Plugin SMS
ddjaff33
Re: Plugin SMS
Message par ddjaff33 » 23 févr. 2015, 22:38
J'ai réinstallé la dernière version du plugin et voici les dernières lignes du mode debug. Ma clé HUAWEI reste non visible dans le port.
2015-02-23 22:33:27,381 - MainThread - smscmd:620 - DEBUG - Write PID file
2015-02-23 22:33:27,384 - MainThread - smscmd:627 - DEBUG - Deactivate screen printouts
2015-02-23 22:33:27,386 - MainThread - smscmd:630 - DEBUG - Start daemon
2015-02-23 22:33:27,435 - MainThread - smscmd:333 - DEBUG - Writing PID 18970 to /tmp/sms.pid
2015-02-23 22:33:27,469 - MainThread - smscmd:197 - DEBUG - Start listening...
2015-02-23 22:33:27,482 - MainThread - smscmd:200 - DEBUG - Connecting to GSM Modem...
INFO: Connecting to modem on port None at 115200bps
DEBUG: write: ATZ
2015-02-23 22:33:27,733 - MainThread - smscmd:224 - ERROR - Exception: 'Serial' object has no attribute 'fd'
ERROR: Exception: 'Serial' object has no attribute 'fd'
2015-02-23 22:33:27,736 - MainThread - smscmd:226 - DEBUG - Execute shell : /usr/bin/php /usr/share/nginx/www/jeedom/plugins/sms/ressources/smscmd/../../core/php/jeeSMS.php number="none" message="'Serial' object has no attribute 'fd'"
DEBUG: Execute shell : /usr/bin/php /usr/share/nginx/www/jeedom/plugins/sms/ressources/smscmd/../../core/php/jeeSMS.php number="none" message="'Serial' object has no attribute 'fd'"
Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
self.run()
File "/usr/lib/python2.7/threading.py", line 505, in run
self.__target(*self.__args, **self.__kwargs)
File "/usr/share/nginx/www/jeedom/plugins/sms/ressources/smscmd/gsmmodem/serial_comms.py", line 93, in _readLoop
data = self.serial.read(1)
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 439, in read
if self.fd is None: raise portNotOpenError
AttributeError: 'Serial' object has no attribute 'fd'
2015-02-23 22:33:27,779 - Thread-2 - smscmd:108 - DEBUG - Thread started, timeout = 10
DEBUG: Thread started, timeout = 10
2015-02-23 22:33:29,188 - Thread-2 - smscmd:111 - DEBUG - Return code: 0
DEBUG: Return code: 0
2015-02-23 22:33:29,191 - Thread-2 - smscmd:112 - DEBUG - Thread finished
DEBUG: Thread finished
ddjaff33
Re: Plugin SMS
Message par ddjaff33 » 23 févr. 2015, 22:41
Ah il y a du mieux. La clé est visible dans le port au bout du 3eme débranchage /rebranchage.
Et les sms refonctionnent !!! Merci à vous
Syll
Contact :
Re: Plugin SMS
Message par Syll » 24 févr. 2015, 23:20
BOnsoir,
ENcore moi et un problème :)
J'utilise le plugin avec une clef Huawey E220 sur un l'image Ubuntu précompilé avec Jeedom. Ceci en vmware player. Les USB remontent bien en compatibilité USB 2.
QUand je boot, les premiers SMS fonctionnent mais après j'ai un timeout en error qui vient dans l'interface Jeedom et ensuite, plus aucun échange, que ce soit en envoi ou réception. SI je reboot, ça refonctionne.
J'ai beau déco/reco la clef, changer le cable usb, ça change rien.
SUr Ubuntu, j'ai ça en erreur :
Dans le port SMS j'ai ça :
Jeedom - ESXi 6.7U2 - VM Debian 9.9 | 60 Modules Zwave | 12 Modules RFXCom | 15 modules Xiaomi | GSM/JPI | Kodi | SqueezeBox | GH |
loic
Administrateur
Re: Plugin SMS
Message par loic » 24 févr. 2015, 23:22
ca ressemble a un soucis vmware la qui perd le lien avec la clef... a voir avec les esperes vmware
freshare
Re: Plugin SMS
Message par freshare » 25 févr. 2015, 08:33
ce matin j'ai fait la mise a jour du plugin sms, et depuis que cela soit en reception ou en emission le demon se met en NOK
et j'ai comme erreur sms Error : Timeout
Que faire ?
et au passage comment revenir en arrière après l'application d'une maj sur un plugin ?
Tout petit Guru avec deux mini
> Liste de mon matériel <
loic
Administrateur
Re: Plugin SMS
Message par loic » 25 févr. 2015, 09:47
Le retour arrière c'est une restauration de backup pas d'autre solution a moins d'etre sur une beta dans ce cas tu peux revenir sur la stable et encore c'est très risqué.
Pour ton soucis essaye de tout redémarrer mais le timeout c'est :
- impossible d’accrocher le réseaux
- impossible de joindre le modem
freshare
Re: Plugin SMS
Message par freshare » 25 févr. 2015, 10:36
j'ai tenté une restauration de la sauvegarde de cette nuit (donc avant les maj), mais la restauration à bloquée. Obligé de refaire la carte, mais lorsque je tente de restaurer, le processus reste bloqué sur "Restauration des fichiers..."
loic
Administrateur
Re: Plugin SMS
Message par loic » 25 févr. 2015, 10:46
Ca peut etre très très long (plusieurs dizaines de minutes)
freshare
Re: Plugin SMS
Message par freshare » 25 févr. 2015, 11:26
loic a écrit :Ca peut etre très très long (plusieurs dizaines de minutes)
cela fait une heure... qu'en penses tu ?
loic
Administrateur
Re: Plugin SMS
Message par loic » 25 févr. 2015, 11:55
Ya peut etre eu un soucis vérifie que tu n'as pas remplis la carte SD
freshare
Re: Plugin SMS
Message par freshare » 25 févr. 2015, 12:17
Désolé de poluer le sujet SMS, je vais faire un nouveau sujet...
https://forum.jeedom.fr/viewtopic.php?f=56&t=5256
Syll
Contact :
Re: Plugin SMS
Message par Syll » 25 févr. 2015, 12:53
J'ai pas encore testé ma clef Huawey E220 sur ma mini mais normalement ça devrait fonctionner. SI ça fonctionne, y'a une possibilité de faire évoluer le plugin en mode déporté ? :)
loic
Administrateur
Re: Plugin SMS
Message par loic » 25 févr. 2015, 13:16
C'est déja compatible en deporté....
Syll
Contact :
Re: Plugin SMS
Message par Syll » 25 févr. 2015, 13:23
loic a écrit :C'est déja compatible en deporté....
ah bah cool :)
merki
Syll
Contact :
Re: Plugin SMS
Message par Syll » 25 févr. 2015, 17:09
Comment on fait pour l'utiliser en mode déporté du coup ? J'ai plug ma clef sur ma jeedom mini, mais après je vois pas comment je peux dire à mon jeedom principal que le plugin sms et la clef sont sur une autre mini.
loic
Administrateur
Re: Plugin SMS
Message par loic » 25 févr. 2015, 17:16
Regarde la doc ici : http://doc.jeedom.fr/fr_FR/core.html partie reseaux jeedom c'est tous ce qu'il y a faire
Syll
Contact :
Re: Plugin SMS
Message par Syll » 25 févr. 2015, 17:18
loic a écrit :Regarde la doc ici : http://doc.jeedom.fr/fr_FR/core.html partie reseaux jeedom c'est tous ce qu'il y a faire
Merci je vais regarder ça. J'ai jeté un oeil rapide et je pense que le doc va m'aider pour (bcp) d'autres choses.
Syll
Contact :
Re: Plugin SMS
Message par Syll » 26 févr. 2015, 20:55
Retour rapide sur la clef Huawey E220 :
J'ai les mêmes symptômes que beaucoup, la clef décroche au bout d'un certain temps. Je pense que je vais opter pour un petit HUB USB et je verrai bien :)
freshare
Re: Plugin SMS
Message par freshare » 27 févr. 2015, 13:09
De mon côté comme Syll, je peux envoyer ou recevoir quelques sms... Puis j'ai des "timeout"... Je n'avais pas cela avec la précédente version du plugin.
Envoyé en utilisant Tapatalk
loic
Administrateur
Re: Plugin SMS
Message par loic » 27 févr. 2015, 14:11
A mon avis c'est l'alimentation de la clef pas le plugin
Revenir vers « [Plugin Officiel] SMS »
