A priori je rencontre le meme probleme que blum95 pour l'installation des dépendances.
Je suis sur RPI2 avec jeedom 2.0.1 et jessie comme distrib.
Il me semble me souvenir de vieux posts ou l'install ne fonctionne pas forcement sous jessie? C'est toujours le cas?
Mon log:
########### Installation en cours ##########
Reading package lists...
Building dependency tree...
Reading state information...
software-properties-common is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 91 not upgraded.
File "/usr/bin/add-apt-repository", line 167, in
sp = SoftwareProperties(options=options)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 105, in __init__
self.reload_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 595, in reload_sourceslist
self.distro.get_sources(self.sourceslist)
File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 89, in get_sources
(self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Raspbian/jessie
Get:1 http://mirrordirector.raspbian.org jessie InRelease [15.0 kB]
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://apt.adafruit.com jessie InRelease
Get:2 http://mirrordirector.raspbian.org jessie/main armhf Packages [8963 kB]
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://apt.adafruit.com jessie/main armhf Packages
Hit https://deb.nodesource.com jessie InRelease
Hit https://deb.nodesource.com jessie/main Sources
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://apt.adafruit.com jessie/main Translation-en
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:3 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:6 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:7 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Get:8 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70.3 kB]
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Fetched 9048 kB in 37s (238 kB/s)
libav-tools is already the newest version.
Package libttspico-utils is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libttspico-utils' has no installation candidate
########### Fin ##########
+TouFou
