Error: The requested platform 'Alexa' was not registered
Networks514
Message par Networks514 » 04 juil. 2019, 17:00
Suite réinstallation dépendance, j'ai ce message au redémarrage du démon
[2019-7-4 14:25:11] ====================
[2019-7-4 14:25:12] Loaded plugin: homebridge-camera-ffmpeg
[2019-7-4 14:25:12] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[2019-7-4 14:25:12] ---
[2019-7-4 14:25:12] Loaded plugin: homebridge-jeedom
[2019-7-4 14:25:12] Registering platform 'homebridge-jeedom.Jeedom'
[2019-7-4 14:25:12] Loading 2 platforms...
[2019-7-4 14:25:12] [JEEDOM-PI] Initializing Jeedom platform...
[2019-7-4 14:25:12] [JEEDOM-PI] debugLevel:300
[2019-7-4 14:25:12] Error: The requested platform 'Alexa' was not registered by any plugin.
at API.platform (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/api.js:134:13)
at Server._loadPlatforms (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/server.js:327:45)
at Server.run (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/server.js:90:36)
at module.exports (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/cli.js:59:10)
at Object.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (module.js:653:30)
at Object.Module._extensions..js (module.js:664:10)
at Module.load (module.js:566:32)
at tryModuleLoad (module.js:506:12)
at Function.Module._load (module.js:498:3)
[2019-7-4 14:25:12] Got SIGTERM, shutting down Homebridge...
Je ne comprends pourquoi :
J'avais avant dans la partie plateforme homebridge supplémentaire
"platform": "Alexa",
"name": "Alexa",
"username": "XXX",
"password": "XXX"
Rien dans Gérer les plugins pour Homebridge
J'ai tenté Réparer et Reinstaller idem.
En supprimant la plateforme homebridge supplémentaire, le demon démarre bien, mais quid de la plateforme Alexa
Ai-je loupé qq chose ?
Networks514
Nebz
Modérateur
Re: Error: The requested platform 'Alexa' was not registered
Message par Nebz » 04 juil. 2019, 17:02
Hello,Envoi ton log de dépendance après avoir fait réparer et réinstaller
Dev plugin Homebridge
Networks514
Message par Networks514 » 04 juil. 2019, 20:05
Mon log
--0%
--10%
Lancement de l'installation/mise à jour des dépendances homebridge
--20%
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Hit:3 https://deb.nodesource.com/node_8.x stretch InRelease
Fetched 40.3 kB in 1s (26.2 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
apt-utils is already the newest version (1.4.9).
avahi-daemon is already the newest version (0.6.32-2).
avahi-discover is already the newest version (0.6.32-2).
avahi-utils is already the newest version (0.6.32-2).
dialog is already the newest version (1.3-20160828-2).
libavahi-compat-libdnssd-dev is already the newest version (0.6.32-2).
libnss-mdns is already the newest version (0.10-8).
0 upgraded, 0 newly installed, 0 to remove and 121 not upgraded.
--30%
Version actuelle :
--40%
Package 'npm' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
--45%
Utilisation du dépot officiel
## Installing the NodeSource Node.js 8.x LTS Carbon repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Fetched 25.4 kB in 1s (16.3 kB/s)
## Confirming "stretch" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_8.x/dists/stretch/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
## Creating apt sources list file for the NodeSource Node.js 8.x LTS Carbon repo...
+ echo 'deb https://deb.nodesource.com/node_8.x stretch main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src https://deb.nodesource.com/node_8.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Fetched 25.4 kB in 1s (17.5 kB/s)
## Run `sudo apt-get install -y nodejs` to install Node.js 8.x LTS Carbon and npm
## You may also need development tools to build native addons:
     sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
     curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
     echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
     sudo apt-get update && sudo apt-get install yarn
  nodejs
0 upgraded, 1 newly installed, 0 to remove and 121 not upgraded.
Need to get 0 B/12.4 MB of archives.
After this operation, 60.9 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 63744 files and directories currently installed.)
Preparing to unpack .../nodejs_8.16.0-1nodesource1_armhf.deb ...
Unpacking nodejs (8.16.0-1nodesource1) ...
Setting up nodejs (8.16.0-1nodesource1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Version actuelle : v8.16.0
--50%
--60%
Installation de Homebridge...
added 178 packages from 162 contributors and audited 732 packages in 25.824s
found 0 vulnerabilities
--70%
--80%
--90%
Désactivation de avahi-daemon au démarrage...(il démarrera avec le daemon (on contourne le bug de la Smart du 1 jan 1970))
--95%
--100%
Installation des dépendances Homebridge terminée, vérifiez qu'il n'y a pas d'erreur
Et le démon
[2019-7-4 18:00:16] ====================
[2019-7-4 18:00:18] Loaded plugin: homebridge-camera-ffmpeg
[2019-7-4 18:00:18] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[2019-7-4 18:00:18] ---
[2019-7-4 18:00:18] Loaded plugin: homebridge-jeedom
[2019-7-4 18:00:18] Registering platform 'homebridge-jeedom.Jeedom'
[2019-7-4 18:00:19] Loading 2 platforms...
[2019-7-4 18:00:19] [JEEDOM-PI_Repaired_a3] Initializing Jeedom platform...
[2019-7-4 18:00:19] [JEEDOM-PI_Repaired_a3] debugLevel:300
[2019-7-4 18:00:19] Error: The requested platform 'Alexa' was not registered by any plugin.
[2019-7-4 18:00:19] Got SIGTERM, shutting down Homebridge...
Est-ce normal de ne rien avoir dans Gestion des Plugins pour Homebridge ? Je n'ai rien d'installer et j'avais souvenir d'avoir vu Homebridge-Alexa ..
Merci à toi
Networks514
Nebz
Modérateur
Message par Nebz » 04 juil. 2019, 21:04
pour moi l'installation s'est bien passée,
pouvez vous vérifier dans le dossier : /var/www/html/plugins/homebridge/resources/node_modules/ que vous avez homebridge-alexa ?
Nebz
Modérateur
Message par Nebz » 04 juil. 2019, 21:09
oui dans gérer les plugin, Alexa n'est pas affiché comme il fait partie des dépendances directement.
Networks514
Message par Networks514 » 04 juil. 2019, 21:19
J’ai bien homebridge-Alexa avec le contenu
root@raspberrypi:/var/www/html/plugins/homebridge/resources/node_modules/homebridge-alexa# ls
config.schema.json  lib  node_modules  package.json  plugin.js  README.md  Roadmap.md  Troubleshooting.MD  V1_README.md
Dès que je rajoute ceci dans plate-forme homebridge supplémentaire , j’ai le message d’erreur au lancement du démon
    "name": "Alexa",
    "username": "XXX",
    "password": "XXX"
Networks514
Networks514
Message par Networks514 » 04 juil. 2019, 21:47
Bon, j’ai restauré ma sauvegarde de cette nuit et ça remarche
Pour info, dans Gestion des plugins pour homebridge, j’ai à nouveau :
×homebridge-alexa @ 0.1.35 - Alexa Skill frontend for Homebridge
Je retenterai plus tard la réinstallation des dépendances 😀
Et merci à toi de t’être penché sur mon pb !
Networks514
Masterfion
Message par Masterfion » 07 juil. 2019, 20:44
Salut Nebz,
J'ai la même erreur que Networks514 mais je ne restaurerai pas ma sauvegarde :D
Nous allons devoir trouver pourquoi nous avons cette erreur... si tu veux bien.
Pourquoi et Comment : mise à jour d'un "vieux Jeedom" de prod vers Jeedom 3.3.25 (dernière stable).
Plugin Homebridge stable / beta dernière version : idem.
Log :
[2019-7-7 18:42:57] ====================
[2019-7-7 18:42:57] Loaded plugin: homebridge-camera-ffmpeg
[2019-7-7 18:42:57] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[2019-7-7 18:42:57] ---
[2019-7-7 18:42:57] Loaded plugin: homebridge-jeedom
[2019-7-7 18:42:57] Registering platform 'homebridge-jeedom.Jeedom'
[2019-7-7 18:42:57] Loading 2 platforms...
[2019-7-7 18:42:57] [CT-Jeedom_Repaired_2d] Initializing Jeedom platform...
[2019-7-7 18:42:57] [CT-Jeedom_Repaired_2d] debugLevel:300
[2019-7-7 18:42:57] Error: The requested platform 'Alexa' was not registered by any plugin.
[2019-7-7 18:42:57] Got SIGTERM, shutting down Homebridge...
Merci pour ton aide.
Je désactive le plugin.
Beta-Testeur JEEDOM
Nebz
Modérateur
Message par Nebz » 07 juil. 2019, 20:48
Tu peux fournir tes dep ?
Masterfion
Message par Masterfion » 08 juil. 2019, 08:30
Hello, les voici :
--10%
--20%
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 http://ftp.debian.org/debian stretch InRelease
Hit:3 http://ftp.debian.org/debian stretch-updates InRelease
Hit:4 http://ftp.debian.org/debian stretch Release
Hit:5 https://deb.nodesource.com/node_8.x stretch InRelease
Hit:6 http://repo.zabbix.com/zabbix/3.4/debian stretch InRelease
build-essential is already the newest version (12.3).
0 upgraded, 0 newly installed, 0 to remove and 34 not upgraded.
--30%
Version actuelle :
--40%
--45%
+ apt-get update
Hit:4 http://ftp.debian.org/debian stretch-updates InRelease
Hit:5 http://ftp.debian.org/debian stretch Release
OK
+ apt-get update
Hit:4 https://deb.nodesource.com/node_8.x stretch InRelease
nodejs
0 upgraded, 1 newly installed, 0 to remove and 34 not upgraded.
Need to get 13.6 MB of archives.
After this operation, 64.4 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_8.x stretch/main amd64 nodejs amd64 8.16.0-1nodesource1 [13.6 MB]
Fetched 13.6 MB in 0s (15.4 MB/s)
(Reading database ... 58909 files and directories currently installed.)
Preparing to unpack .../nodejs_8.16.0-1nodesource1_amd64.deb ...
Detected old npm client, removing...
--50%
--60%
added 178 packages from 162 contributors and audited 732 packages in 3.041s
--70%
--80%
--90%
--95%
--100%
Beta-Testeur JEEDOM
Nebz
Modérateur
Message par Nebz » 08 juil. 2019, 08:34
aucun problème de ce coté, et le dossier homebridge-alexa est bien là dans resources /node_modules ?
autre question, peux-tu relancer le démon et m'envoyer tout le log de début ? c'est la partie de chargement des modules qui m'intéresse (ou il devrait justement dire qu'il charge homebridge-alexa... ou pas ;)
Nebz
Modérateur
Message par Nebz » 08 juil. 2019, 08:35
sauf si t'as rien avant :
Masterfion
Message par Masterfion » 08 juil. 2019, 20:38
Excuse-moi, je n'ai pas pu te fournir ça plus tôt.
Voici les logs complets après reboot du daemon :
[2019-7-8 18:36:38] Loaded config.json with 0 accessories and 2 platforms.
[2019-7-8 18:36:38] ---
[2019-7-8 18:36:38] ====================
[2019-7-8 18:36:38] ERROR LOADING PLUGIN homebridge-alexa:
[2019-7-8 18:36:38] Error: Cannot find module 'bottleneck'
at Function.Module._resolveFilename (module.js:548:15)
at Function.Module._load (module.js:475:25)
at Module.require (module.js:597:17)
at require (internal/module.js:11:18)
at Object.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-alexa/lib/alexaLocal.js:11:18)
[2019-7-8 18:36:38] Loaded plugin: homebridge-camera-ffmpeg
[2019-7-8 18:36:38] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[2019-7-8 18:36:38] Loaded plugin: homebridge-jeedom
[2019-7-8 18:36:38] Registering platform 'homebridge-jeedom.Jeedom'
[2019-7-8 18:36:38] Loading 2 platforms...
[2019-7-8 18:36:38] [CT-Jeedom_Repaired_2d] Initializing Jeedom platform...
[2019-7-8 18:36:38] [CT-Jeedom_Repaired_2d] debugLevel:300
[2019-7-8 18:36:38] Error: The requested platform 'Alexa' was not registered by any plugin.
[2019-7-8 18:36:38] Got SIGTERM, shutting down Homebridge...
Beta-Testeur JEEDOM
Nebz
Modérateur
Message par Nebz » 08 juil. 2019, 21:29
Ma première question, tu peux aussi vérifier stp ?
Masterfion
Message par Masterfion » 09 juil. 2019, 20:25
Hello, j'ai bien le dossier /var/www/html/plugins/homebridge/resources/node_modules/homebridge-alexa... aux côtés de 166 autres dossiers (y a du monde là dedans !).
Beta-Testeur JEEDOM
Nebz
Modérateur
Message par Nebz » 09 juil. 2019, 21:37
Il y a un package.json dedans ?
Masterfion
Message par Masterfion » 10 juil. 2019, 09:00
Yep :
Beta-Testeur JEEDOM
