Re: [Plugin Tiers] Loxone
Publié : 04 févr. 2019, 15:54
Bonjour Lunarok,
Je viens de refaire le test avec une installation neuve en Debian 9 et j'ai la même erreur encore, ci-dessous mon log, merci d'avance.
Début de l'installation
--2019-02-04 15:46:07-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
Length: 1489 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 66.0M=0s
2019-02-04 15:46:08 (66.0 MB/s) - 'dependencies.sh' saved [1489/1489]
dependencies.sh: 3: [: /tmp/jeedom/loxone/dependancy: unexpected operator
Nodejs non installé
Ign:1 http://ftp.fr.debian.org/debian stretch InRelease
Hit:2 http://security.debian.org/debian-security stretch/updates InRelease
Hit:3 http://ftp.fr.debian.org/debian stretch-updates InRelease
Hit:4 http://ftp.fr.debian.org/debian stretch Release
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (9.20161125).
lsb-release set to manually installed.
E: Unable to locate package npm
dependencies.sh: 37: [: x86_64: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 8.x LTS Carbon repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://ftp.fr.debian.org/debian stretch InRelease
## Confirming "stretch" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_8.x/dis ... ch/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
## Creating apt sources list file for the NodeSource Node.js 8.x LTS Carbon repo...
+ echo 'deb https://deb.nodesource.com/node_8.x stretch main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_8.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Get:4 https://deb.nodesource.com/node_8.x stretch InRelease [4647 B]
Hit:5 http://ftp.fr.debian.org/debian stretch Release
Get:6 https://deb.nodesource.com/node_8.x stretch/main Sources [762 B]
Get:8 https://deb.nodesource.com/node_8.x stretch/main amd64 Packages [1009 B]
Fetched 6418 B in 0s (7316 B/s)
## Run `sudo apt-get install -y nodejs` to install Node.js 8.x LTS Carbon and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 13.6 MB of archives.
After this operation, 64.3 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_8.x stretch/main amd64 nodejs amd64 8.15.0-1nodesource1 [13.6 MB]
debconf: (This frontend requires a controlling tty.)
Fetched 13.6 MB in 5s (2500 kB/s)
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 57531 files and directories currently installed.)
Preparing to unpack .../nodejs_8.15.0-1nodesource1_amd64.deb ...
Unpacking nodejs (8.15.0-1nodesource1) ...
Setting up nodejs (8.15.0-1nodesource1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Version actuelle : v8.15.0
> websocket@1.0.28 install /var/www/html/plugins/loxone/resources/node_modules/websocket
> (node-gyp rebuild 2> builderror.log) || (exit 0)
make: Entering directory '/var/www/html/plugins/loxone/resources/node_modules/websocket/build'
CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
SOLINK_MODULE(target) Release/obj.target/bufferutil.node
COPY Release/bufferutil.node
CXX(target) Release/obj.target/validation/src/validation.o
SOLINK_MODULE(target) Release/obj.target/validation.node
COPY Release/validation.node
make: Leaving directory '/var/www/html/plugins/loxone/resources/node_modules/websocket/build'
> lxcommunicator@0.9.0 postinstall /var/www/html/plugins/loxone/resources/node_modules/lxcommunicator
> node ./browserify.js
Creating browserified module...
Creating debug module
Creating release module
Saving debug module
Saving release module
LxCommunicator~Browser.js and LxCommunicator~Browser.min.js has been created!
npm notice created a lockfile as package-lock.json. You should commit this file.
added 274 packages from 277 contributors and audited 1282 packages in 28.71s
found 0 vulnerabilities
Fin de l'installation
0K . 100% 66.0M=0s
Nodejs non installé
+ apt-get update
OK
+ apt-get update
nodejs
Saving debug module
