Je rencontre depuis l'installation du plugin un soucis de communication.
Je n'ai aucun soucis sur la remonté des informations des divers capteurs ou bouton déjà en place, 9 Magnets, 2 Motions et 4 switchs.
Par contre, malgré plusieurs changements de mot de passe, je n'arrive plus a envoyé de commande a la gateway (changement de couleur) ou au plug pour commande on/off.
En effet, pendant un cours instant, j'ai pu activer / désactiver mon plug via un scénario lors de la première mise en place.
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"vFbQi5HHEsLE5x42","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"eTrwtgh8Bti1l9ai","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"x4C1v0Qd2kE8bTD5","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"ftxU9fHKbKphg7xh","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"AhXGx9tS5X7VtIkx","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"report","model":"motion","sid":"158d0001277b65","short_id":36108,"data":"{\"no_motion\":\"1800\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"6bY9xgCleljUZ5Z1","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"LR05UK2EwdoIWDH5","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"report","model":"switch","sid":"158d00013f6eee","short_id":26816,"data":"{\"status\":\"click\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"vMpXNQya5LLCtjOa","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"mBzIrjMu2Tqteflv","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"4HdHb5skU5kgVvI9","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"Fd14fjNpRmphE5F6","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"Qr0CJuWhhndEH6zx","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"kfyHGmmfEOFcjVI0","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"5rWojAEffo7YBogP","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"YQEZWvzQWgXMcDqm","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"m9uU0JVXqP0hiNjV","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"TFGcFdgRCaAfsCge","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"5UZzCEAFqihBnIsQ","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"afCpMB0xUCp5g7Do","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"nNgKG2pjvKpn74C0","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"o1pR6iFyyJxE7XU8","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"rVjUrJWGazQDS0S8","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"TbZQ7wcwxNo6IJvC","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"ne44KIYQZUbV49Se","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"fniO8mAKWBub84VF","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"report","model":"switch","sid":"158d00013f6eee","short_id":26816,"data":"{\"status\":\"double_click\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"tEtqXBnqKcMUaTdp","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"BYJF4WWQpbQeSneo","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"PAPr63uYhbwv4rX6","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"TCyDWHOB5u9w310y","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"magnet","sid":"158d000110a968","short_id":63921,"data":"{\"status\":\"close\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"9aj3s0Pha0gyNoaP","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"n6ukKuCgou8IaFrf","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"1APkwrgHy8e04Y7B","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"970MFkP5Z5yXYPMT","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"IFHzNLqLWcGFh8Xw","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"ko23CHbbXjwYu76M","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"4iZ3glTkAzDJtVKR","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"plug","sid":"158d00012596c7","short_id":95,"data":"{\"status\":\"on\",\"inuse\":\"1\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"y822qEbNok20p4bi","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"GwHDyQHn310A1kTe","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"0zKFxcmoXNztHxJg","data":"{\"ip\":\"192.168.0.17\"}"}
Aquara received from 192.168.0.17 : {"cmd":"heartbeat","model":"gateway","sid":"286c0785b95f","short_id":"0","token":"lxLLiIDm1kbvgCJd","data":"{\"ip\":\"192.168.0.17\"}"}
Je continue a chercher de mon coté, mais si l'un d'entre vous a idée, je suis preneur
