Message
par yoyo91 » 20 déc. 2016, 18:51
Merci de votre attention, voici le logo en copier coller.
{u'short_id': u'0', u'cmd': u'heartbeat', u'token': u'8LEahPAM021tCJ2V', u'sid': u'f0b4299ae50c', u'model': u'gateway', u'data': u'{"ip":"192.168.1.33"}'}
File "/var/www/html/plugins/xiaomihome/resources/xiaomihome.py", line 16, in <module>
connector.check_incoming()
File "/usr/local/lib/python2.7/dist-packages/mihome/connector.py", line 47, in check_incoming
self.handle_incoming_data(payload)
File "/usr/local/lib/python2.7/dist-packages/mihome/connector.py", line 64, in handle_incoming_data
json.loads(payload["data"]))
File "/var/www/html/plugins/xiaomihome/resources/xiaomihome.py", line 10, in <lambda>
cb = lambda m, s, c, d: push_data(m, s, c, d)
File "/var/www/html/plugins/xiaomihome/resources/xiaomihome.py", line 8, in push_data
r = requests.post(str(sys.argv[1]) + '&model=' + str(model) + '&sid=' + str(sid) + '&cmd=' + str(cmd), json=data, timeout=(0.5, 120), verify=False)
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 94, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 49, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 443, in request
prep = self.prepare_request(req)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 374, in prepare_request
hooks=merge_hooks(request.hooks, self.hooks),
File "/usr/lib/python2.7/dist-packages/requests/models.py", line 304, in prepare
self.prepare_url(url, params)
File "/usr/lib/python2.7/dist-packages/requests/models.py", line 361, in prepare_url
raise InvalidURL("Invalid URL %r: No host supplied" % url)
requests.exceptions.InvalidURL: Invalid URL u'http://:80/plugins/xiaomihome/core/api/xiaomihome.php?apikey=MxwOVS7jEcOjuvsMKCdJXZXjDhgqXNVQiOrFgLKfmY6lcKTI&model=gateway&sid=f0b4299ae50c&cmd=heartbeat': No host supplied
