A très bientôt !
Eaton Ellipse ECO 650 FR sur Jeedom Smart non reconnu
Tetsuo
Message par Tetsuo » 30 nov. 2017, 10:11
Bonjour à vous.
J'essaye de paramétrer mon Eaton Ellipse ECO 650 FR en installant un serveur NUT pour le configurer dans le plugin NUT.
Impossible de le faire reconnaître sur une Smart via le câble USB.
(A noter qu'il était reconnu parfaitement sur mon ancienne Jeedom Mini+)
lsusb ne remonte rien
root@jeedom:~# lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
En regardant les messages du noyau ...
root@jeedom:~# dmesg | grep 'usb'
[    0.191088] usbcore: registered new interface driver usbfs
[    0.191127] usbcore: registered new interface driver hub
[    0.191182] usbcore: registered new device driver usb
[    0.568257] usbcore: registered new interface driver cdc_ether
[    0.568315] usbcore: registered new interface driver cdc_ncm
[    0.568570] usbcore: registered new interface driver cdc_acm
[    0.568622] usbcore: registered new interface driver usb-storage
[    0.568710] usbcore: registered new interface driver usbserial
[    0.568738] usbcore: registered new interface driver usbserial_generic
[    0.568765] usbserial: USB Serial support registered for generic
[    0.569978] usbcore: registered new interface driver usbhid
[    0.569988] usbhid: USB HID core driver
[    2.379386] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000020, ctrl: 0
[    2.446688] dwc_otg: usb0: type: 0 speed: 0, config: 0, dma: 0, id: 0, phy: c0000000, ctrl: 0
[    2.822810] usb 1-1: new high-speed USB device number 2 using dwc_otg
[  169.378836] usb 1-1.4: new low-speed USB device number 3 using dwc_otg
[  169.498867] usb 1-1.4: device descriptor read/64, error -71
[  169.728804] usb 1-1.4: device descriptor read/64, error -71
[  169.918915] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
[  170.048932] usb 1-1.4: device descriptor read/64, error -71
[  170.288832] usb 1-1.4: device descriptor read/64, error -71
[  170.478884] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[  170.547048] usb 1-1.4: device descriptor read/8, error -71
[  170.726862] usb 1-1.4: device descriptor read/8, error -71
[  170.918915] usb 1-1.4: new low-speed USB device number 6 using dwc_otg
[  170.989053] usb 1-1.4: device descriptor read/8, error -71
[  171.166564] usb 1-1.4: device descriptor read/8, error -71
J'ai fait plusieurs reboot en branchant débranchant, changeant de câble ...
Après des recherches certains évoquent sur l'erreur -71 soit :
  • désactiver l'option CONFIG_USB_SUSPEND du noyau
  • changer le mode de performance
  • un problème d'alimentation insuffisante (j'utilise bien sûr le transfo d'origine Jeedom)
Donc si quelqu'un à une solution, une intuition, une piste je suis preneur. Merci ;)
Sartog
Re: Eaton Ellipse ECO 650 FR sur Jeedom Smart non reconnu
Message par Sartog » 15 avr. 2018, 15:13
Je remonte ce sujet car j'ai exactement le même problème.
Alors que tout fonctionnait sur la mini+, avec la Smart rien n'est détecté.
Le support ne m'a pas aidé car c'est moi qui est installé le serveur nut donc c'est à moi d'installer tout ce qui va avec.
Avec la mini+ il n'y a rien eu de spécial à faire, j'aurais donc tendance à dire que le problème vient des drivers 64bits absent ... ou un truc du genre.
Je n'ai pas encore trouvé la solution, mais je ne désespère pas.
Ce qui est étrange c'est que nous soyons si peu à brancher un onduleur sur la Smart avec ce problème ....
Box : smart, mini+, pi 2 et 3, ipbx800 v4
Protocole : Z-Wave (Fibaro & Qubino), Ikea, Bluetooth
Méteo : Netatmo
Audio : Sonos (Play 1 et 5)
mael501
Message par mael501 » 13 janv. 2019, 16:12
Tetsuo a écrit :
30 nov. 2017, 10:11
Bonjour à vous.
Sartog a écrit :
15 avr. 2018, 15:13
J'ai le même soucis avec une smart et un eaton 3s, avez vous trouvé une solution, éventuellement à partager?
Voilà ce que me sort un "dmesg":
[1401535.698985] usb 1-1.4: device descriptor read/8, error -71
[1401535.807544] hub 1-1:1.0: unable to enumerate USB device on port 4
Mes connaissance en linux sont malheureusement trop limitées :/
Une idée?
1 Jeedom Smart stretch 3.3.30, zwave - rfxcom - zigbee - blea
mael501
Message par mael501 » 16 janv. 2019, 19:22
Personne d'autre n'a une idée sinon?
Tetsuo
Message par Tetsuo » 28 févr. 2019, 22:13
Le support m'a signalé ne rien pouvoir faire.
J'ai fini par l'installer sur mon NAS reconnu de suite via USB et fait une intégration via adresse IP NUT.
Depuis je suis satisfait mais je doute que ce soit une solution satisfaisante pour vous :|
vinc74
Message par vinc74 » 03 avr. 2019, 13:11
Je déterre un peu ce post.
Quel plugin utilisez-vous ? nut_free ?
Robby
Message par Robby » 07 sept. 2019, 23:21
Eaton 3S
Je viens d'acheter le plugin mais impossible de le faire fonctionner en usb...
Idaho947
Message par Idaho947 » 15 sept. 2019, 13:03
Quel tuto as tu suivi?
Revenir vers « [Plugin Officiel] Onduleur (NUT) »
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 7 invités
