Merci à Lunarok qui rend la domotique sous jeedom encore plus abordable.
J'ai une question pourquoi avons nous toujours des logs toutes les 10 secondes sur même en ayant coché aucun log dans la configuration du plugin. Cela fait tout de même 60500 logs par semaine. Je pense à ma pauvre carte SD. Ce plugin est clairement le plus bavard dans les logs.
Et ne remplissons nous pas la BD pour rien? Les logs sont bien sauvegardés dans le fichier de restauration?
Merci d'avance pour vos lumière.
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"Bpb1IhJ4Lsr6nDkb","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"gEXMnWWbIfyyhtiR","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"6aaAyiBahW5UVKV2","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"report","model":"gateway","sid":"XXXXX","short_id":0,"data":"{\"rgb\":1090519040}"}
Aquara received from 192.168.1.10 : {"cmd":"report","model":"gateway","sid":"XXXXX","short_id":0,"data":"{\"rgb\":0}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"gPE9YEdMY9JL2jXq","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"xw9dlhgw8HrQXRkr","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"VegfuBMNJaUzECxW","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"3kzCfI0PZ8qy0p19","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"1uS7zHIogYcwtnXr","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"FvOtzpMncZDPGSmA","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"guJcu0NlaYxQoSg4","data":"{\"ip\":\"192.168.1.10\"}"}
Aquara received from 192.168.1.10 : {"cmd":"heartbeat","model":"gateway","sid":"XXXXX","short_id":"0","token":"pDvmMi5zZ4EGWcP2","data":"{\"ip\":\"192.168.1.10\"}"}
