Hi
I’m struggling with the correct settings for my Ikea bulbs.
The bulb and dimmer are connected to deconz, and the dimmer is set to control the bulb in the phoscon app and it’s working as it should.
I just can’t find the correct settings in the homebridge plugin to control the bulb.
The problem is that the Ikea bulb got the value 1 when the bulb is off, and the max value is 254 (100% light) and from what I can read, the plugin goes from 0 to 255.
So on the phone it shows with 0% light, but the bulb on, when turning off the light with the dimmer.
Sent from my iPhone using Tapatalk
Ikea bulb and round dimmer
Re: Ikea bulb and round dimmer
You should have a binary command in your lightbulb equipment, assign the generic type : light status (binary)/Lumière Etat (Binaire) to it.
Dev plugin Homebridge
This is what I have now
When turning off (With the dimmer) the light then bulb still show as on, in HomeKit.
Don’t mind the rest of the lights. That’s from my old SmartThings hub
And this is what the debug shows when turning off the light with the dimmer:
[11/12/2019, 9:18:51 AM] [Vestervang 19] [INFO] [Maj reçue de Jeedom] commande:7 value:0
[11/12/2019, 9:18:51 AM] [Vestervang 19] [INFO] [[Modification Cache Jeedom: Light 4>Etat 01() de 1 vers 0 dans {"id":"7","logicalId":"01.state::on","generic_type":"","eqType":"deconz","name":"Etat 01","order":"0","type":"info","subType":"numeric","eqLogic_id":"3","isVisible":0,"alert":[],"currentValue":1,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}
[11/12/2019, 9:18:51 AM] [Vestervang 19] [INFO] [Maj reçue de Jeedom] commande:10 value:1
[11/12/2019, 9:18:51 AM] [Vestervang 19] [INFO] [[Modification Cache Jeedom: Light 4>Etat Luminosité 01(LIGHT_STATE) de 157 vers 1 dans {"id":"10","logicalId":"01.state::bri","generic_type":"LIGHT_STATE","eqType":"deconz","name":"Etat Luminosité 01","order":"1","type":"info","subType":"numeric","eqLogic_id":"3","isVisible":0,"alert":[],"currentValue":157,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}
[11/12/2019, 9:18:51 AM] [Vestervang 19] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat Luminosité 01" (10) Envoi valeur: true dans On
[11/12/2019, 9:18:51 AM] [Vestervang 19] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat Luminosité 01" (10) Envoi valeur: 0 dans Brightness
[11/12/2019, 9:18:51 AM] [Vestervang 19] [DEBUG] ==RESTART POLLING==
as said before, assign "Lumière Etat (Binaire)" to your first command (id 1)
Nebz a écrit :as said before, assign "Lumière Etat (Binaire)" to your first command (id 1)
Thank you very much now it’s working.
Now I just have to figure out the dimmer. Somehow deconz is storing the dimmer value so if I change the dimmer on the phone and turn it off on the phone, when I then use the dimmer, it returns to the dimmers last known value
but that behaviour is the same if you use it in jeedom dashboard's widget isn't it ?
Nebz a écrit :but that behaviour is the same if you use it in jeedom dashboard's widget isn't it ?
I think so. I used to use the Ikea gateway plugin but I’m trying to migrate everything to Jeedom because I got some zigbee Sensors that keeps loosing connection because of the distance.
But I think the Ikea hub only store the last known value of the bulb where the deconz store both the bulb and the dimmer (or at least I think so)
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 15 invités
