Oui je sais pas si le site est en rade ou a enfin intégré le captcha, mais tout est HS :
2019-10-24 18:59:04 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 19:59:04', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 19:59:04', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 16:59:05 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 17:59:05', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 17:59:05', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 15:59:05 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 16:59:05', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 16:59:05', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 13:59:05 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 14:59:05', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 14:59:05', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 12:59:07 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 13:59:07', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 13:59:07', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 11:59:05 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 12:59:05', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 12:59:05', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 10:59:04 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 11:59:04', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 11:59:04', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 09:59:05 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 10:59:05', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 10:59:05', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 08:59:07 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 09:59:07', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 09:59:07', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 07:59:15 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 08:59:15', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 08:59:15', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 06:59:05 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 07:59:05', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 07:59:05', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 05:59:04 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 06:59:04', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 06:59:04', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 04:59:07 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 05:59:07', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 05:59:07', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 02:59:06 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 03:59:06', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 03:59:06', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 01:59:04 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 02:59:04', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 02:59:04', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-24 00:59:04 sigri_atome "Login Failed" à la connexion API, réessayez plus tard...
2019-10-23 23:59:09 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-24 00:59:09', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-24 00:59:09', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 22:59:08 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 23:59:08', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 23:59:08', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 21:59:05 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 22:59:05', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 22:59:05', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 20:59:04 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 21:59:04', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 21:59:04', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 19:59:06 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 20:59:06', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 20:59:06', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 18:59:06 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 19:59:06', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 19:59:06', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 17:59:04 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 18:59:04', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 18:59:04', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 16:59:06 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 17:59:06', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 17:59:06', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 15:59:06 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 16:59:06', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 16:59:06', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
2019-10-23 14:59:04 sigri_atome Erreur sur sigri_atome::cronHoraire() : [MySQL] Error code : 42000 (1064). You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'index, cost) VALUES ('2019-10-23 15:59:04', 'Array[1]->consu' at line 1 : INSERT INTO sigri_atome_hour (hour, code, total_consumption, index, cost) VALUES ('2019-10-23 15:59:04', 'Array[1]->consumption->code1', '', '1', '1') ON DUPLICATE KEY UPDATE total_consumption = CASE WHEN total_consumption
