Début de l'installation
Version actuelle : v5.12.0
Ok, version suffisante
Reading package lists...
Building dependency tree...
Reading state information...
The following extra packages will be installed:
libftdi1
Suggested packages:
avrdude-doc
avrdude libftdi1
0 upgraded, 2 newly installed, 0 to remove and 37 not upgraded.
Need to get 260 kB of archives.
After this operation, 1021 kB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian/ jessie/main avrdude armhf 6.1-2+rpi1 [244 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libftdi1 armhf 0.20-2 [16.7 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 260 kB in 0s (276 kB/s)
Selecting previously unselected package libftdi1:armhf.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 51116 files and directories currently installed.)
Preparing to unpack .../libftdi1_0.20-2_armhf.deb ...
Unpacking libftdi1:armhf (0.20-2) ...
Selecting previously unselected package avrdude.
Preparing to unpack .../avrdude_6.1-2+rpi1_armhf.deb ...
Unpacking avrdude (6.1-2+rpi1) ...
Processing triggers for man-db (2.7.5-1~bpo8+1) ...
Setting up libftdi1:armhf (0.20-2) ...
Setting up avrdude (6.1-2+rpi1) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
/var/www/html/plugins/espeasy/node
`-- http@0.0.0
npm WARN enoent ENOENT: no such file or directory, open '/var/www/html/plugins/espeasy/node/package.json'
npm WARN node No description
npm WARN node No repository field.
npm WARN node No README data
npm WARN node No license field.
Si quelqu'un peut m'aider.....
Déjà désinstalle puis remis toujours pareil
EDIT MODO: Merci d'utiliser les balises code pour poster des logs, c'est plus lisible.
