[Plugin Tiers] Xiaomi Home
Re: Xiaomi Home
Suite a un bug j'ai tout supprimer (gateway et les object connecté). Cependant plus rien ne remonte maintenant sur le plugin ?
Il faut que je reste la gateway ?
Re: Xiaomi Home
De mon coté, si je supprime un device Xiaomi Zigbee dans Jeedom, il remonte dès qu'une nouvelle information est envoyé (donc quasi instantanément).
Change la couleur de l'anneau du Xiaomi Home pour forcer l'api à envoyer une donnée, elle devrait remonter instantanément.
Sinon dans le doute, reboot puis regarde si les dépendances et si le daemon est lancé et envois nous ce qui se passe dans les logs du plugin surtout xiaomi node
JJ
JJ
Re: Xiaomi Home
Je viens de refaire et j'ai bien dans les logs les "battements" mais rien ne s'ajoute.
2017-04-13 14:47 - Starting thread Xiaomi2017-04-13 14:47 - Starting thread Yeelight
Aquara received from 192.168.0.xx : {"cmd":"heartbeat","model":"gateway","sid":"286c078924e9","short_id":"0","token":"zaCuEeu82Ag3ZG3w","data":"{\"ip\":\"192.168.0.xx\"}"}
Aquara received from 192.168.0.xx : {"cmd":"heartbeat","model":"gateway","sid":"286c078924e9","short_id":"0","token":"sdmLNu5EiJHFgVx4","data":"{\"ip\":\"192.168.0.xx\"}"}
Aquara received from 192.168.0.xx : {"cmd":"heartbeat","model":"gateway","sid":"286c078924e9","short_id":"0","token":"d2qDn1xTeVyW2AM3","data":"{\"ip\":\"192.168.0.xx\"}"}
Aquara received from 192.168.0.xx : {"cmd":"report","model":"gateway","sid":"286c078924e9","short_id":0,"data":"{\"rgb\":1679162634,\"illumination\":1292}"}
Aquara received from 192.168.0.xx : {"cmd":"heartbeat","model":"gateway","sid":"286c078924e9","short_id":"0","token":"JV2hQ0I0WSWRWtza","data":"{\"ip\":\"192.168.0.xx\"}"}
Aquara received from 192.168.0.xx : {"cmd":"heartbeat","model":"gateway","sid":"286c078924e9","short_id":"0","token":"gX4QlXHnbDhF8hBZ","data":"{\"ip\":\"192.168.0.xx\"}"}
Aquara received from 192.168.0.xx : {"cmd":"heartbeat","model":"gateway","sid":"286c078924e9","short_id":"0","token":"pFaDbzjOZXetOXqS","data":"{\"ip\":\"192.168.0.xx\"}"}
on voit bien le changement de couleur mais rien n'y fait j'ai rien dans la liste.
Je précise que je l'ai supprimé volontairement. Est-ce qu'il faut que je le réinitialise totalement (la gateway) si oui comment faire ?
J'ai que deux object donc je peux le faire sans problème.
Mais a la base j'ai eu un souci mes objet ce sont débrancher de ma gateway il a fallu que je les réveille, ça le fait souvent ?
Maj :
J'ai essayé de restaurer et c'est pareil il ne voit pas d'activité mais j'ai récupéré les object, je vois bien les heartbeat avec le bon SID mais la dernière actiivté de la gateway est pas bonne malgré tout.
Quelqu'un a une idée ?
Maj :
Re: Xiaomi Home
J'ai un petit problème que je n'arrive pas à résoudre , je ne sais pas trop ou poster, je n'arrive pas à avoir le plafonnier dans home bridge, j'ai renseigné les types générique, suite à Ca il est apparu, mais les commandes ne fonctionnent pas , une idée ?
Re: Xiaomi Home
Il a fini par retrouver du monde, j'ai relancer l’installation des dépendance puis redémarrer le service et la dernière communication n'est plus d'il y a 3 jours.
Re: Xiaomi Home
"Et seule la valeur 0 est remonté, je me demande si ce n'es pas un bug.
Personne d'autre n'utilise cet interrupteur ?"
Je te confirme que chez moi non-plus le double interrupteur ne marche pas, le statut reste toujours à '0', quelque-soit l'action effectuée
Re: Xiaomi Home
Aie, j'ai voulut ouvrir un ticket car je suis de plus en plus persuadé que c'est un bug, malheureusement ce n'es pas un plugin officiel.jjtronics a écrit :En essayant de l'intégrer dans un scénario simple, je me rends compte que le premier interrupteur déclenche le trigger, le second ne déclenche meme pas le trigger.jjtronics a écrit :Bonjour à tous,
Quelqu'un à des interrupteur double Aquara (N° de modele Jeedom : 86sw2) ?
Déjà pour ceux qui ne connaissent pas, ils sont tout simplement magnifique et d'excellente facture, j'ai été très agréablement surpris par la qualité du produit.
Ils remontent bien dans Jeedom mais le Status reste à 0 alors que pour les mini interrupteur j'ai bien les click double click ...
En regardant dans les logs du node, les commandes sont pourtant bien remontés :Aurais-je loupé quelque chose ?Code : Tout sélectionner
Aquara received from 192.168.1.41 : {"cmd":"report","model":"86sw2","sid":"158d0001288f3c","short_id":31182,"data":"{\"channel_0\":\"click\"}"} Aquara received from 192.168.1.41 : {"cmd":"report","model":"86sw2","sid":"158d0001288f3c","short_id":31182,"data":"{\"channel_1\":\"click\"}"} Aquara received from 192.168.1.41 : {"cmd":"report","model":"86sw2","sid":"158d0001288f3c","short_id":31182,"data":"{\"dual_channel\":\"both_click\"}"}
Merci à tous pour votre aide,
P.S je suis sur Jeedom stable à jour avec le plugin à jour.
JJ
Merci d'avance pour votre aide,
JJ
Vraiment personne d'autre n'a craqué sur ce très joli interrupteur ? D'autant plus que j'ai aussi commandé les encastrable et ils ont l'air d'avoir exactement le meme fonctionnement
Merci à tous pour votre aide !
Re: Xiaomi Home
garath a écrit :"Et seule la valeur 0 est remonté, je me demande si ce n'es pas un bug.
Ahh, on est deux dans le meme cas, ça doit etre un bug.
Lunarock, tu en penses quoi ?
Re: Xiaomi Home
j'ai fait les mêmes tests que toi et j'ai exactement le même log !
Je vois les commandes remontées mais le plugin n'interprète que le clic du bouton gauche "channel_0" et reste à '0' alors qu'il devrait passer à la valeur "click". Je pense qu'il doit manquer quelque-chose pour gérer les 2 channels ...
Aquara received from 192.168.1.150 : {"cmd":"report","model":"86sw2","sid":"158d0001288fe9","short_id":23273,"data":"{\"channel_0\":\"click\"}"}
Aquara received from 192.168.1.150 : {"cmd":"report","model":"86sw2","sid":"158d0001288fe9","short_id":23273,"data":"{\"channel_1\":\"click\"}"}
Aquara received from 192.168.1.150 : {"cmd":"report","model":"86sw2","sid":"158d0001288fe9","short_id":23273,"data":"{\"dual_channel\":\"both_click\"}"}
Re: Xiaomi Home
J'aimerais me faire un scénario pour savoir si j'ai un problème de reception de la gateway, style si depuis plus de 15 minutes je n'ai pas recçu de communication me balancer une alerte, et pour certain objet aussi.
C'est faisable de récupéré l'info qu'on a sur les infos de l'objet par exemple la dernière communication ?
Re: Xiaomi Home
Reste plus qu'a espérer que Lunarock vois nos message pour nous confirmer l'éventualité d'un bug.garath a écrit :j'ai fait les mêmes tests que toi et j'ai exactement le même log !
Re: Xiaomi Home
Pour récupérer l'info de dernière communication avec l'objet je ne sais pas mais les éléments xiaomi home remontent de façon périodique des informations sur l'état des piles par ex, tu pourrais te baser là dessus comme trigger de déclenchement de ton scénario.ionik a écrit :J'aimerais me faire un scénario pour savoir si j'ai un problème de reception de la gateway, style si depuis plus de 15 minutes je n'ai pas recçu de communication me balancer une alerte, et pour certain objet aussi.
La gateway en elle meme remonte de façon périodique la luminosité de la pièce.
Par contre je n'ai pas fait attention au délais entre deux remonté de valeur de pile mais ça doit pas etre bien long non plus.
Si tu trouves de meilleurs solutions ça m'interesse également !
Re: Xiaomi Home
Déjà je vais regarder les trigger mais on a pas de variables pour les infos les plus mise a jours
Edit : l'information n'est pas disponible donc il faut voir si il peut la rendre accessible.
Re: Xiaomi Home
+1 avec le module double switch à pile 86sw2. Les click passe dans le log Node mais pas de statut remonté par le plugin.garath a écrit :"Et seule la valeur 0 est remonté, je me demande si ce n'es pas un bug.
Aquara received from 192.168.89.1 : {"cmd":"report","model":"86sw2","sid":"158d0001068892","short_id":57758,"data":"{\"channel_0\":\"click\"}"}
Aquara received from 192.168.89.1 : {"cmd":"report","model":"86sw2","sid":"158d0001068892","short_id":57758,"data":"{\"channel_1\":\"click\"}"}
NOTA: Je préfère que Lunarok avance sur les modif de fond du plugin avec Dr S car ceci ne me gène pas forcément pour l'instant.
Re: Xiaomi Home
Surtout que j'en ai acheté 3 de ces doubles interrupteursjjtronics a écrit :Reste plus qu'a espérer que Lunarock vois nos message pour nous confirmer l'éventualité d'un bug.garath a écrit :j'ai fait les mêmes tests que toi et j'ai exactement le même log !
Re: Xiaomi Home
garath a écrit :Surtout que j'en ai acheté 3 de ces doubles interrupteurs?jjtronics a écrit :Reste plus qu'a espérer que Lunarock vois nos message pour nous confirmer l'éventualité d'un bug.garath a écrit :j'ai fait les mêmes tests que toi et j'ai exactement le même log !
De mon coté, j'en ai pris deux et aussi l'encastrable 230v qui est plus cher
Mais je ne l'ai pas encore reçu le dernier
Re: Xiaomi Home
Effectivement, je penses aussi qu'il devrait y avoir deux statuts, je vais essayer de créer de nouvelle commande et trifouiller un peu voir si j'arrive à récupérer la valeur (car elle remonte bien tout de meme dans les logs)xonix a écrit :+1 avec le module double switch à pile 86sw2. Les click passe dans le log Node mais pas de statut remonté par le plugin.garath a écrit :"Et seule la valeur 0 est remonté, je me demande si ce n'es pas un bug.
Je te confirme que chez moi non-plus le double interrupteur ne marche pas, le statut reste toujours à '0', quelque-soit l'action effectuéeD'ailleurs, puisque c'est un module double, il devrait y avoir 2 "status", non? Je n'ai que "Pile Voltage", "Status" et " Batterie" sur les commandes.Code : Tout sélectionner
Aquara received from 192.168.89.1 : {"cmd":"report","model":"86sw2","sid":"158d0001068892","short_id":57758,"data":"{\"channel_0\":\"click\"}"} Aquara received from 192.168.89.1 : {"cmd":"report","model":"86sw2","sid":"158d0001068892","short_id":57758,"data":"{\"channel_1\":\"click\"}"}
Quand tu parles de modifs de fond, tu pourrais nous en dire plus ? Tu parles du menu déroulant qui viendra avec le core v3 ? (Je suis curieux)
JJ
Re: Xiaomi Home
Je ne devrais pas faire de pub ici mais les blogs de certaines personnes sont vraiment à suivre car très intéressant ( l'un des noms des 2 blogueurs dont je parle commence par L... et est très connu dans ce fil et l'autre commence par Dr s... et il est très connu aussi sur Jeedom)
Envoyé de mon FRD-L09 en utilisant Tapatalk
Re: Xiaomi Home
Il doit y avoir 3 statuts en fait (channel 0, channel 1 et double) mais oui y aune crotte dans la valeur j'ai vu. Mais je corrigerais sûrement que pour la prochaine version qui arrivera avant la v3 finalement oui
Et oui y a de la nouveauté dedans, un peu de patience
Re: Xiaomi Home
Par contre, Lunarok, peux-tu juste nous dire dans quel fichier est la "crotte" ? pour qu'on puisse corriger manuellement ? merciiii
Moi je vois bien les 3 status dans : /var/www/html/plugins/xiaomihome/core/config/devices/86sw2/86sw2.json mais je ne vois pas d'erreur ...
