Plugin SMS
Re: Plugin SMS
A l'instant :
[643812.664403] usb 1-1.3: USB disconnect, device number 4
[643824.685453] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
[643824.789028] usb 1-1.4: New USB device found, idVendor=05c6, idProduct=f000
[643824.789044] usb 1-1.4: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[643824.789050] usb 1-1.4: Product: Qualcomm CDMA Technologies MSM
[643824.789057] usb 1-1.4: Manufacturer: Qualcomm, Incorporated
[643824.789063] usb 1-1.4: SerialNumber: 356793032396525
[643824.791648] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[643824.808234] scsi host1: usb-storage 1-1.4:1.0
[643825.806336] scsi 1:0:0:0: CD-ROM WCDMA MMC Storage 2.31 PQ: 0 ANSI: 2
[643825.809935] sr 1:0:0:0: [sr0] scsi-1 drive
[643825.810852] sr 1:0:0:0: Attached scsi CD-ROM sr0
[643825.811094] sr 1:0:0:0: Attached scsi generic sg0 type 5
avec cela dans le lsusb :
Bus 001 Device 005: ID 05c6:f000 Qualcomm, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Re: Plugin SMS
A priori ta clé n'est pas correctement détectée
tu devrais avoir dans tes logs
[ 8.794316] usbcore: registered new interface driver usbserial
[ 8.795769] usbcore: registered new interface driver usbserial_generic
[ 8.797280] usbserial: USB Serial support registered for generic
[ 8.811286] usbcore: registered new interface driver option
[ 8.812627] usbserial: USB Serial support registered for GSM modem (1-port)
[ 8.813249] option 1-1.4:1.0: GSM modem (1-port) converter detected
[ 8.814741] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB0
[ 8.814879] option 1-1.4:1.1: GSM modem (1-port) converter detected
[ 8.815508] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB1
[ 8.815623] option 1-1.4:1.2: GSM modem (1-port) converter detected
[ 8.821046] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB2
indiquant la creation des dev ttyUSB pour l'accés à la clé
As tu pu tester la clé sur un autre systeme ?
Système DIY 2 PI3 avec SSD (voir mon profil pour le détail)
Re: Plugin SMS
quelle est la réf exacte de ta clé stp ? je vais prendre une identique .... bizarre ...
Re: Plugin SMS
je l'ai acheté ici sur amazon Clé USB UMTS HSDPA UMTS Huawei E169
https://www.amazon.fr/gp/product/B004DE ... UTF8&psc=1
Attention elle ne fonctionne pas avec le plugin SMS mais très bien avec gammu
Re: Plugin SMS
jevais prenre celle qui fonctionne avec le plugin , ça sera plus simple ... celle-ci : Huawai E220 , non ?
Re: Plugin SMS
Si tu veux utiliser le plugin SMS au lieu du plugin gammu , il faut effectivement prendre une clé compatible: mais la il faut demander à qu'un qui a cette clé.
Re: Plugin SMS
celle que j'ai là est compatible avzc le plugin sms ... c'est dommage pourtant.
Re: Plugin SMS
Ca fait plus d'une semaine que je tente d'exploiter le plugins SMS, je rencontre des problèmes de stabilité.
J'utilise une clé Alcatel One Touch X220L qui fonctionne correctement, Jeedom peut envoyer et recevoir des SMS, sauf que ca ne dure pas.
Je ne sais pour quelle raison, mais à un moment, le process ne reçoit plus de réponse à la commande AT+CREG? juste après l'envoi d'un SMS.
Si je redémarre le plugins, il n'arrive plus à ouvrir le tty (ttyUSB3), je suis obligé de redémarrer Jeedom (2.2.6/RPI2)
Plantage:
Redémarrage
Plantage:
DEBUG: write: AT+CSQ
DEBUG: response: ['+CSQ: 28,99', 'OK']
DEBUG: write: AT+CMGL=0
DEBUG: response: ['OK']
DEBUG: write: AT+CREG?
DEBUG: response: ['+CREG: 0,1', 'OK']
2016-04-26 08:26:17,559 - Thread-3 - smscmd:120 - DEBUG - Client connected to [127.0.0.1:51395]
DEBUG: Client connected to [127.0.0.1:51395]
2016-04-26 08:26:17,560 - Thread-3 - smscmd:123 - DEBUG - Message read from socket: {"number":"+336XXXXXXX3","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
DEBUG: Message read from socket: {"number":"+336XXXXXXX3","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
2016-04-26 08:26:17,561 - Thread-3 - smscmd:125 - DEBUG - Client disconnected from [127.0.0.1:51395]
DEBUG: Client disconnected from [127.0.0.1:51395]
2016-04-26 08:26:17,582 - Thread-3 - smscmd:120 - DEBUG - Client connected to [127.0.0.1:51396]
DEBUG: Client connected to [127.0.0.1:51396]
2016-04-26 08:26:17,583 - Thread-3 - smscmd:123 - DEBUG - Message read from socket: {"number":"+336XXXXXXX77","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
DEBUG: Message read from socket: {"number":"+336XXXXXXX77","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
2016-04-26 08:26:17,584 - Thread-3 - smscmd:125 - DEBUG - Client disconnected from [127.0.0.1:51396]
DEBUG: Client disconnected from [127.0.0.1:51396]
2016-04-26 08:26:18,377 - MainThread - smscmd:338 - DEBUG - Message received in socket messageQueue
DEBUG: Message received in socket messageQueue
2016-04-26 08:26:18,379 - MainThread - smscmd:340 - DEBUG - Message : {"number":"+336XXXXXXX3","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
DEBUG: Message : {"number":"+336XXXXXXX3","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
DEBUG: write: AT+CMGS=42
DEBUG: response: ['> ']
DEBUG: write: 0021470B91331234567890123456CC53981D96B7CBA0F29C0E0A8FE9697BA10C6A86E5E434E80FC2A16536
DEBUG: response: ['+CMGS: 71', 'OK']
2016-04-26 08:26:23,387 - MainThread - smscmd:338 - DEBUG - Message received in socket messageQueue
2016-04-26 08:26:23,389 - MainThread - smscmd:340 - DEBUG - Message : {"number":"+336XXXXXXX77","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
DEBUG: Message : {"number":"+336XXXXXXX77","message":"L'alarme est activ\u00e9e Mardi \u00e0 8h26"}
DEBUG: write: 0021480B91123456789012345678CC53981D96B7CBA0F29C0E0A8FE9697BA10C6A86E5E434E80FC2A16536
2016-04-26 09:04:53,993 - MainThread - smscmd:568 - DEBUG - Daemon
2016-04-26 09:04:53,994 - MainThread - smscmd:569 - DEBUG - Check PID file
2016-04-26 09:04:53,995 - MainThread - smscmd:574 - DEBUG - PID file '/tmp/sms.pid'
2016-04-26 09:04:53,995 - MainThread - smscmd:582 - DEBUG - PID file does not exists
2016-04-26 09:04:53,996 - MainThread - smscmd:590 - DEBUG - Check platform
2016-04-26 09:04:53,996 - MainThread - smscmd:591 - DEBUG - Platform: linux2
2016-04-26 09:04:53,997 - MainThread - smscmd:593 - DEBUG - Write PID file
2016-04-26 09:04:53,998 - MainThread - smscmd:600 - DEBUG - Deactivate screen printouts
2016-04-26 09:04:53,998 - MainThread - smscmd:603 - DEBUG - Start daemon
2016-04-26 09:04:54,014 - MainThread - smscmd:326 - DEBUG - Writing PID 31304 to /tmp/sms.pid
2016-04-26 09:04:54,023 - MainThread - smscmd:178 - DEBUG - Start listening...
2016-04-26 09:04:54,025 - MainThread - smscmd:181 - DEBUG - Connecting to GSM Modem...
INFO: Connecting to modem on port /dev/ttyUSB3 at 115200bps
DEBUG: write: ATZ
2016-04-26 09:05:04,039 - MainThread - smscmd:224 - ERROR - Exception: Timeout
ERROR: Exception: Timeout
Exception: Timeout
Jeedom 3.3.x / Odroid N2 [Alcatel OneTouch X220L + Milight + Aeotec Z-Stick S5 + Bluetooth + RFXCom]
Re: Plugin SMS
J ai fait un script toutes les heures qui relancent la clé .
plus de pb depuis.
faire la commande lsusb
Bus 001 Device 008: ID 12d1:150f Huawei Technologies Co., Ltd.
recuperer 12d1:150f pour le script
faire un script sous jeedom ou rasperry avec ceci
rm -f /tmp/sms.pid
sudo fuser /dev/ttyUSB0 -k
sudo usb_modeswitch -v 0x12d1 -p 0x150f --reset-usb
si qqu un à le moyen de connaitre l etat de la clé par commande je suis preneur . ca eviterai de faire un reset toutes les h et de le relancer qd il est planté
plus de pb depuis.
rm -f /tmp/sms.pid
Re: Plugin SMS
C'est un contournement plutôt sympa. Mais j'aurai une préférence pour corriger le problème à la source.
Ça sent le driver qui plante...
Re: Plugin SMS
oui aussi mais ca fait un moment que j ai ce dysfonctionnement
en attendant le plugin fonctionne .
a suivre il y aura une solution
Re: Plugin SMS
Un nouveau plantage suite à l'envoi de 2 sms ! Le reset du port USB ne fonctionne pas chez moi, smscmd tombe toujours en timeout.
Je vais devoir faire un reboot toutes les heures
Re: Plugin SMS
des que tu envoies 2 sms ca plante moi aussi
mais avec le usb_modeswitch ca reset
Re: Plugin SMS
Pas moi. J'ai baissé la vitesse de connexion à 9600 pour voir si ça change la donne.
Re: Plugin SMS
moi elle est a 9600 depuis le début
Re: Plugin SMS
Pas fiable ce truc. Pour un système de notification domotique ça craint.
Re: Plugin SMS
il y a des clé usb meilleur que d'autres? merci
Re: Plugin SMS
C'est pas la clé, c'est le système qui pose problème.
- idem
- Timide
- Contact :
Re: Plugin SMS
Depuis quelques semaines, je tourne en rond... La cle Huawei E220 marchait nickel depuis plus d un an...et la, elle part en timeout, le port usb disconnect, du coup, clé inexploitable.
Comme (choix perso) je prefere rester sur le plugin SMS plutot que Gammu, va falloir que je me trouve une nouvelle clé
Pour ceux qui veulent des clé 3G type E160E ou E1756, j'en ai pas mal en stock qui ne servent pas...
Jeedom DIY
Jeedom sur NUC est au top!!
http://geekandmore.fr
Unix/Linux, shell, SQL, gestion de projet, gestion des changements, consultant sénoir...
- idem
- Timide
- Contact :
Re: Plugin SMS
Hey copain de ug, j'ai tout pareil depuis quelques semaines aussi...Kitox a écrit :Bon, j'ai reçu ma clé Huwaei e200 avec une carte free a 2€ et tout marche niquel, mais que pour un moment .... toute les 24 heures le plugin merde et le daemon passe en non stop de OK a NOK ... desfois je recois un message "timedout", des fois " Error : Attempting to use a port that is not open" et là, depuis aujourd'hui, impossible de le relancer pour de bon ...
Avec vous des idées ou des questions pour que vous puissiez m'aider ?
EDIT: dans les log du dameon j'ai ceci :
Exception: Attempting to use a port that is not open
Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 763, in run
self.__target(*self.__args, **self.__kwargs)
File "/usr/share/nginx/www/jeedom/plugins/sms/ressources/smscmd/gsmmodem/serial_comms.py", line 93, in _readLoop
data = self.serial.read(1)
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 443, in read
if not self._isOpen: raise portNotOpenError
ValueError: Attempting to use a port that is not open
et au bout d'un moment je finti même avec une page "502 Bad Gateway
nginx"
Jeedom DIY
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 7 invités
