Mi Plant pas de remontée
LennVilardi
Message par LennVilardi » 10 avr. 2019, 10:33
Ce Mi Plant est sur une antenne déporté à base de rpi0w.
L'antenne a bien son cœur en vert.
Pour avoir une remontée d'infos de ce capteur, je dois mettre l'antenne en mode inclusion et faire un refresh sur le capteur.
Sinon quand je fais un refresh normal aucune valeur ne change.
Voici le log lors d'un refresh forcé :
[2019-04-10 10:13:18][DEBUG] : SOCKETHANDLER------Client connected to [10.0.0.9:34660]
[2019-04-10 10:13:18][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey":"MYAPIKEY","cmd":"refresh","device":{"id":"C4:7C:8D:67:2A:A9"},"command":{"device":{"id":"C4:7C:8D:67:2A:A9","delay":"14400","needsrefresh":1,"name":"miflora"},"name":"miflora"}}
[2019-04-10 10:13:18][DEBUG] : SOCKETHANDLER------Client disconnected from [10.0.0.9:34660]
[2019-04-10 10:13:18][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2019-04-10 10:13:18][DEBUG] : SOCKET-READ------Received command from jeedom : refresh
[2019-04-10 10:13:18][DEBUG] : SOCKET-READ------Attempt an action on a device
[2019-04-10 10:13:19][DEBUG] : SOCKET-READ------Action Thread Launched
[2019-04-10 10:13:19][DEBUG] : ACTION------Attempt to refresh values
[2019-04-10 10:13:19][DEBUG] : CONNECTOR------Connecting : C4:7C:8D:67:2A:A9 with bluetooth 0
[2019-04-10 10:13:19][DEBUG] : CONNECTOR------Failed to connect to peripheral C4:7C:8D:67:2A:A9, addr type: public attempt 1
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Connected... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Reading Characteristic...C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Characteristic Readen .... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Writing Characteristic... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : CONNECTOR------Characteristic written... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : {'rsp': ['wr']}
[2019-04-10 10:13:21][DEBUG] : Subscribing to notification : C4:7C:8D:67:2A:A9
[2019-04-10 10:13:21][DEBUG] : Delegated
[2019-04-10 10:13:21][DEBUG] : {'battery': 100, 'firmware': '3.1.9', 'id': u'C4:7C:8D:67:2A:A9'}
[2019-04-10 10:13:21][DEBUG] : Subscribing for 2s
[2019-04-10 10:13:21][DEBUG] : SENDER------Send to jeedom : {u'devices': {u'C4:7C:8D:67:2A:A9': {'battery': 100, 'source': 'RPIZW', 'firmware': '3.1.9', 'id': u'C4:7C:8D:67:2A:A9'}}}
[2019-04-10 10:13:22][DEBUG] : Starting new HTTP connection (1): 10.0.0.9
[2019-04-10 10:13:22][DEBUG] : http://10.0.0.9:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=MYAPIKEY HTTP/1.1" 200 0
[2019-04-10 10:13:22][DEBUG] : CONNECTOR------Disconnecting... C4:7C:8D:67:2A:A9
[2019-04-10 10:13:22][DEBUG] : CONNECTOR------Disconnected...C4:7C:8D:67:2A:A9
[2019-04-10 10:13:22][DEBUG] : Device disconnected
Une idée ?
cariakou
Re: Mi Plant pas de remontée
Message par cariakou » 11 avr. 2019, 21:45
Bonjour ,
J'ai le meme problème avec le plug-ing Bluetooth Advertisement (blea) et les miflora. Les données ne remontent pas et je n'ai aucun problème dans les logs meme en debug.
LennVilardi
Message par LennVilardi » 15 avr. 2019, 15:20
J'ai essayé avec un autre OS (Dietpi) à la place de Raspbian
J'ai acheté une antenne Sena et désactivé l'antenne du pi 0
Je suis passé d'un rpi zero à un pi 2
Il s'agit de ma 3ème antenne, si je mets le Mi Plant à côté de mes 2 autres antennes, toutes les données remontent !
LennVilardi
Message par LennVilardi » 27 avr. 2019, 23:03
240 vues pas une réponse en 12 jours je désespère
eristoff
Message par eristoff » 28 avr. 2019, 10:47
C'est la notification qui n'est pas reçue. En gros après un refresh manuel le plugin se connecte au Mi Flora, envoie une demande de mise à jour, créé un thread pour attendre la notification pendant 2s et se déconnecte. Et la notification n'est pas reçue.
J'ai proposé une modif qui a amélioré un peu chez moi en laissant la connexion ouverte
Quelques infos pour tester "à la main" en dehors du plugin : https://www.fanjoe.be/?p=2741
Cela permet de vérifier qu'il n'y a pas de problème de portée déjà.
LennVilardi
Message par LennVilardi » 28 avr. 2019, 14:53
Sur une autre antenne les infos remontent, j'ai donc recopié le dossier blead de l'antenne qui fonctionne vers celle qui ne remonte que partiellement les infos. Cela ne change rien.
J'avais une antenne alfa 9dbi qui traînait je l'ai rajouté à une clé Sena UD100, donc c'est pas une question de portée.
J'essaye ton script pour voir. Merci pour l'aide
LennVilardi
Message par LennVilardi » 28 avr. 2019, 15:16
./fanjoe.sh: ligne 16: amp : commande introuvable
./fanjoe.sh: ligne 16: gt : commande introuvable
./fanjoe.sh: ligne 16: /dev/null: Permission non accordée
connect: Device or resource busy (16)
Nom :
./fanjoe.sh: ligne 54: bc : commande introuvable
./fanjoe.sh: ligne 58: bc : commande introuvable
Température : °C
Ensoleillement : 0 lux
Humidité : 0 %
Engrais : 0 uS/cm
Batterie : 0 %
Version :
connect error: Software caused connection abort (103)
eristoff
Message par eristoff » 29 avr. 2019, 09:14
il faut installer bc (apt-get install bc) et remplacer les & et > par & et >
