df -h
df -h
pi@raspberrypi:~ $ sudo apt-get update; sudo apt-get upgrade -y; sudo apt-get install rpi-update -y
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Get:4 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages [56.8 kB]
Get:5 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages [95.2 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages [1,360 B]
Fetched 11.8 MB in 23s (511 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
rpi-update is already the newest version (20140705).
pi@raspberrypi:~ $ sudo rpi-update
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
*** Performing self-update
*** Relaunching after update
*** Your firmware is already up to date
sudo blkid
je n'ai pas mon système en ce moment sous la main ... mais voici le résultat d'autres commandes ...lone a écrit : ↑13 avr. 2018, 07:13Faispour voir à quoi correspond PARTUUID=ba5c2b98-02Code : Tout sélectionner
sudo blkid
(pour le cmdline.txt je voulais juste savoir, avec les images déjà prêtes je pense que tu n'as pas besoin de faire la modif)
pi@raspberrypi:~ $ sudo fdisk -l
Disk /dev/mmcblk0: 3.7 GiB, 3904897024 bytes, 7626752 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xba5c2b98
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 93802 85611 41.8M c W95 FAT32 (LBA)
/dev/mmcblk0p2 98304 7626751 7528448 3.6G 83 Linux
Disk /dev/sda: 55.9 GiB, 60022480896 bytes, 117231408 sectors
Disklabel type: dos
Disk identifier: 0xa8fe70f4
/dev/sda1 8192 93802 85611 41.8M c W95 FAT32 (LBA)
/dev/sda2 98304 3629055 3530752 1.7G 83 Linux
pi@raspberrypi:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 3.6G 1.3G 2.2G 37% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 6.2M 458M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 22M 20M 53% /boot
tmpfs 93M 0 93M 0% /run/user/1000
je ne veux booter QUE sur mon SSD (qui est en usb) MAIS si j'enlève la SD ... rien ne se passe ! et OUI j'ai bien gravé dessus ton image !
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/sda2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
oui j'ai bien vu que tu n'es pas l'auteur de ce postlone a écrit : ↑13 avr. 2018, 08:43Ce n'est pas moi l'auteur de ce post, c'est Bronche, ce n'est pas mon image.
Tu as gravé bien son image sur ton ssd ?
Tu dis "dans le config.tx à la fin j'ai bien : program_usb_boot_mode=1" , cette fois il faut que ce soit sur la partition boot de ta SD.
Fais une modif de cmdline.txt sur la SD:Code : Tout sélectionner
sudo vcgencmd otp_dump | grep 17:
oui je confirme ! c'est bien le caslone a écrit : ↑13 avr. 2018, 10:25doit te répondre 17:3020000aCode : Tout sélectionner
C'est le cas ?
+1lone a écrit : ↑13 avr. 2018, 10:25doit te répondre 17:3020000aCode : Tout sélectionner
C'est le cas ?
sudo blkid
sudo nano /boot/cmdline.txt
sudo nano /etc/fstab
Donc on se fout complètement de savoir si on est sur une SD ou un SSD....proc /proc proc defaults 0 0
PARTUUID=a986b25d-01 /boot vfat defaults 0 2
PARTUUID=a986b25d-02 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
tmpfs /tmp/jeedom tmpfs defaults,size=128M $
- Si je ne mets pas de SD dans mon pi3, le pi3 ne démarre pas ! ... même avec le SSD branché dessus !bronche a écrit : ↑13 avr. 2018, 10:35+1lone a écrit : ↑13 avr. 2018, 10:25doit te répondre 17:3020000aCode : Tout sélectionner
C'est le cas ?
Faut commencer par ça ...
Tu n'as pas répondu à ma question... pourquoi tu as une Sd dans ton PI3 si tu veux booter sur un SSD !!
Je le répète, pas de modification des fichiers de configuration. Le pi 3 se moque éperdument de booter sur la SD ou l'USB, d'ailleurs l'image SSD et l'image SD que je mets à disposition sont exactement... les mêmes !
Si tu n'as pas de boot c'est que :
1/ Ton PI3 n'est pas configuré pour booter sur l'usb. Dans ce cas voir la doc pour reprogrammer l'OTP ( One-Time Programmable)
2/ Ton SSd n'est pas reconnu, mal alimenté, défectueux.
Il n'y a pas d'autres explications.
Amitiés
Phil
