Je viens de faire un scan avec TCPDUMP et je vous en donne un extrait :
19:42:40.856173 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 135
E.../......;..._...2..&.....{"cmd":"heartbeat","model":"gateway","sid":"34df15395ec0e","short_id":"0","token":"FEBd8GTjsmXuvfGt","data":"{\"ip\":\"192.168.1.95\"}"}
19:42:45.406393 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
E.../......M..._...2..&..|I.{"cmd":"report","model":"sensor_switch.aq2","sid":"185c012124575b","short_id":55657,"data":"{\"status\":\"click\"}"}
19:42:48.049456 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
E.../......K..._...2..&..|I.{"cmd":"report","model":"sensor_switch.aq2","sid":"185c012124575b","short_id":55657,"data":"{\"status\":\"click\"}"}
19:42:50.763073 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
E.../......I..._...2..&..|I.{"cmd":"report","model":"sensor_switch.aq2","sid":"185c012124575b","short_id":55657,"data":"{\"status\":\"click\"}"}
19:42:50.833481 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 135
E.../......4..._...2..&.....{"cmd":"heartbeat","model":"gateway","sid":"34df15395ec0e","short_id":"0","token":"sIS9uwuRfu5ulzEL","data":"{\"ip\":\"192.168.1.95\"}"}
19:42:51.062091 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 117
E.../......E..._...2..&..}h.{"cmd":"report","model":"sensor_motion.aq2","sid":"155f00212f4572a","short_id":27471,"data":"{\"no_motion\":\"120\"}"}
19:42:53.042103 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
E.../......D..._...2..&..|I.{"cmd":"report","model":"sensor_switch.aq2","sid":"185c012124575b","short_id":55657,"data":"{\"status\":\"click\"}"}
19:43:35.891089 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
E...0.........._...2..&..|I.{"cmd":"report","model":"sensor_switch.aq2","sid":"185c012124575b","short_id":55657,"data":"{\"status\":\"click\"}"}
19:43:38.110735 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
E...0...... ..._...2..&..|I.{"cmd":"report","model":"sensor_switch.aq2","sid":"185c012124575b","short_id":55657,"data":"{\"status\":\"click\"}"}
19:43:39.848705 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
19:43:40.718899 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 135
E...0.........._...2..&...*){"cmd":"heartbeat","model":"gateway","sid":"34df15395ec0e","short_id":"0","token":"dpOLo8kOI6KItSDO","data":"{\"ip\":\"192.168.1.95\"}"}
19:43:41.569080 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
19:43:45.357992 IP lumi-gateway-v3_miio57925569.4321 > 224.0.0.50.9898: UDP, length 116
E...0 ........._...2..&..|I.{"cmd":"report","model":"sensor_switch.aq2","sid":"185c012124575b","short_id":55657,"data":"{\"status\":\"click\"}"}^C
131 packets captured
131 packets received by filter
0 packets dropped by kernel
On ne le voit pas, mais je poursuis mes actions de click et plus rien de passe.
Ci-dessous, j'ai relancé le TCPDUMP mais au lieu de faire un clic (qui ne se verrait pas), j'ai demandé à la gateway de me jouer un son.
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
19:45:48.442314 IP lumi-gateway-v3_miio57935669.9898 > raspberrypi.9898: UDP, length 77
E..i0n........._...P&.&..U;.{"cmd":"write_ack","sid":"34df15395ec0e","data":"{\"error\":\"Invalid key\"}"}
19:46:04.073704 IP lumi-gateway-v3_miio57935669.9898 > raspberrypi.9898: UDP, length 77
E..i0r........._...P&.&..U;.{"cmd":"write_ack","sid":"34df15395ec0e","data":"{\"error\":\"Invalid key\"}"}
19:46:10.389253 IP lumi-gateway-v3_miio57935669.9898 > raspberrypi.9898: UDP, length 77
E..i0t........._...P&.&..U;.{"cmd":"write_ack","sid":"34df15395ec0e","data":"{\"error\":\"Invalid key\"}"}
19:46:17.602276 IP lumi-gateway-v3_miio57935669.9898 > raspberrypi.9898: UDP, length 77
E..i0w........._...P&.&..U;.{"cmd":"write_ack","sid":"34df15395ec0e","data":"{\"error\":\"Invalid key\"}"}
19:46:24.213493 IP lumi-gateway-v3_miio57935669.9898 > raspberrypi.9898: UDP, length 77
E..i0.........._...P&.&..U;.{"cmd":"write_ack","sid":"34df15395ec0e","data":"{\"error\":\"Invalid key\"}"}
Et là, pas de son mais du code avec des erreurs :
Je précise que lorsque le clic passe, le son passe également.
Il m'indique une clé invalide, mais laquelle et pourquoi au bout de 5 minutes (env) seulement ?
Bon maintenant j'ai une passe de plus. Les capteurs de température continuent à fonctionner. C'est déjà ça.
