Re: [Tuto] installation sécurisé Jeedom avec Docker + périphériques USB
Publié : 31 août 2019, 22:20
Moi quand le lance "docker start jeedom-server" , ca bloque a
étape 6 téléchargement de jeedom réussie
All init complete
Start apache2
Failed to connect to bus: No such file or directory
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.65.3. Set the 'ServerName' directive globally to suppress this message
Restarting Apache httpd web server: apache2.
Start sshd
start-stop-daemon: warning: failed to kill 84: No such process
Restarting OpenBSD Secure Shell server: sshd.
Start atd
/sbin/start-stop-daemon: warning: failed to kill 102: No such process
Stopping deferred execution scheduler: atd.
Starting deferred execution scheduler: atd.
/usr/lib/python2.7/dist-packages/supervisor/options.py:298: UserWarning: Supervisord is running as root and it is searching for its configuration file in default locations (including its current working directory); you probably want to specify a "-c" argument specifying an absolute path to a configuration file for improved security.
'Supervisord is running as root and it is searching '
2019-08-31 19:42:55,752 CRIT Supervisor running as root (no user in config file)
2019-08-31 19:42:55,752 INFO Included extra file "/etc/supervisor/conf.d/supervisord.conf" during parsing
Unlinking stale socket /var/run/supervisor.sock
2019-08-31 19:42:56,064 INFO RPC interface 'supervisor' initialized
2019-08-31 19:42:56,064 CRIT Server 'unix_http_server' running without any HTTP authentication checking
2019-08-31 19:42:56,065 INFO supervisord started with pid 104
2019-08-31 19:42:57,067 INFO spawned: 'cron' with pid 107
2019-08-31 19:42:58,069 INFO success: cron entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
J e^peu arreter avec Ctrl + C mais jeedom nes'ouvre pas a l'adresse http://localhost:9080/
Une idée ?
Thierry
All init complete
Start apache2
Start sshd
Start atd
Une idée ?
Thierry
