[Plugin Tiers] Xiaomi Home
non ^^ .
tu le vois dans l'app me home?
Dans me home, Je vois le rond en sous menu de la gateway, et le carré au même niveau que la gateway...
Je sais pas si je suis clair??
magicgg91
j'ai fais une réinstalle puis restaure mais tj le meme pb
tu as une autre piste ?
oui et tj rien
voici mes logs :
Début de l'installation
Version actuelle : v5.12.0
Ok, version suffisante
Reading package lists...
Building dependency tree...
Reading state information...
libssl-dev is already the newest version.
libssl-dev set to manually installed.
python-pip is already the newest version.
python3-pip is already the newest version.
libffi-dev
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 152 kB of archives.
After this operation, 282 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libffi-dev armhf 3.1-2 [152 kB]
debconf: (This frontend requires a controlling tty.)
Fetched 152 kB in 0s (437 kB/s)
Selecting previously unselected package libffi-dev:armhf.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 119745 files and directories currently installed.)
Preparing to unpack .../libffi-dev_3.1-2_armhf.deb ...
Unpacking libffi-dev:armhf (3.1-2) ...
Processing triggers for install-info (5.2.0.dfsg.1-6) ...
Processing triggers for man-db (2.7.0.2-5) ...
Setting up libffi-dev:armhf (3.1-2) ...
Requirement already satisfied (use --upgrade to upgrade): yeecli in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): mihome in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): future in /usr/local/lib/python2.7/dist-packages
Cleaning up...
Requirement already satisfied (use --upgrade to upgrade): python-mirobo in /usr/local/lib/python3.4/dist-packages
Cleaning up...
/var/www/html/plugins/xiaomihome/resources
+-- crypto@0.0.3
`-- dgram@1.0.1
npm WARN enoent ENOENT: no such file or directory, open '/var/www/html/plugins/xiaomihome/resources/package.json'
npm WARN resources No description
npm WARN resources No repository field.
npm WARN resources No README data
npm WARN resources No license field.
+-- crypto@0.0.3
`-- dgram@1.0.1
Fin de l'installation
voici mes logs :
libffi-dev
Cleaning up...
Cleaning up...
Cleaning up...
Cleaning up...
+-- crypto@0.0.3
`-- dgram@1.0.1
+-- crypto@0.0.3
`-- dgram@1.0.1
- Capture d’écran 2017-06-09 à 19.56.46.png (478.24 Kio) Consulté 1617 fois
pourtant j'ai bien des events :
2017-06-09 20:00 - Starting thread Xiaomi
2017-06-09 20:00 - Starting thread Yeelight
Aquara received from 192.168.1.33 : {"cmd":"heartbeat","model":"gateway","sid":"f0b429cc660e","short_id":"0","token":"HnDpYvLHbdCEZh2l","data":"{\"ip\":\"192.168.1.33\"}"}
Aquara received from 192.168.1.33 : {"cmd":"heartbeat","model":"gateway","sid":"f0b429cc660e","short_id":"0","token":"yPB7rBboNAWRnaUw","data":"{\"ip\":\"192.168.1.33\"}"}
Aquara received from 192.168.1.33 : {"cmd":"report","model":"cube","sid":"158d0001148efa","short_id":21635,"data":"{\"status\":\"flip90\"}"}
oui j'ai bien rafraichi ^^
ne serait-ce pas un cache qui traine est qui du coup jeedom ne me recrée pas un objet car il pense qu'il existe deja ?
Je viens vers vous un peu en désespoir de cause...
Depuis plusieurs mois ma config (RPi 3) fonctionnait très bien avec entre autre le plugin Xiaomi. Seulement voilà, début mai ma connexion internet a sauté, ce qui s'est suivi par un changement de box. Bref, suite à ça, j'ai décidé de repartir de zéro (ma sauvegarde ne fonctionne pas, il me sort un soucis avec le fichier backup bien qu'il soit bien là et non vide...).
Seulement voilà, depuis, je rencontre un soucis avec le plugin Xiaomi : le démon ne fonctionne que pendant environ 5 minutes, après quoi plus rien ne remonte, bien que tout fonctionne parfaitement dans l'appli MiHome.
J'ai tenté de repartir plusieurs fois d'une netinstall en n'installant que ce plugin, idem en partie d'un raspbian + installation de Jeedom ensuite, pas moyen de faire tenir le demon.
J'ai vu plusieurs posts avec un problème similaire sur le forum, mais aucune des solutions proposées n'a pu résoudre mon soucis.
A noter que sur chacune des nouvelles installation, Jeedom reste en mode démarrage indéfiniment (en redémarrant ça part). Est ce que le soucis pourrait venir de là ?
Tristan
Tristan
Vivement qu'on passe en python car il me semble qu'il y a bcp de problèmes du type "ca marchait et ça marche plus" ces derniers temps....
Dev plugin Homebridge
Non rien a voir avec passer zn python, surtout que les seuls vrais pbs qu'on a eu dernièrement étaient en python justement donc double abus
La le soucis déjà qu'une installé reste en démarrage c'est pas normal et ça impacte les services, donc voilà. Faudrait déjà avoir une install qui marche correctement avant de mettre un plugin
Moi elle va bien ma version Python
Et ma nodejs aussi en fait... je fais des restore réguliers en stable et bêta pas de prob
bon alors vous allez rire mais j'ai trouvé !!!!!!!!!!!!!!
et ca vient de ma conf réseau jeedom
Mon PI à changé d'ip 192.168.1.22 au lieu de 192.168.1.20 avant.
du coup le module qui va chercher la Configuration réseaux n'avait pas la bonne IP.
du coup la requete de push_data de xiaomihome.py n'avait pas la bonne IP.
4h la dessus !!!
merci de votre temps (pour rien dsl !)
4h la dessus !!!
FIXEZ VOTRE IP !!! On le dira jamais assez
Je pense aussi que ça doit pas aider, mais pourtant je ne fais rien d'autre que d'utiliser l'image netinstall, j'ai même essayé sur 2 cartes SD différentes pour un résultat identique, comprends plus
Prend la dernière raspbian Jessie et utilise l'installation "autre" de jeedom
Salut tout le monde,
Des news de l'intégration des modules carrés (température et ouverture) dans le plugin ?
Pour ma part je les retrouve bien dans mon appli MiHome (iOS) avec la gateway en version 1.4.1_147.0143. Par contre ils ne se sont pas mis au même niveau que les capteurs ronds, j'ai les ronds ensembles et les carrés ensembles.
Copie d'écran à l'appui : A+
Aburner
Aburner
Je viens juste d'acheter et installer le plugin Xiaomi Home.
Petit soucis : impossible d'installer et faire tourner les dépendances donc le démon ne démarre pas.
Je tourne sur Debian 8.
Voici les logs de l'installation des dépendances en niveau de traces 'Info' :
Tout le reste de Jeedom fonctionne sans soucis, j'ai une quinzaine de plugins qui tournent.
J'ai peut-être oublié un truc tout con... je n'utilise Jeedom que depuis quelques semaines.
Version actuelle : v0.10.29
Package 'npm' is not installed, so not removed
The following packages will be REMOVED:
libc-ares2* libv8-3.14.5* nodejs*
0 upgraded, 0 newly installed, 3 to remove and 5 not upgraded.
After this operation, 7463 kB disk space will be freed.
(Reading database ... 52044 files and directories currently installed.)
Removing nodejs (0.10.29~dfsg-2) ...
Removing libc-ares2:amd64 (1.10.0-2+deb8u1) ...
Purging configuration files for libc-ares2:amd64 (1.10.0-2+deb8u1) ...
Removing libv8-3.14.5 (3.14.5.8-8.1) ...
Purging configuration files for libv8-3.14.5 (3.14.5.8-8.1) ...
Processing triggers for libc-bin (2.19-18+deb8u9) ...
Utilisation du dépot officiel
## Installing the NodeSource Node.js v5.x repo...
## Populating apt-get cache...
+ apt-get update
Ign http://ftp.fr.debian.org jessie InRelease
Hit http://ftp.fr.debian.org jessie-updates InRelease
Hit http://security.debian.org jessie/updates InRelease
Ign http://ppa.launchpad.net jessie InRelease
Hit http://ftp.fr.debian.org jessie Release.gpg
Ign http://ppa.launchpad.net jessie Release.gpg
Hit http://ftp.debian.org jessie-backports InRelease
Hit http://ftp.fr.debian.org jessie-updates/contrib Sources
Get:1 http://ftp.fr.debian.org jessie-updates/main amd64 Packages/DiffIndex [7900 B]
Get:2 http://ftp.fr.debian.org jessie-updates/non-free amd64 Packages/DiffIndex [736 B]
Hit http://security.debian.org jessie/updates/non-free Sources
Hit http://ftp.fr.debian.org jessie-updates/contrib amd64 Packages
Get:3 http://ftp.debian.org jessie-backports/main amd64 Packages/DiffIndex [27.8 kB]
Hit http://ftp.fr.debian.org jessie-updates/contrib Translation-en
Get:4 http://ftp.fr.debian.org jessie-updates/main Translation-en/DiffIndex [2704 B]
Get:5 http://ftp.fr.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://ftp.fr.debian.org jessie-updates/main Sources
Hit http://ftp.fr.debian.org jessie-updates/non-free Sources
Hit http://security.debian.org jessie/updates/non-free amd64 Packages
Get:6 http://ftp.debian.org jessie-backports/main Translation-en/DiffIndex [27.8 kB]
Hit http://security.debian.org jessie/updates/non-free Translation-en
Hit http://security.debian.org jessie/updates/main Sources
Hit http://security.debian.org jessie/updates/contrib Sources
Hit http://security.debian.org jessie/updates/main amd64 Packages
Hit http://security.debian.org jessie/updates/contrib amd64 Packages
Err http://ppa.launchpad.net jessie/main amd64 Packages
404 Not Found
Hit http://security.debian.org jessie/updates/contrib Translation-en
Ign http://ppa.launchpad.net jessie/main Translation-en
Hit http://ftp.fr.debian.org jessie/main Sources
Ign http://ppa.launchpad.net jessie/main Translation-fr
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://ftp.fr.debian.org jessie/non-free Sources
Hit http://ftp.fr.debian.org jessie/contrib Sources
Hit http://ftp.fr.debian.org jessie/main amd64 Packages
Hit http://ftp.fr.debian.org jessie/non-free amd64 Packages
Hit http://ftp.fr.debian.org jessie/contrib amd64 Packages
Hit http://ftp.fr.debian.org jessie/contrib Translation-en
Hit http://ftp.fr.debian.org jessie/main Translation-en
Hit http://ftp.fr.debian.org jessie/main Translation-fr
Hit http://ftp.fr.debian.org jessie/non-free Translation-en
Fetched 67.7 kB in 3s (21.4 kB/s)
W: Failed to fetch http://ppa.launchpad.net/linrunner/tlp/ubuntu/dists/jessie/main/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Error executing command, exiting
The following extra packages will be installed:
libc-ares2 libv8-3.14.5
libc-ares2 libv8-3.14.5 nodejs
0 upgraded, 3 newly installed, 0 to remove and 5 not upgraded.
Need to get 0 B/1990 kB of archives.
After this operation, 7463 kB of additional disk space will be used.
Selecting previously unselected package libc-ares2:amd64.
(Reading database ... 51936 files and directories currently installed.)
Preparing to unpack .../libc-ares2_1.10.0-2+deb8u1_amd64.deb ...
Unpacking libc-ares2:amd64 (1.10.0-2+deb8u1) ...
Selecting previously unselected package libv8-3.14.5.
Preparing to unpack .../libv8-3.14.5_3.14.5.8-8.1_amd64.deb ...
Unpacking libv8-3.14.5 (3.14.5.8-8.1) ...
Selecting previously unselected package nodejs.
Preparing to unpack .../nodejs_0.10.29~dfsg-2_amd64.deb ...
Unpacking nodejs (0.10.29~dfsg-2) ...
Setting up libc-ares2:amd64 (1.10.0-2+deb8u1) ...
Setting up libv8-3.14.5 (3.14.5.8-8.1) ...
Setting up nodejs (0.10.29~dfsg-2) ...
update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
libffi-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
Cleaning up...
Cleaning up...
Cleaning up...
Cleaning up...
/var/www/html/plugins/xiaomihome/resources/nodejs.sh: line 63: npm: command not found
/var/www/html/plugins/xiaomihome/resources/nodejs.sh: line 65: npm: command not found
