A très bientôt !
[TUTO]Installer Jeedom sur Odroid C2
mutmut
Re: [TUTO]Installer Jeedom sur Odroid C2
Message par mutmut » 20 mai 2017, 00:02
en comparant avec le kern.log, j'ai trouvé ceci :
May  5 17:17:09 localhost kernel: [    0.827906] usb 1-1: new high-speed USB device number 2 using dwc_otg
May  5 17:17:09 localhost kernel: [    0.828170] dwc_otg: Indeed it is in host mode hprt0 = 00001101
May  5 17:17:09 localhost kernel: [    1.089671] hub 1-1:1.0: USB hub found
May  5 17:17:09 localhost kernel: [    1.089968] hub 1-1:1.0: 4 ports detected
May  5 17:17:09 localhost kernel: [    1.267918] raid6: int64x1    508 MB/s
May  5 17:17:09 localhost kernel: [    1.368100] usb 1-1.3: new full-speed USB device number 3 using dwc_otg
May  5 17:17:09 localhost kernel: [    1.437906] raid6: int64x2    819 MB/s
May  5 17:17:09 localhost kernel: [    1.448117] usb 1-1.3: device descriptor read/64, error -32
May  5 17:17:09 localhost kernel: [    1.607838] raid6: int64x4   1297 MB/s
May  5 17:17:09 localhost kernel: [    1.638166] usb 1-1.3: device descriptor read/64, error -32
May  5 17:17:09 localhost kernel: [    1.777848] raid6: int64x8   1392 MB/s
May  5 17:17:09 localhost kernel: [    1.828096] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
May  5 17:17:09 localhost kernel: [    1.908113] usb 1-1.3: device descriptor read/64, error -32
May  5 17:17:09 localhost kernel: [    1.947890] raid6: neonx1     886 MB/s
May  5 17:17:09 localhost kernel: [    2.098162] usb 1-1.3: device descriptor read/64, error -32
May  5 17:17:09 localhost kernel: [    2.117846] raid6: neonx2    1445 MB/s
May  5 17:17:09 localhost kernel: [    2.133848] random: nonblocking pool is initialized
May  5 17:17:09 localhost kernel: [    2.287850] raid6: neonx4    1884 MB/s
May  5 17:17:09 localhost kernel: [    2.297838] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
May  5 17:17:09 localhost kernel: [    2.457863] raid6: neonx8    1885 MB/s
May  5 17:17:09 localhost kernel: [    2.457867] raid6: using algorithm neonx8 (1885 MB/s)
May  5 17:17:09 localhost kernel: [    2.457871] raid6: using intx1 recovery algorithm
May  5 17:17:09 localhost kernel: [    2.458314] xor: measuring software checksum speed
May  5 17:17:09 localhost kernel: [    2.557829]    8regs     :  2846.000 MB/sec
May  5 17:17:09 localhost kernel: [    2.605953] switch_vpu_mem_pd: viu_vd1 OFF
May  5 17:17:09 localhost kernel: [    2.605958] switch_vpu_mem_pd: afbc_dec OFF
May  5 17:17:09 localhost kernel: [    2.605962] switch_vpu_mem_pd: di_post OFF
May  5 17:17:09 localhost kernel: [    2.605966] switch_vpu_mem_pd: viu_vd2 OFF
May  5 17:17:09 localhost kernel: [    2.657844]    8regs_prefetch:  2612.000 MB/sec
May  5 17:17:09 localhost kernel: [    2.717842] usb 1-1.3: device not accepting address 5, error -71
May  5 17:17:09 localhost kernel: [    2.757846]    32regs    :  3467.200 MB/sec
May  5 17:17:09 localhost kernel: [    2.828109] usb 1-1.4: new full-speed USB device number 7 using dwc_otg
May  5 17:17:09 localhost kernel: [    2.857830]    32regs_prefetch:  2881.600 MB/sec
May  5 17:17:09 localhost kernel: [    2.857837] xor: using function: 32regs (3467.200 MB/sec)
May  5 17:17:09 localhost kernel: [    2.867864] bio: create slab <bio-1> at 1
May  5 17:17:09 localhost kernel: [    2.868485] Btrfs loaded
May  5 17:17:09 localhost kernel: [    2.868558] BTRFS: selftest: Running btrfs free space cache tests
May  5 17:17:09 localhost kernel: [    2.868563] BTRFS: selftest: Running extent only tests
May  5 17:17:09 localhost kernel: [    2.868580] BTRFS: selftest: Running bitmap only tests
May  5 17:17:09 localhost kernel: [    2.868596] BTRFS: selftest: Running bitmap and extent tests
May  5 17:17:09 localhost kernel: [    2.868617] BTRFS: selftest: Free space cache tests finished
May  5 17:17:09 localhost kernel: [    2.868620] BTRFS: selftest: Running extent buffer operation tests
May  5 17:17:09 localhost kernel: [    2.868624] BTRFS: selftest: Running btrfs_split_item tests
May  5 17:17:09 localhost kernel: [    2.868661] BTRFS: selftest: Running find delalloc tests
May  5 17:17:09 localhost kernel: [    3.117032] BTRFS: selftest: Running btrfs_get_extent tests
May  5 17:17:09 localhost kernel: [    3.117214] BTRFS: selftest: Running hole first btrfs_get_extent test
May  5 17:17:09 localhost kernel: [    3.168232] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
May  5 17:17:09 localhost kernel: [    3.270035] cdc_acm 1-1.3:1.0: This device cannot do calls on its own. It is not a modem.
May  5 17:17:09 localhost kernel: [    3.271802] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
May  5 17:17:09 localhost kernel: [    4.278854] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
May  5 17:17:09 localhost kernel: [    4.722083] fuse init (API version 7.22)
May  5 17:17:09 localhost kernel: [    4.731844] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
May  5 17:17:09 localhost kernel: [    4.731923] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May  5 17:17:09 localhost kernel: [    5.012972] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May  5 17:17:09 localhost kernel: [    5.013246] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May  5 17:17:09 localhost kernel: [    5.013681] cectx c810023c.aocec: aml_cec_class_devnode(): mode is 1b6
May  5 17:17:09 localhost kernel: [    5.030875] Driver for 1-wire Dallas network protocol.
May  5 17:17:09 localhost kernel: [    5.225883] usbcore: registered new interface driver ftdi_sio
May  5 17:17:09 localhost kernel: [    5.225936] usbserial: USB Serial support registered for FTDI USB Serial Device
May  5 17:17:09 localhost kernel: [    5.226040] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
May  5 17:17:09 localhost kernel: [    5.226101] usb 1-1.4: Detected FT232RL
May  5 17:17:09 localhost kernel: [    5.226107] usb 1-1.4: Number of endpoints 2
May  5 17:17:09 localhost kernel: [    5.226112] usb 1-1.4: Endpoint 1 MaxPacketSize 64
May  5 17:17:09 localhost kernel: [    5.226117] usb 1-1.4: Endpoint 2 MaxPacketSize 64
May  5 17:17:09 localhost kernel: [    5.226122] usb 1-1.4: Setting MaxPacketSize 64
May  5 17:17:09 localhost kernel: [    5.226466] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
May  5 17:17:09 localhost kernel: [    5.281063] ionvideo open
May  5 17:17:09 localhost kernel: [    5.477881] ionvideo_stop_generating!!!!
May  5 17:17:09 localhost kernel: [    5.477945] ionvideo release
May  5 17:17:09 localhost kernel: [    5.491447] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
May  5 17:17:09 localhost kernel: [    5.537767] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SS
May  5 17:17:09 localhost kernel: [    9.918085] libphy: stmmac-0:00 - Link is Up - 1000/Full
May  5 17:17:09 localhost kernel: [   13.791784] vout_serve: vmode set to 1080p60hz
et un lsusb donne :
jeedom@odroidc2:/var/log$ sudo lsusb
Bus 001 Device 007: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 008: ID 0658:0200 Sigma Designs, Inc.
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Les seuls usb utilisés sont pour le rfxcom et la clé zwave
Odroid C2 / Jeedom stable
Zwave.me UZB1 / RFXtrx433E / HEM2 / Orvibo / Connexoon / Netatmo
Synology DS1512+ / FBX6
Un grand MERCI à l'équipe Jeedom !
romain38
Message par romain38 » 20 mai 2017, 08:09
mutmut a écrit :
19 mai 2017, 23:54
merci romain38 our les chemins.
Par contre je n'ai pas le syslog du crash et rien de visible dans le kern.log
MAIS j'ai trouvé dans user.log les 2 crash (30/4 et 5/5 à la même heure !!!) et redémarrage (1/5 et 7/5) :
Apr 30 17:17:07 localhost mtp-probe: checking bus 1, device 7: "/sys/devices/dwc2_b/usb1/1-1/1-1.4"
Apr 30 17:17:07 localhost mtp-probe: bus: 1, device: 7 was not an MTP device
Apr 30 17:17:07 localhost mtp-probe: checking bus 1, device 8: "/sys/devices/dwc2_b/usb1/1-1/1-1.3"
Apr 30 17:17:07 localhost mtp-probe: bus: 1, device: 8 was not an MTP device
May  1 19:05:52 localhost node[1608]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
May  1 19:05:52 localhost node[1608]: *** WARNING *** Please fix your application to use the native API of Avahi!
May  1 19:05:52 localhost node[1608]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
May  1 19:05:52 localhost node[1608]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
May  1 19:05:52 localhost node[1608]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
May  5 17:17:09 localhost mtp-probe: checking bus 1, device 8: "/sys/devices/dwc2_b/usb1/1-1/1-1.3"
May  5 17:17:09 localhost mtp-probe: bus: 1, device: 8 was not an MTP device
May  5 17:17:09 localhost mtp-probe: checking bus 1, device 7: "/sys/devices/dwc2_b/usb1/1-1/1-1.4"
May  5 17:17:09 localhost mtp-probe: bus: 1, device: 7 was not an MTP device
May  7 13:21:07 localhost node[1568]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
May  7 13:21:07 localhost node[1568]: *** WARNING *** Please fix your application to use the native API of Avahi!
May  7 13:21:07 localhost node[1568]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
May  7 13:21:07 localhost node[1568]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
May  7 13:21:07 localhost node[1568]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
une idée par hasard ?
Salut Mutmut,
En effet les 2 redémarrages sont bien visibles !
Tu dois avoir un cron qui se déclenche à cette heure ci pour que les plantages soient si réguliers.
Ta sortie graphique est désactivée ? Tu utilise une carte SD ou alors une eMMC ?
De mon côté, je n'ai pas réussi à trouver la raison de mes plantages. Ce qui est sur, c'est que depuis que j'ai réactivé la sortie graphique, je n'ai plus de plantage.
Je tenterai de rejouer avec ce paramètre lors de la sortie d'un nouveau kernel...
Romain.
raslittle
Message par raslittle » 04 juin 2017, 21:11
Je tente de brancher une enceinte filaire sur mon odroid via l'adaptateur USB, mais je n'ai aucun son en sortie.
J'ai lu dans un post qu'il fallait peut être modifier un paramètre.
Quelqu'un saurait comment procéder svp.
JEEDOM sur ODROID C2 + RfxTrx433E + Z-Stick AEON S2 + IPX800 V3&V4
PSX200-1205
Synology 213+
lulu740
Message par lulu740 » 08 juin 2017, 07:44
je voudrais basculer sur un Odroid C2, j'ai pris l'ensemble carte + Emmc + adaptateur SD. Le soucis je n arrive pas à voir ma carte Emmc à travers l'adaptateur SD sur mon bureau (que ce soit un PC, un mac), l'adaptateur est il defectueux ou avez vous installer par un autre biais.
Adaptateur EMMC---->micro-sd--------> adaptateur SD------>lecteur ordi.
koulyndriss
Message par koulyndriss » 08 juin 2017, 12:55
Non comme ça
Odroid c2 / KODI sur un autre c2
Clef USB Gen5 / dongle RFxcom / Xiaomi
éclairage en zigbee avec du Philips et ikea
tom74
Message par tom74 » 08 juin 2017, 13:04
Salut, mon ordi portable ne voyais pas l'emmc depuis le lecteur SD, sur ma tour, pas de problème,
J'ai quand même acheter un lecteur carte SD USB et çà fonctionne également .
Le problème doit survenir avec certains lecteurs...
lulu740
Message par lulu740 » 08 juin 2017, 14:57
Bonjour Tom74,
merci pour le retour. Frustrant tout cela, essayé sur mac mini, macbook pro,portable pc et tour pc, rien à faire. Bon vais esperer qu'avec un adaptateur usb---->micro SD cela fonctionnera.
tom74
Message par tom74 » 08 juin 2017, 20:28
Oui bizarre que çà ne fonctionne avec aucun de tes périph...
Tu utilise toujours le même adaptateur?
domoggvad
Message par domoggvad » 08 juin 2017, 20:31
Tu peux aussi le faire par une carte SD, puis tout basculer sur emmc,
sudo nand-sata-install
sinon je sais que j'ai eu ce problème, le lecteur de carte ne rentre pas correctement dans la cle usb, j'ai du limer un petit peu les deux coins pour que tout rentre dans l'ordre
Envoyé de mon HUAWEI VNS-L31 en utilisant Tapatalk
Pièces jointes
3 Odroid C2 (Prod - secours - test) Z83 tests: rfxcom + Z-wave- Clims DAIKIN - espeasy - thekey - Xiaomi - Telinfo - broadlink... widget V3 :viewtopic.php?f=29&t=44183&p=717810#p717810
lulu740
Message par lulu740 » 08 juin 2017, 20:56
Merci à vous deux effectivement, je viens de limer sur le coté et bingo.Bon on va pouvoir attaquer enfin la suite........ Encore une fois merci, j'etais loin de penser à un tel soucis..... ;)
lulu740
Message par lulu740 » 09 juin 2017, 16:21
Bon la je peche à nouveau, installation de l'os apparemment faite, j arrive à me connecter en SSH, mais pas d'installation de Jeedom.
Faut il le faire manuellement, je pensais que cela se faisait comme sur le rasp.....
A +++ merci
domoggvad
Message par domoggvad » 09 juin 2017, 16:40
Si tu vas sur la fiche, installation, c est la partie 6 autres installations, trois lignes à saisir, et le reste se fait tout seul
lulu740
Message par lulu740 » 09 juin 2017, 16:49
Bonjour Domoggvad,
merci, donc je retombe sur une procedure d'installation comme avant. Faut il aussi faire manuellement, l'extension de partition ???? la modif du "tmp".
Merci de ton aide, je pensais en prenant l'image "odroid", cela se faisait d'office..
domoggvad
Message par domoggvad » 09 juin 2017, 16:58
Non, il n'y a plus d image toute prête , tout se fait automatiquement à l installation
lulu740
Message par lulu740 » 10 juin 2017, 05:58
Merci domoggvad,
me semblait que c 'était une netinstall la version que j'avais téléchargé. Bon malgré tes commandes de 3 lignes je garde un écran blanc, m'en vais ré-installer le tout encore une fois .......
Vous tiens au courant.
Bonne journée.....
Pièces jointes
Capture d’écran 2017-06-10 à 05.55.50.png (54.05 Kio) Consulté 1430 fois
lulu740
Message par lulu740 » 11 juin 2017, 14:04
Bon après moulte re-install rien à faire, je me connecte à mon adresse ip de l'odroid, je reçois un écran blanc, rien à faire quand ça veut pas ça veut pas, bizarrement je tapes les 3 lignes de la rubrique "autre", mis à part la première pas de réaction de la commande "./install.sh". La led bleu qui clignote .....
essayer avec la emmc et une micor-sd...... me suis retaper tout le post en lecture, mais pas de miracle.
domoggvad
Message par domoggvad » 11 juin 2017, 14:58
Bizarre, je viens de le faire deux fois est tout est OK
Tu as pris quel image ?
lulu740
Message par lulu740 » 11 juin 2017, 18:27
Hello, ben je commence a me poser des questions ???? J ai pris celle dont j ai fait la copie écran.... j'arrive à me connecter en ssh mais rien de plus.
domoggvad
Message par domoggvad » 11 juin 2017, 18:58
Pour la netinstall, tu copie, tu branche, puis tu laisse faire, tu n' as pas besoin de ssh, juste de ton adresse IP sur un navigateur pour suivre l installation qui dure entre 20 et 30 ninutes
domoggvad
Message par domoggvad » 11 juin 2017, 19:00
À la fin de l installation, tu auras le login Jeedom.. admin. admin
Revenir vers « Do-It-Yourself ("Faire-soi-même") »
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 14 invités
