo, mais les temps d’arrosages calculés restent à zéro.
J’adresse une copie du log debug, j’y vois bien des écarts entre les trames des deux zones d’arrosage mais ne parviens pas dans les configurations à obtenir deux zones identiques.
Par ailleurs, les deux trames sont différentes, mais toutes deux ne permettent pas d’obtenir des temps d’arrosage.
Merci à ceux qui pourront m’aider à finaliser le paramétrage.
Log debug
Jacques
Jeedom 3.3.35 DIY RPI 3 avec SDD sans SD + 3 cartes x 8 relais ip
Netatmo + 2 Stations meteo distantes +Thermostat .
Arrosage 6 zones avec prévisions / mesures.
RFX Com pour 6 sondes thermo météo Orégon
jacqorlean
Message par jacqorlean » 18 juil. 2019, 20:49
Suite et ecran dashboard
jacqorlean
Message par jacqorlean » 19 juil. 2019, 07:32
PS : Jeedom à jour sur RPI, seul le plugin monitoring n’est pas à jour
Par contre, les lignes « listener non trouvé » sont générées lors de l’activation/désactivation d’une zone d’arrosage.
mika-nt28
Message par mika-nt28 » 19 juil. 2019, 08:49
La pression de l'eau de ta source est normalement constante, il faut bien entendue savoir la pression que l'on as par une mesure
C'est tres etrange ca.
Peux tu mettre un screen de la programmation car les log "Zone inactive dans cette programmation" indique que le plugin ne touve pas la branche dans la programmation
La partie meteo j'en suis pas 100% content et je chez moi par exemple la quantité d'eau de pluie (plugin meteo) ne convient pas correctement.
Pour le limitation d'usage (vent, probabilité de pluie, ...) c'est pas trop mal.
Est ce que tu as configurer un EtatElectrovanne?
Car le listener ecoute cette etat.
jacqorlean
Message par jacqorlean » 19 juil. 2019, 11:51
Bonjour et merci pour ce retour d’informations.
Je regarde l’état de l’électrovanne.
Jacques
jacqorlean
Message par jacqorlean » 19 juil. 2019, 18:23
Re bonjour.
Le temps d’arrosage fonctionne maintenant.
Le non-fonctionnement ne venait pas de l’état de l’électro-vanne.
Le changement de type d’arroseur a débloqué la situation.
Le paramétrage de test était réalisée sur deux zones équipées de goutte à goutte.
Seul changement effectué : passer de goutte à goutte à tuyère .
Je continue le paramètrage des autres zones.
Je rencontre un blocage sur le dépassement de débit, j’ai renseigné 4000 L/h en débit maxi et avec qq tuyères à 120 L/h, j’ai un message de dépassement interdisant la sauvegarde. J’essaie de comprendre.
Merci pour votre assistance.
Jacques
manu_44
Message par manu_44 » 21 juil. 2019, 13:02
J'ai parcouru la documentation du plugin, et je ne comprends pas trop le cas d'usage. Pour les personnes initiées, c'est peut être très clair, mais pour moi qui souhaite me lancer dans l'arrosage connecté, je n'ai pas compris, et j'avoue que je n'ai pas parcouru les 200+ messages du forum pour savoir s'il y avait plus d'explications.
Pour info, j'utilise Jeedom actuellement pour mes volets (via module qubino ZMNHCD1) et lumières Hue et Wiz.
Pour être plus précis, je ne sais pas quel type d'équipement est capable de gérer le plugin ? Est-ce qu'il s'agit d'electrovannes, de modules ? Est-ce qu'il est comptatible avec tout type d'équipement ou certains en particulier ? Avez-vous un cas d'usage qui explique une configuration simple ? Parce que dans l'état, je ne vois pas comment un bout de code va arroser mon jardin 🤣🤣🤣
Merci d'avance,
Manuel
mika-nt28
Message par mika-nt28 » 22 juil. 2019, 08:24
Merci d'avance,
Manuel
Ou en ai tu dans ton projet d'arrosage?
En fonction de ce que tu veux arroser tu aura besoin d'arroseur (tuillere, goute a goute, turbine).
Chaqu'un de ses arroseur a des caractéristique debit pression bien determiné par le constructeur (pas toujours evident a trouvé je l'accorde)
Pour contrôler chaque branche d'arrosage tu a besoin d'une électrovanne qui peut etre activé par un module domotique (perso c'est des relais knx)
manu_44
Message par manu_44 » 22 juil. 2019, 15:49
J'ai acheté une electrovanne :
- 12V G3 / 4 Laiton N/C Distributeur d'eau 6 points Vanne électromagnétique électrique normalement fermée Vanne de régulation de pression 2 voies 12V (https://www.amazon.fr/gp/product/B07HP2 ... UTF8&psc=1)
Je pense y ajouter un module Fibaro FGS 222 pour gérer l'ouverture et la fermeture de l'electrovanne.
Est-ce que le plugin peut m'être utile ?
mika-nt28
Message par mika-nt28 » 22 juil. 2019, 15:56
Le plugin permet de gérer la quantité d'eau que l'on veux pour chaque zone d'arrosage.
Certaine personne vont te dire qu'un scénario suffis, mais je trouve trop imprécis et laisse passé énormément de gaspillage.
philb
Message par philb » 12 août 2019, 18:59
Bonjour Mika,
J'utilisais jusqu'ici avec mes boîtiers d'arrosage Etherain de quicksmart, leur logiciel Optirain/windows.
J'ai téléchargé votre plugin pour englober mon arrosage sous jeedom:
Quelques questions:
- Quel plugin météo utilisez vous?
Si weather, quel est le paramètre probabilité de pluie? le paramètre "pluie de la veille"est issu de la valeur "pluie stockée dans la base ?
- Je vois des paramètres météo générales au plugin, et des conditions météo par branche. Les paramètres généraux sont suffisants pour l’ensemble et les individuels viennent amender ponctuellement?
- coefficient: min et max, quel est la logique? je comprends qu'un coeff peut venir augmenter ou decroitre l'intensité d'un arrosage branches, mais pourquoi min et max? mon logiciel optirain me permettait de fixer un coeff par mois (ex 50% en avril, 120%en juillet..). Doit on ici modifier chaque branche manuellement ?
-J'ai vu une question sur l'espacement latéral mais n'ai pas vu de réponse..pouvez vous expliquer?
Merci par avance pour vos réponses ( Elles devraient être incluses dans la doc)
lemars
Message par lemars » 20 août 2019, 09:21
J'ai parcouru les 11 pages de sujet très intéressant mais vous n'indiquez pas quel matériel vous utilisez pour commander votre système d'arrosage.
L'endroit ou je vais installé les 2 électrovannes est un peu loin de la box : par souci de sécuriser le fonctionnement du système je préfèrerai opter pour un réseau filaire
Et même l'idéal serait un système autonome : pour palier aussi les pannes de courant
Merci de vos lumières
Lemars
mika-nt28
Message par mika-nt28 » 24 août 2019, 07:30
Désolé je rentre de vacances, je ne sais pas si les question on trouvé reponse mais je vais tout de meme tenté d'apporter une reponse
philb a écrit :
12 août 2019, 18:59
Bonjour Mika,
Quelques questions:
Le plugin metéo n'a pas d'importance ca on vien choisir les commandes de meteo sous jeedom
J'ai quand même détecte un bug sur les précipitation qu'il faut que je corrige.
On peut mettre des condition par branche pas nécessairement que de la meteo.
Par exemple chez moi je n'arrose pas si je suis sur la terrasse
Le coeficient a ete ajouté pour que l'on puisse avoir un control manuel sur l'arrosage.
Perso il est toujours a 100 mais parfois quand l'herbe seche quand meme je passe a 200%
L'espacement c'est plutot pour le goute a goute
lemars a écrit :
20 août 2019, 09:21
Lemars
Le type de materiel n'a pas d'importance le plugin est capable de s'adapté a condition de touver les caracteristique principale de l'arroseur
lemars
Message par lemars » 24 août 2019, 07:49
Bonjour merci
Je comprends et le plugin a l'air super et il m'intéresse
Mais au niveau matériel je cherche une solution super fiable : car autant si j'allume le chauffage un peu avant ok, mais si j'arrose non stop car je pars en vacances ...
Merci bien M Aubert
vincecoco
Message par vincecoco » 26 août 2019, 12:24
Vous utilisez quelle source pour la pluviométrie ?
@lemars
Les double charge de chez fibaro ont une option pour se couper toute seule au bout de X minutes (au cas où :) )
