TypeError: Cannot read property 'result' of undefined
Rroblik
Message par Rroblik » 03 juil. 2019, 08:42
J'ai un soucis depuis plusieurs jours avec le plugin :
au niveau du log du daemon
En résultat tout mes devices sont en "sans réponse" côté application Maison.
Voici le log complet :
[7/3/2019, 8:00:09 AM] [Klbr] [INFO] Adresse Jeedom bien configurée :http://192.168.1.200:800
Load homebridge-camera-ffmpeg.Camera-ffmpeg
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Plafonnier
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Volet
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Ext (nord)
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Salon
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Frigo
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Ext (garage)
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Garage
[7/3/2019, 8:00:09 AM] [Klbr] Accessoire en cache: Onkyo
Setup Payload:
X-HM://0023ISYWYB826
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
    │ 031-45-154 │
[7/3/2019, 8:00:09 AM] [Klbr] Synchronisation Jeedom <> Homebridge...
[7/3/2019, 8:00:09 AM] Homebridge is running on port 51826.
[7/3/2019, 8:00:10 AM] TypeError: Cannot read property 'result' of undefined
    at Request._callback (/var/www/jeedom/plugins/homebridge/resources/node_modules/homebridge-jeedom/lib/jeedom-api.js:48:14)
    at Request.self.callback (/var/www/jeedom/plugins/homebridge/resources/node_modules/request/request.js:185:22)
    at Request.emit (events.js:189:13)
    at Request.<anonymous> (/var/www/jeedom/plugins/homebridge/resources/node_modules/request/request.js:1161:10)
    at IncomingMessage.<anonymous> (/var/www/jeedom/plugins/homebridge/resources/node_modules/request/request.js:1083:12)
    at Object.onceWrapper (events.js:277:13)
    at IncomingMessage.emit (events.js:194:15)
    at endReadableNT (_stream_readable.js:1125:12)
    at process._tickCallback (internal/process/next_tick.js:63:19)
[7/3/2019, 8:00:10 AM] Got SIGTERM, shutting down Homebridge...
[7/3/2019, 8:05:06 AM] Loaded config.json with 0 accessories and 1 platforms.
[7/3/2019, 8:05:06 AM] ---
[7/3/2019, 8:05:07 AM] ====================
[7/3/2019, 8:05:07 AM] ERROR LOADING PLUGIN homebridge-alexa:
[7/3/2019, 8:05:07 AM] Error: Cannot find module 'bottleneck'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:582:15)
    at Function.Module._load (internal/modules/cjs/loader.js:508:25)
    at Module.require (internal/modules/cjs/loader.js:637:17)
    at require (internal/modules/cjs/helpers.js:22:18)
    at Object.<anonymous> (/var/www/jeedom/plugins/homebridge/resources/node_modules/homebridge-alexa/lib/alexaLocal.js:11:18)
    at Module._compile (internal/modules/cjs/loader.js:701:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:712:10)
    at Module.load (internal/modules/cjs/loader.js:600:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:539:12)
    at Function.Module._load (internal/modules/cjs/loader.js:531:3)
[7/3/2019, 8:05:08 AM] Loaded plugin: homebridge-camera-ffmpeg
[7/3/2019, 8:05:08 AM] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[7/3/2019, 8:05:08 AM] ---
[7/3/2019, 8:05:08 AM] Loaded plugin: homebridge-jeedom
[7/3/2019, 8:05:08 AM] Registering platform 'homebridge-jeedom.Jeedom'
[7/3/2019, 8:05:08 AM] Loading 1 platforms...
[7/3/2019, 8:05:08 AM] [Klbr] Initializing Jeedom platform...
[7/3/2019, 8:05:08 AM] [Klbr] debugLevel:200
[7/3/2019, 8:05:08 AM] [Klbr] [INFO] Adresse Jeedom bien configurée :http://192.168.1.200:800
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Plafonnier
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Volet
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Ext (nord)
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Salon
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Frigo
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Ext (garage)
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Garage
[7/3/2019, 8:05:08 AM] [Klbr] Accessoire en cache: Onkyo
Setup Payload:
    │ 031-45-154 │
[7/3/2019, 8:05:08 AM] [Klbr] Synchronisation Jeedom <> Homebridge...
[7/3/2019, 8:05:08 AM] Homebridge is running on port 51826.
[7/3/2019, 8:05:09 AM] TypeError: Cannot read property 'result' of undefined
[7/3/2019, 8:05:09 AM] Got SIGTERM, shutting down Homebridge...
[7/3/2019, 8:10:06 AM] Loaded config.json with 0 accessories and 1 platforms.
[7/3/2019, 8:10:06 AM] ---
[7/3/2019, 8:10:07 AM] ====================
[7/3/2019, 8:10:07 AM] ERROR LOADING PLUGIN homebridge-alexa:
[7/3/2019, 8:10:07 AM] Error: Cannot find module 'bottleneck'
Avez-vous une idée ?
Pour info je suis à jour côté plugin et dépendances, et je suis sous iOS 13 beta
EDIT : j'ai installé manuellement bottleneck suite à ce post : viewtopic.php?f=188&t=35564&p=738532&hi ... ck#p737957 mais l'erreur persiste
Nebz
Modérateur
Re: TypeError: Cannot read property 'result' of undefined
Message par Nebz » 03 juil. 2019, 09:00
Hello, c'est normal que ton port soit 800 ? Va vérifier tes paramètres réseau interne dans jeedom
Dev plugin Homebridge
Rroblik
Message par Rroblik » 06 juil. 2019, 07:34
Hello
Oui sa c’est normal :)
Jeedom est sur un pi qui fait office de reverse proxy pour différent équipement donc le port 80 n’est pas libre pour Jeedom. Mais sa tourne sans soucis depuis plus d’un an :)
Nebz
Modérateur
Message par Nebz » 06 juil. 2019, 08:17
Oui mais là le démon ne parvient plus à récupérer la liste des périphériques sur jeedom... et il se connecte à l'api qui est sur cette adresse....
Nebz
Modérateur
Message par Nebz » 06 juil. 2019, 08:22
Et sinon pour bottleneck il fait partie des dépendances... donc il doit être installé à ce moment, tu as tenté de réinstaller les dépendances ? Ou faire une "réparation et réinstallation " ?
Rroblik
Message par Rroblik » 06 juil. 2019, 09:26
Jeedom est correctement configuré localement il retrouve bien son monde y compris sur ce port, la piste n’est pas la bonne.
Il y a du avoir un changement côté iOS car je suis sous ios 13 et je crois que c’est puis ce moment que sa ne marche plus.
Je vais tenter de réparer effectivement mais je voulais éviter car je crois que je vais devoir remettre tout côté app Maison mais bon...!
Nebz
Modérateur
Message par Nebz » 06 juil. 2019, 09:31
Lol aucun lien avec ios13 :-)
Tout fonctionne parfaitement de ce côté !
C'est pas une piste que je te donnais... simplement la raison :-)
Rroblik
Message par Rroblik » 06 juil. 2019, 12:27
La raison de?
Mes devices sont tout à fait bien remontés comme on peut le voir!
Ce forum ne changera jamais : une poignée pense tout savoir et prend les autres pour des bébêtes.
Je vais regarder au niveau des dépendances du module dont dépend celui la
Quelqu’un d’autre a le même cas peu être ?
Nebz
Modérateur
Message par Nebz » 06 juil. 2019, 12:31
Oui je pense savoir de quoi je parle c'est moi qui ait développé ce plug-in ;-)
Donc la raison de ton problème.
Non personne d'autre n'a le problème actuellement. Ça vient donc de ton install...
Je t'ai proposé une solution mais tu ne m'as pas fait de retour, tu peux m'en dire plus ?
Revenir vers « [Plugin Tiers] Homebridge »
