J'ai crée un widget Poubelle qui change d'état en fonction d'une variable
- - Poubelles vertes
- Poubelles grises
- OK
Pouvez vous me dire ce que je dois modifier dans le code du widget ?
Pour info j'ai crée le widget via le plugin directement
Le code
<div style="min-width:120px; min-height:80px;" class="cmd tooltips cmd-widget cursor container-fluid" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#">
<center>
<div style="font-weight: bold;font-size : 12px;#hideCmdName#">#name_display#</div>
<span style="font-size: 2.5em;" class="iconCmd"></span>
<div style="display:inline-block;">
<span style="font-weight: bold;" class="pull-right">#unite#</span>
<span style="font-size: 2em;font-weight: bold;" class="pull-right state"></span>
</div>
<div style="#displayHistory# font-size: 0.8em;" class="col-xs-12 center-block">
<span title="Min" class="tooltips">#minHistoryValue#</span>|<span title="Moyenne" class="tooltips" >#averageHistoryValue#</span> | <span title="Max" class="tooltips">#maxHistoryValue#</span> <i class="#tendance#"></i>
</div>
</center>
<!-- Ne Pas Supprimer -->
<script class="createWidgetInfo" type="text/javascript">//<![CDATA[{"type":"1","version":"1","size":"2.5","min":["0","50","52"],"max":["49","51","100"],"images":["poubok.png","poubdechets.png","poubvertes.png"]}]]></script>
<script>
var srcImg = 'plugins/widget/core/template/dashboard/cmd.info.numeric.Poubelles/';
var iconUpdate = function (state){
$('.cmd[data-cmd_uid=#uid#] .iconCmd').empty();
if (state >= 0 && state <= 49) {
$('.cmd[data-cmd_uid=#uid#] .iconCmd').html('<img style="display: inline-block;" src="'+srcImg+'poubok.png">');
if (state >= 50 && state <= 51) {
$('.cmd[data-cmd_uid=#uid#] .iconCmd').html('<img style="display: inline-block;" src="'+srcImg+'poubdechets.png">');
if (state >= 52 && state <= 100) {
$('.cmd[data-cmd_uid=#uid#] .iconCmd').html('<img style="display: inline-block;" src="'+srcImg+'poubvertes.png">');
$('.cmd[data-cmd_uid=#uid#] .state').text(state);
$('.cmd[data-cmd_uid=#uid#]').attr('title','Valeur du '+_options.valueDate+', collectée le '+_options.collectDate)
iconUpdate(_options.display_value);
jeedom.cmd.update['#id#']({display_value:'#state#',valueDate:'#valueDate#',collectDate:'#collectDate#',alertLevel:'#alertLevel#'});
</script>
</div>
Merci pour votre aide
