erreur lancement homebridge
Publié : 02 oct. 2019, 15:02
hello,
j'ai ca comme message d'erreur au lancement.
une idée?
[10/2/2019, 12:55:07] Loaded config.json with 2 accessories and 2 platforms.
[10/2/2019, 12:55:07] ---
[10/2/2019, 12:55:09] Loaded plugin: homebridge-alexa
[10/2/2019, 12:55:09] Registering platform 'homebridge-alexa.Alexa'
[10/2/2019, 12:55:09] ---
[10/2/2019, 12:55:10] Loaded plugin: homebridge-camera-ffmpeg
[10/2/2019, 12:55:10] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[10/2/2019, 12:55:10] ---
[10/2/2019, 12:55:10] Loaded plugin: homebridge-jeedom
[10/2/2019, 12:55:10] Registering platform 'homebridge-jeedom.Jeedom'
[10/2/2019, 12:55:12] Loaded plugin: homebridge-dafang
[10/2/2019, 12:55:12] Registering platform 'homebridge-dafang.Dafang'
[10/2/2019, 12:55:12] ---
[10/2/2019, 12:55:12] Loaded plugin: homebridge-hyperion
[10/2/2019, 12:55:12] Registering accessory 'homebridge-hyperion.Hyperion'
[10/2/2019, 12:55:12] Loaded plugin: homebridge-mqtt
homebridge API version: 2.4
[10/2/2019, 12:55:12] Registering platform 'homebridge-mqtt.mqtt'
[10/2/2019, 12:55:13] Loaded plugin: homebridge-onkyo
[10/2/2019, 12:55:13] Registering accessory 'homebridge-onkyo.Onkyo'
[10/2/2019, 12:55:13] ---
[10/2/2019, 12:55:14] Loaded plugin: homebridge-ring
[10/2/2019, 12:55:14] Registering platform 'homebridge-ring.Ring'
[10/2/2019, 12:55:14] ---
[10/2/2019, 12:55:15] Loaded plugin: homebridge-samsungtv-control
[10/2/2019, 12:55:15] Registering accessory 'homebridge-samsungtv.SamsungTV'
[10/2/2019, 12:55:15] ---
[10/2/2019, 12:55:15] Loaded plugin: homebridge-tasmota-sonoff-thermostat
[10/2/2019, 12:55:15] Registering accessory 'homebridge-tasmota-thermostat.tasmota-thermostat'
[10/2/2019, 12:55:16] Loaded plugin: homebridge-xiaomi-roborock-vacuum
[10/2/2019, 12:55:16] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
[10/2/2019, 12:55:16] ---
[10/2/2019, 12:55:16] Loading 2 platforms...
[10/2/2019, 12:55:16] [Tréméloir_Repaired_c7] Initializing Jeedom platform...
[10/2/2019, 12:55:16] [Tréméloir_Repaired_c7] debugLevel:100
[10/2/2019, 12:55:16] [Tréméloir_Repaired_c7] [INFO] Adresse Jeedom bien configurée :http://192.168.1.38:80
[10/2/2019, 12:55:16] [Ring] Initializing Ring platform...
[10/2/2019, 12:55:16] Loading 2 accessories...
[10/2/2019, 12:55:16] [TV Backlight] Initializing Hyperion accessory...
[10/2/2019, 12:55:16] [TV Backlight] Starting Hyperion Accessory
[10/2/2019, 12:55:16] Error: The requested accessory 'xiaomiroborockvacuum' was not registered by any plugin.
at API.accessory (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/api.js:64:13)
at Server._loadAccessories (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/server.js:297:42)
at Server.run (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/server.js:91:38)
at module.exports (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/lib/cli.js:59:10)
at Object.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (internal/modules/cjs/loader.js:936:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:947:10)
at Module.load (internal/modules/cjs/loader.js:790:32)
at Function.Module._load (internal/modules/cjs/loader.js:703:12)
at Function.Module.runMain (internal/modules/cjs/loader.js:999:10)
at internal/main/run_main_module.js:17:11
[10/2/2019, 12:55:16] Got SIGTERM, shutting down Homebridge...
une idée?
