A très bientôt !
Plugin blea
Theking31
Re: Plugin blea
Message par Theking31 » 17 avr. 2018, 16:15
Petit problème dans l'installation des dépendances suite à une restauration avec droit de jeedom :o
Des idées ?
Launch install of blea dependancy
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_8.x stretch InRelease
Reading package lists...
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
libffi-dev is already the newest version (3.2.1-6).
libssl-dev is already the newest version (1.1.0f-3+deb9u2).
python-dev is already the newest version (2.7.13-2).
python-requests is already the newest version (2.12.4-1).
bluetooth is already the newest version (5.43-2+rpt2+deb9u2).
python-pip is already the newest version (9.0.1-2+rpt2).
0 upgraded, 0 newly installed, 0 to remove and 14 not upgraded.
git is already the newest version (1:2.11.0-3+deb9u2).
libglib2.0-dev is already the newest version (2.50.3-2).
Requirement already satisfied: pyudev in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from pyudev)
Requirement already satisfied: pyserial in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: requests in /usr/lib/python3/dist-packages
Requirement already satisfied: cryptography in /usr/lib/python3/dist-packages
Requirement already satisfied: pycrypto in /usr/lib/python3/dist-packages
Cloning into 'bluepy'...
running build
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/bluepy
copying bluepy/sensortag.py -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/thingy52.py -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/get_services.py -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/__init__.py -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/btle.py -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/blescan.py -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/scanner.py -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/uuids.json -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/bluez-src.tgz -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/bluepy-helper.c -> build/lib.linux-armv7l-2.7/bluepy
copying bluepy/Makefile -> build/lib.linux-armv7l-2.7/bluepy
running install
Working dir is /tmp/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
running build
running build_py
copying bluepy/bluepy-helper -> build/lib.linux-armv7l-2.7/bluepy
running install_lib
copying build/lib.linux-armv7l-2.7/bluepy/sensortag.py -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/thingy52.py -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/bluepy-helper.c -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/uuids.json -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/get_services.py -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/__init__.py -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/bluez-src.tgz -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/btle.py -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/bluepy-helper -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/Makefile -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/blescan.py -> /usr/local/lib/python2.7/dist-packages/bluepy
copying build/lib.linux-armv7l-2.7/bluepy/scanner.py -> /usr/local/lib/python2.7/dist-packages/bluepy
byte-compiling /usr/local/lib/python2.7/dist-packages/bluepy/sensortag.py to sensortag.pyc
byte-compiling /usr/local/lib/python2.7/dist-packages/bluepy/thingy52.py to thingy52.pyc
byte-compiling /usr/local/lib/python2.7/dist-packages/bluepy/get_services.py to get_services.pyc
byte-compiling /usr/local/lib/python2.7/dist-packages/bluepy/__init__.py to __init__.pyc
byte-compiling /usr/local/lib/python2.7/dist-packages/bluepy/btle.py to btle.pyc
byte-compiling /usr/local/lib/python2.7/dist-packages/bluepy/blescan.py to blescan.pyc
byte-compiling /usr/local/lib/python2.7/dist-packages/bluepy/scanner.py to scanner.pyc
running install_egg_info
running egg_info
creating bluepy.egg-info
writing bluepy.egg-info/PKG-INFO
writing top-level names to bluepy.egg-info/top_level.txt
writing dependency_links to bluepy.egg-info/dependency_links.txt
writing entry points to bluepy.egg-info/entry_points.txt
writing manifest file 'bluepy.egg-info/SOURCES.txt'
reading manifest file 'bluepy.egg-info/SOURCES.txt'
removing '/usr/local/lib/python2.7/dist-packages/bluepy-1.1.2.egg-info' (and everything under it)
Copying bluepy.egg-info to /usr/local/lib/python2.7/dist-packages/bluepy-1.1.2.egg-info
running install_scripts
Installing blescan script to /usr/local/bin
Installing thingy52 script to /usr/local/bin
Installing sensortag script to /usr/local/bin
Everything is successfully installed!
running build
running build_py
creating build
running install
running build
running build_py
running install_lib
running egg_info
Jeedom 4.0.23 sur Intel NUC 6CAYH | Linux 4.9.0-11-amd64 | Debian 9.11
Rfxcom | Z-Wave Plus Z-Stick GEN5 | Conbee 2 | => sur hub alimenté
Blea| Brodlink | Xiaomi |ESPeasy | Wifilightv2
Theduck38
Helper
Contact :
Re: Plugin blea
Message par Theduck38 » 17 avr. 2018, 16:36
Quel problème ? Tes logs ont l'air OK...
-- TD38 --
Helper Officiel Jeedom
Theking31
Re: Plugin blea
Message par Theking31 » 17 avr. 2018, 16:58
C'est ça le soucis :lol: :D
Problème reçurent (dépendances not ok) depuis quelques pages en arrières et merci à bertrandF pour sa solution
bertrandF a écrit :
04 avr. 2018, 12:14
Pour info, j'ai pu régler mon souci avec les dépendances BLEA en exécutant la commande :
sudo pip install bluepy
Merci à toi aussi Theduck38 pour le soutient ;)
znation
Re: Plugin blea
Message par znation » 28 avr. 2018, 09:57
J'ai remarqué il y a quelques jours que j'ai des soucis avec mes NUT.
Ils restent toujours présents en statut meme quand ils ne sont plus présents (pile enlevé par ex), par contre ils passent à -200dbm ... je comprends pas trop.
Avez vous une idée ?
EDIT : j'ai du supprimer/recréer (scanner) l'equipement pour que ça refonctionne ... bizarre !
JEEDOM v3.3.31 - NUC Z83 II
bphoque
Re: Plugin blea
Message par bphoque » 29 avr. 2018, 09:00
Les personnes qui utilisent le plugin avec stretch sur une VM ESxi ont-ils toujours un problèmes de charges CPU ? Ce problème intervient quelque heure après la mise en route du plugin.
Jeedom Smart pour les tests (beta + appmobile)
Jeedom sur NUC en prod
Protocole : Blea, Enocean, Zwave, Edisio, RFXCOM, RFPLAYER, Zigbee
domokalu
Re: Plugin blea
Message par domokalu » 29 avr. 2018, 21:28
Oui, la VM n'est plus contactable via ssh, obligé de rebooter.
bphoque
Re: Plugin blea
Message par bphoque » 01 mai 2018, 09:20
domokalu a écrit :
29 avr. 2018, 21:28
Je viens de tester. Effectivement, le problème est tjs présent.
Swr
Re: Plugin blea
Message par Swr » 02 mai 2018, 07:44
J'ai perdu le "coeur" de mon antenne PI zero aprés plusieurs mois sans problème.
Il semble que Jeedom n'arrive pas à envoyer les fichiers :
bash: /home/pluginblea/blead/resources/install.sh: No such file or directory
J'arrive bien à ma logger sur le Pizero avec putty et "pluginblea" + mot de passe
Auriez-vous une piste?
Pièces jointes
Swr
Re: Plugin blea
Message par Swr » 02 mai 2018, 13:42
Swr a écrit :
02 mai 2018, 07:44
J'ai essayé de desintaller et remettre Blea sur Jeedom.
Le log des dépendances du Pi zéro est toujours :
HTTP.error (je vois une erreur à la création du fichier)
tar: Removing leading `/var/www/html/plugins/blea/core/class/../../' from member names
[Wed May 02 13:37:45.294194 2018] [:error] [pid 4571] [client 77.136.202.144:39171] PHP Warning: ssh2_scp_send(): Failure creating remote file: failed to send file in /var/www/html/plugins/blea/core/class/blea.class.php on line 1044, referer: https://xxxxxxx.ddns.net/index.php?v=d&m=blea&p=blea
rm: cannot remove '/var/www/html/plugins/blea/core/class/../../../../log/blea_Pi-zero_dependancy': No such file or directory
Par contre, je comprends pas comment resoudre
Merci de votre aide
Deepcore
Re: Plugin blea
Message par Deepcore » 02 mai 2018, 14:14
bphoque a écrit :
29 avr. 2018, 09:00
Non je n'ai pas ce problème de mon coté ... désolé ;)
Le plug-in tourne despuis 3 semaines sans problème
Jeedom Prod VM Debian 9 sous ESXi 6.7
Jeedom Dev Pi 2 Debian 9
Antenne : VM Debian 8 - HA-Bridge, Nut Serveur sous ESXi 6.0
Protocole : ZWave, ZigBee (Hue,Ikea,Xiaomi et Zigate), IP devices, Bluetooth
160 modules gérés
benj29
Contact :
Re: Plugin blea
Message par benj29 » 02 mai 2018, 14:37
Personne n'a d'idée pour surveiller l'état du démon (le coeur vert/rouge) d'une antenne BLEA et le remonter dans un virtuel façon démon = 1 / 0.
Je surveille le ping, j'ai eu quelques arrêts de démon (1 tous les 2/3 mois sur mes PI 3 ou sur ma VM de mon NAS) et c'est fâcheux car on en a aucune idée, il faut surveiller de temps à autre et découvrir.
Me_
Re: Plugin blea
Message par Me_ » 02 mai 2018, 14:50
benj29 a écrit :Personne n'a d'idée pour surveiller l'état du démon (le coeur vert/rouge) d'une antenne BLEA et le remonter dans un virtuel façon démon = 1 / 0.
Je n’utilise pas le plugin BLEA, mais avec Jeelink tu dois peut-être pouvoir faire cela.
Présentation
Mon matériel: ici
Deepcore
Re: Plugin blea
Message par Deepcore » 02 mai 2018, 14:58
benj29 a écrit :
02 mai 2018, 14:37
Salut Benj29,
Je cherche aussi et je tombé sur ce topic : viewtopic.php?f=23&t=27876&hilit=%C3%A9tat+deamon
Et celui la viewtopic.php?f=190&t=33016
160 modules gérés
benj29
Contact :
Re: Plugin blea
Message par benj29 » 02 mai 2018, 15:01
Merci, mais non... mais merci d'avoir voulu regarder.
Ce n'est pas aussi simple.
Le démon de BLEA ne me sert à rien.
Je n'ai aucun démon BLEA en local car je n'ai pas de clé bluetooth sur mon Jeedom.
Je passage par 3 antennes, 1 déporté en VM sur mon NAS (suite aux déboires de Debian 8 et BLEA qui pête quand il a envie, j'ai externalisé la clé SENA et c'est stable) ; 2 RPI 3 en BLEA.
Je n'ai aucun moyen de savoir que les démons sur mes 3 antennes sont OK sauf en allant les voir "à la main".
D'ailleurs dans santé, ça ne fait que monter/descendre.
J'avais pensé à récupérer l'état du démon (mais au delà du up et running, qui ne pas si ça marche réellement) et le traduire en virtuel 0/1. Mais je suis loin d'avoir les compétences pour faire cela.
superbricolo
Contact :
Re: Plugin blea
Message par superbricolo » 02 mai 2018, 15:02
Justement, j'ai eu l'idée de le faire. J'ai donc modifié le plugin pour qu'il surveille à intervalle régulier les antennes et qu'il relance le démon en cas de problème. Par contre je n'ai pas osé proposer ma modif car je ne suis pas sûr que c'était la philosophie prévue du développeur.
J'ai aussi augmenté quelques délais d'attente et le nombre de certain retry. J'ai une antenne sur un raspberry 1 et il y a quelques temps j'avais pas mal d'erreurs et d'arrêts du démon. Sans doute à cause de manque de puissance. En plus j'ai Wview pour ma station meteo qui tourne sur mon Raspberry et qui prend aussi un peu de puissance. Depuis les modifs programme, tout roule sans intervention.
Jeedom mini PC Core I5 4300U ESXI
Zwave: Z-Stick Gen5, 31 noeuds, XIAOMI: 13 périph RFLINK,RFPLAYER,ZIBASEDOM: OWL, sondes Oregon,Livolo,X2D STARBOX F03, ECO-DEVICE, Bluetooth, ORVIBO, Karotz, RM PRO
Ecran tactile sur Pi 3, Google Home
Site météo: flash.galaxy.free.fr
Deepcore
Re: Plugin blea
Message par Deepcore » 02 mai 2018, 15:08
benj29 a écrit :
02 mai 2018, 15:01
Ok je ne connaissais ton contexte, une piste peut etre ici viewtopic.php?f=157&t=28608&hilit=script+demon
160 modules gérés
benj29
Contact :
Re: Plugin blea
Message par benj29 » 02 mai 2018, 16:15
@ Deepcore, sujet déjà vu.
J'ai mis la solution en place mais peu d'intérêt.
Cela permet juste de lancer de manière automatique au premier démarrage (coupure électrique) le démon BLEA sur la RPI.
Mais ce n'est pas parce qu'un démon est lancé qu'il est OK ;).
@ superbricolo, je suis preneur de ce que tu as fait. C'est exactement ce que je voulais faire.
Visiblement tu n'as aussi aucune antenne en local.
Me_
Plugin blea
Message par Me_ » 02 mai 2018, 16:29
benj29 a écrit :Merci, mais non... mais merci d'avoir voulu regarder.
Avec Jeelink, tu peux "monitorer" un daemon "deporté"...!
Je le faisais pendant un temps pour ma téléinfo qui était déportée sur un rPi...
Présentation
Mon matériel: ici
benj29
Contact :
Re: Plugin blea
Message par benj29 » 02 mai 2018, 16:43
Je suis peut être bête mais pour moi non.
Il faut que ton déporté, soit un Jeedom, non ?
Dans mon cas, les RPI ou la VM sont des Debian8 avec un démon BLEA qui tourne.
Ce démon n'est pas un démon "Jeedom" mais bien un script que tu installes etc.
cadavor
Re: Plugin blea
Message par cadavor » 02 mai 2018, 17:03
benj29 a écrit :
02 mai 2018, 16:43
Plugin Script
Script ssh_command
Et la commande SSH qui va bien pour connaitre l'état du démon/process/service
Jeedom Stable 3.3
NUC Z83 + Aeotec Z-Stick Gen5
Z-Wave FGR + FGMS + FGDS + FGFS + FGK + FGWPE + ZW062 + ZW080
GH Mini + Orvibo AllOne + Playbulb + Miband2
Revenir vers « [Plugin Officiel] BLEA »
